Leica Forum Blog News
» New Forum Project – The Mirrorless Forum |
| Leica M9 Forum The Leica M9 Forum is dedicated to everything around the new Leica M9. |
#1 (permalink) |
Erfahrener Benutzer
All,
The only discussion I've seen on the content of Sean Reid's M9 review is about his high ISO results. But in the "Speed" section was a very troubling remark that, surprisingly, has generated no discussion. Sean, far from being a Leica shill as some have claimed, reports that when firing in continuous mode, the M9 sometimes froze. On some occasions, he reports, these crashes caused the camera to lose some of the pictures that it had supposedly taken. In either case, the only way to get the camera working again was to remove and reinsert the battery. This same problem with the M8 was frequently reported on the LUF. I often experienced it myself with my M8s when taking many pictures in rapid succession (I would do this in single shot mode, not continuous, mode). Leica certainly knew about this problem, and they supposedly fixed it for me a few times although the "fixes" never worked. It would be surprising and disappointing if the M9 has the exact same bug. Has anyone else experienced this? Has anybody heard anything about a response from Leica since Sean's review mentioned this? Last edited by dalippe; 15.09.2009 at 03:06. Reason: People don't get irony |
#3 (permalink) | |
Erfahrener Benutzer
Quote:
I've never seen this behavior in normal use of the camera but for the RAW buffer testing, I was continually hammering the camera (continuous mode with repeated bursts to get timings) and I did run into this problem. I've reported it to Leica. Cheers, Sean Last edited by sean_reid; 15.09.2009 at 03:01. |
#4 (permalink) | |
Erfahrener Benutzer
Quote:
![]() Regards,
__________________
"Live as though you were going to die tomorrow and learn as though you were going to live forever." ~ Mahatma Gandhi |
#5 (permalink) |
Erfahrener Benutzer
I was hoping this was going to be resolved in the M9--I can handle a slower (compared to dslr's) camera, but not one that is unreliable in this respect
![]() Didn't Mark Norton discover in the M8 that this problem was due to a flaw in the off-the-shelf chip used? Would be a shame if Leica used the same old, knowing it should be replaced...... andy |
#7 (permalink) | |
Erfahrener Benutzer
Quote:
To the OP's comment. The M9 has not been reworked from the ground up. It does share many of the same parts and flaws as the M8 did and still does. In the video of the assembly on the M9 when a tech was going to clean the sensor, @ 14m 40s +/-, when she first tried to enter Sensor Cleaning Mode the camera froze making her take out the battery and reinsert it. This same thing has happen to every M8 and M8.2 ever made at one time or another. |
#9 (permalink) |
Erfahrener Benutzer
I've edited my first post to avoid any further confusion. Rather than rely on readers to catch irony, I have been explicit about the fact that I think this fact provides evidence against the claim that Sean is a Leica shill.
#10 (permalink) |
Erfahrener Benutzer
This has been the least used feature in my M8 and I suspect it will remain that way for the M9 if I buy it. If you want the machine-gun mode, the Leica-M system is clearly the wrong place to be. First of all, there's no high speed continuous AF, why would you even contemplate continuous shooting using your M? Now, if your subject even moved a bit in between frames, they will be out of focus. Are you continuously focusing it manually? Then, how do you keep your camera still when focusing? OK, you're shooting static subjects? Then, why do you need to shoot in continuous mode? Leica can take that feature out and I will not miss a thing. |
#11 (permalink) |
Erfahrener Benutzer
Sorry, Arthur, to disagree with you entirely:
--Using the Continuous mode works well to prevent camera movement at slow shutter speeds. At 1/30 & below, I always shoot 2-3 frames. --It's great when a subject is moving through a scene. You can't pick the decisive moment when the next exposure couldn't be the better one. --In portraits, or any time people are talking, I always use C mode to get a vsriety expressions & avoid mouth distortions. Often a person relaxes after hearing the first click & then the expression is more spontaneous. The only real disadvantage is that you can't use Continuous & Discreet modes simultaneously. Kirk |
#12 (permalink) | |
Erfahrener Benutzer
I'm sorry, but how are you in any position to tell me how I should be shooting with cameras that I pay for?
