| Leica M9 Forum The Leica M9 Forum is dedicated to everything around the new Leica M9. |
Leica Products
Leica S2 |
Leica M9 |
Leica M9-P |
Leica MP |
Leica M Lenses |
Leica X1 |
Leica D-Lux 5 |
Leica V-Lux 2 |
| Amazon | eBay | B+H | Amazon | eBay | B+H | Amazon | eBay | B+H | Amazon | eBay | B+H | Amazon | eBay | B+H | Amazon | eBay | B+H | Amazon | eBay | B+H | Amazon | eBay | B+H |
#1 (permalink) |
Erfahrener Benutzer
1) Mine froze this weekend, a feat I managed only once in over ten thousand frames over three or four M8s. I was shooting in single shot mode onto a brand new Extreme III card (which seems pretty slow, especially to format) and I was shooting at a rate just fast enough to keep the buffer light blinking. After maybe five frames and with the buffer light still blinking I pressed Play, then began to zoom in to check focus, and the camera totally froze at 'large pixel display' stage before the zoomed image had resolved to full resolution. It was a remove the battery job, but I didn't lose any shots.
2) When you format the memory card, because it takes so long, it's tempting to put the camera down and let it get on with it. Don't. It won't Auto Off and half an hour later you'll notice the screen still on and the battery draining merrily away. 3) I do get the odd bit of stripe. An example is posted below. 4) There is definitely something going on with some of my glass that worked perfectly at all distances on my last M8.2 - for example, if I focus my 28 cron on anything about fifteen feet away and use F4 or less, I am very likely to get the subject very slightly less in focus than the background. Enough to more than lose the advantage of there being no AA filter but not enough to ruin the shot. I have tested this and all glass at close distances of around 1.5 metres and they are all impeccable at that distance and at all apertures. 5) My CV glass will have to go. The 15 is nicely sharp to the edges but has colour drifts that will get boring to fight with and the 35 skopar, a lens I love, is not sharp to the edges unless you stop it down to its diffraction limits. I am about 450 shots in and don't regret the decision. There are some teething issues to sort out, higher ISO is not such an improvement as I hoped (I'm afraid I personally don't buy the argument that it's significantly better if you print to the same size as you did with the M8 - I wanted more pixels so I could print bigger) and mine is one of those with current firmware at delivery but which does not record the camera serial number in EXIF. I have already decided that if that is a return to base job, I will simply return the camera for a refund and wait until things improve. But otherwise, once I've sorted out these issues above, I should be set! Here's a stripey one: 50 lux, 1/125th at ISO 1600 indoors in a room that allows a lot of light in but still has plenty of shady areas. The shot is a 100% crop but in the original it is just to the right of the right-hand vertical 'thirds' division and seems to run only 2/3rds of the way down from the top BUT the subject matter makes it hard to judge that accurately... Tim L1000309.jpg EDIT: Here's the full frame for reference, makes it easier to see... L1000309-Edit.jpg
__________________
http://tashley1.zenfolio.com/ Last edited by tashley; 15/09/09 at 12:58. |
Current price: 28900 USD
Auction ends: 2012-05-20 11:06:33
Current price: 17400 USD
Auction ends: 2012-06-13 11:04:42
#2 (permalink) |
Moderator
Interesting, Tim, it sounds like the camera is trying to do too much processing at the same time, so it is probably a matter of tuning the firmware. Early days, I would say. As for the high ISO stuff, I find it hard to reconcile you result with the images Riccis posted. Could you elaborate?
#3 (permalink) | |
Erfahrener Benutzer
Quote:
But you can print bigger (at a given ISO) with the M9 than with the M8. No matter what print size you choose the noise will be less with the new camera. Thanks for the report. Cheers, Sean |
#4 (permalink) | |
Erfahrener Benutzer
Quote:
It's not a huge issue but I had slightly higher hopes is all, and were I shooting flash free under tungsten at the moment I would probably take the 5DII and 50 R Cron combo and just hope the banding stayed away! T
__________________
http://tashley1.zenfolio.com/ |
#5 (permalink) | |
Erfahrener Benutzer
Quote:
BYTW Sean I was going to add to The Long Thread but thought it was just toooo long; but I did want to say that anyone who thinks your reviews can be bought by manufacturers has let their cynicism about the world suffocate their common sense. It's also rather insulting to the intelligence of those of us who pay for your reviews because we believe that they will be detailed, thoughtful and fully objective. As indeed they are. Best T
__________________
Current price: 7900 USD
Auction ends: 2012-05-18 09:02:44
Current price: 2199 USD
Auction ends: 2012-06-01 06:06:01
#7 (permalink) | |
Erfahrener Benutzer
Quote:
Cheers, Sean |
#8 (permalink) |
Erfahrener Benutzer
Tim - agreed that formatting seems to take longer (and the over-right option takes forever) - and I'm only working with 2GB Sandisk Extreme cards at the moment - ordered a batch of 4s and 8s which should arrive soon. No other freezing or striping on anything I've seen yet.
__________________
Chris Tribble www.ctribble.co.uk // http://ctribble.blogspot.com // http://www.flickr.com/photos/ctribble/ |
#9 (permalink) | |
Erfahrener Benutzer
Quote:
#10 (permalink) | |
Neuer Benutzer
Tim,
Quote:
Btw, I bought the M9 at the Leica Shop in Solms and I updated the firmware to the current version by myself. Helmut |
#11 (permalink) |
Erfahrener Benutzer
Ah - there's that too. My sn's xxxxxxx ...
__________________
#12 (permalink) |
Erfahrener Benutzer
Tim sorry to hear of these problems.
I am sure the write times and the format times will come down with newer firmware. They did with the M8 once Leica sorted out problems. I find it best to wait until the red light stops blinking before I do any else with the camera except take another shot. |
#14 (permalink) |
Neuer Benutzer
I wrote earlier about a 8 GB (ADATA) card, that worked in the M8, not in the M9.When I found a card that worked in the M9, it was impossible to delate all pictures: I had to delete them one by one. And the same happened as stated by the OP: the light flashed forever and I could not put the M9 off.
#15 (permalink) | |
Erfahrener Benutzer
Quote:
Maybe it's art. Maybe it's about the homogeneous nature of individuality in a society that manufactures people as if they were products. Maybe not. I leave all interpretation to the viewer.
__________________
#16 (permalink) | |
Erfahrener Benutzer
Quote:
![]() ![]() Actually it was sensor dust.
__________________
Current price: 1287.37 GBP
Auction ends: 2012-05-21 12:02:48
Auction ends: 2012-05-21 12:02:50
#17 (permalink) |
Erfahrener Benutzer
Interesting, that might be a regression - the M8 became much faster at formatting cards with one of the firmware releases - can't recall which one.
__________________
David there are certainly more good cameras in the world than there are good photographers My work on Flickr |
| Bookmarks |
| Current eBay Ads |
Current bid:
3250 USD (0 bids)
Current bid:
2199 USD (6 bids) |
| Thread Tools | |
| Display Modes | |
