Leica User Forum
Go Back   Leica User Forum > International User Forum > Leica Products > Leica M / M-E / M9 / Monochrom > Leica M9 SD Card Issues
Old 16/04/10, 18:15   #1 (permalink)
Benutzer
Daumen runter Samsung "Tough" SDHC cards - non compliant
Ad
Just a quickie to let everyone know that these cards DO NOT work in the M9.
The picture will be written to the card but the camera will not replay it - most of the time anyway. When opened on a computer all is ok and the data is intact but the M9 just shows the picture number and doesnt open the file!!!!!
Cards i tried were the silver waterproof/shockproof etc etc 8Gb.
craig stanton is offline   Reply With Quote
Old 16/04/10, 23:05   #2 (permalink)
Erfahrener Benutzer
Aperture 2's Avatar
Frage Re: Samsung "Tough" SDHC cards - non compliant
Did you try to format the card in the camera ? Over write ?
Aperture 2 is offline   Reply With Quote
Old 17/04/10, 00:04   #3 (permalink)
Benutzer
Default Re: Samsung "Tough" SDHC cards - non compliant
ive tried formatting it and overwriting it a few times and it just wont play back the files!!!!! Just wanted to let others know they dont work, cant figure it!!!!!
Old 18/04/10, 01:54   #4 (permalink)
Erfahrener Benutzer
I had a slightly different result with the 16GB Samsung--after turning on the camera, the first shot never plays back, only returns file number. Second shot, whether in series or just a little later, plays back normally. On the computer, the first shot is there and OK. I completely re-formated, more than once, including the tedious "overwrite," and still get the same results. I cannot explain this behavior but I would second the OPs opinion. By the way, my card was a gift directly from Samsung after touring their plant in Korea!!
Joe
Englander is offline   Reply With Quote
Old 01/09/11, 17:10   #5 (permalink)
Erfahrener Benutzer
roydonian's Avatar
What is the situation now, almost a year and a half since the original post? Is anyone successfully using these cards in an M8 or M9? Adverts for them have appeared in LFI.
Best regards,
Doug
roydonian is offline   Reply With Quote
Old 02/09/11, 22:31   #6 (permalink)
Benutzer
I've just shot 200+ images on a 16GB Samsung card and it has worked just fine.
(M9)
Regards Graham
lodeway is offline   Reply With Quote
Old 05/09/11, 11:53   #7 (permalink)
Neuer Benutzer
clinn's Avatar
I am currently using a Samsung "Tough" SDHC card 8Gb I had as a gift with LFI subscription.
and it is working great.
formatted on camera.
__________________
cià
clinn
www.clinnx.jalbum.net
clinn is offline   Reply With Quote
Old 07/09/11, 12:28   #8 (permalink)
buj
Erfahrener Benutzer
Default AW: Samsung "Tough" SDHC cards - non compliant
buj
buj is offline   Reply With Quote
Old 21/05/12, 14:29   #9 (permalink)
Erfahrener Benutzer
roydonian's Avatar
Just to bring this saga up to date – I bought a batch of 4Gb Samsung cards last October just after getting my M9-P and have had virtually no problems with them. I have had only a single instance where a one DNG file was declared unreadable, but the JPEG version of the pic was OK.
I never had any significant problems with Sandisk 2Gb cards in my M8.2, but I have always regarded it as sensible to wait the buffer has emptied before trying to review a photo.
Best regards,
Doug
Old 14/08/13, 13:26   #10 (permalink)
Erfahrener Benutzer
roydonian's Avatar
A further 16 months have gone by, and my Samsung 4Gb cards are still working fine in my M9, with no further image losses.
Many of the postings on this forum reporting SD card problems involve large-capacity cards. I seem to recall reading that cards of 8 Gb and larger use a different electronic configuration, so wonder of this is a factor in some of the problems being reported.
It may be that card sizes have just moved on with passing time, and such sizes are now normal. However, my experience to date has been that a fully-charged battery and an empty 4 Gb card are enough for a day’s shooting with the M9 set to JPEG + DNG.. The only time that I’ve had to change either a battery or a card came when I spent a day in the Forum in Rome.
I’m not a ‘chimper’, so only review a pic if the exposure, framing, or focussing was critical. This keeps life simple, and maximises battery life, but at the cost of losing the occasional image. The worst instance was losing a sequence shot against the light with my Tri-Elmar set to 50 mm. Every image showed massive levels of flare. So that is another instance where I now opt to check the newly-taken image.
Best regards,
Doug
Thank You says
torris (20/08/13)
Old 26/08/13, 23:59   #11 (permalink)
Neuer Benutzer
Philjh's Avatar
Ad
I did some SD card research, based on peoples M9 experiences, before I got my M-E last march.
I use the Samsung 8GB Class10 SDHC card with black metal cover, model MB-SP8GA. I alternate between two cards, never delete pics from card and always format in camera.
I have never had any problems at all. In fact I have bought a small supply of these cards, they are so reliable.
Philjh is offline   Reply With Quote
Reply
Current eBay Ads
Current bid:
1342.92 USD
(21 bids)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