I shoot commercial fashion work, I like Leica M cameras. The Leica M8 and M9 have incorporated the continuous drive function, therefore it should WORK, read NOT randomly crash/freezeup the camera. Leica M film cameras have had the long tradition and reputation of being the rock solid go-to camera when all others fail. If Leica wants to continue that tradition in the digital age, this problem isn't even a question--it NEEDS to be resolved. What if you were a war photographer, in a dangerous situation trying shoot and all of a sudden your camera freezes up? Silly. ps. the M8 (and supposedly M9) freezeup problem is not just when shooting in Continuos mode, it also happens in Single shot mode if you shoot in rapid frame succession. my two cents. Quote:
#13 (permalink) | |
Erfahrener Benutzer
Quote:
I use form time to time. Mainly when I'm shooting at lower shutter speeds but I have also used it with the camera mounted on a tripod doing pano shots moving the ball head as the camera is firing. |
#14 (permalink) |
Erfahrener Benutzer
Sure ... it's your camera, you are free to do whatever you want. At 2-3 frames per sec, it still sounded a little silly to use it to capture the decisive moment versus 8 frames per sec on a D3.
I agree, the M9 should not fail at $7K. |
#15 (permalink) | |
Erfahrener Benutzer
Quote:
1. You weren't considerate enough to actually read my post. I said this happens to me in single shot mode, when taking many frames in quick succession. 2. Even if it only happened in continuous mode, that wouldn't be OK. It isn't OK for a camera to crash because a control is set to a provided value, period. I would make the apparently controversial claim that this is true even if arthury doesn't value that control. 3. Your post expresses a limited view of what an M camera can do. Times when it makes sense to take many shots in quick succession include (but are no doubt not limited to): o Zone focused o A toddler in a high chair, given a setting that has a foot or two of DOF. They make endless wonderful expressions and it is worth trying to capture as many as possible. 4. Your unsolicited advice was rather presumptuous. I've shot some 40,000 exposures with my M8 and have a pretty good sense of when the M system is right for me. EDIT: arthury, you posted your reply while I was typing this. Thank you. Last edited by dalippe; 15.09.2009 at 05:10. |
#16 (permalink) |
Erfahrener Benutzer
If this is a genuine issue, why should Leica fix it if people are willing to shell out $7000.00 for the M9 "as is"?
__________________
Wilfredo www.BenitezRivera.com "Everything that we see is a shadow cast by that which we do not see." - Martin Luther King, Jr. |
#17 (permalink) |
Erfahrener Benutzer
While this forum is a very useful resource with a wealth of knowledge, it is unbelievably frustrating having to sift through the countless useless posts trying to get constructive answers.....
Wilfredo, to answer your question, the M9 to me has more improvements over the M8 to justify an upgrade even IF they didn't resolve the freezeup issue. And regardless, Leica should resolve this, when the camera freezes, you loose all frames in the buffer, that's like having a film Leica with light leaks. Last edited by 35mmSummicron; 15.09.2009 at 05:32. |
#19 (permalink) |
Erfahrener Benutzer
Do tell Sean!
I've developed a pretty quick technique on my M8 classic of removing the baseplate, battery, reinserting, deleting the last frame on the card (as its usually corrupt from the freezeup) and going back to shooting..... Any series of frames leading to the crash, I usually consider lost and try to reshoot. |
#20 (permalink) | |
Benutzer
Quote:
Anyone with a M9 can verify? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/leica-m9-forum/98708-piece-bad-news-seans-m9-review.html
| Posted By | For | Type | Date | |
| List of Leica M9 issues & problems | Leica Rumors | This thread | Pingback | 27.09.2009 04:49 | |
| Leica Rumors | This thread | Refback | 27.09.2009 04:49 | |
