Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M9 Forum
Leica M9 Forum The Leica M9 Forum is dedicated to everything around the new Leica M9.
Register now
Old 12.09.2009, 04:45   #1 (permalink)
Benutzer
Default Read Sean's ISO results and quite disappointed.
Just read Sean's ISO write-up, and well it's disappointing that this is all Leica could come up with. It really does seem to me to be a case of in camera smoothing at higher ISO and at a loss of some detail. I am so disappointed and I think I am now out of the market for an M9. It's just not good enough in this day an age. I so wanted to have a digital RF with good high ISO. Matching the M8 to the M9 could probably be achieved with noise ninja or difine...For sure the full frame is nice but the price!!!! I might just get another M8.. Just my opinion of course.
padraigm is offline   Reply With Quote
Old 12.09.2009, 04:54   #2 (permalink)
Erfahrener Benutzer
Bo_Lorentzen's Avatar
Default Re: Read Sean's ISO results and quite disappointed.
We talking about different cameras.? I was just looking through the 1250 iso shots from Samy's and those faster.. comparing to shadows in these and M8 images. its at least 1 stop better. full frame. Lovely camera.
Bo_Lorentzen is offline   Reply With Quote
Old 12.09.2009, 05:09   #3 (permalink)
Erfahrener Benutzer
adan's Avatar
I haven't read Sean's report, but I suspect if he's seeing some smoothing or processing at ISO 1600 and above, he's likely right. I sense a slight CaNikoness to the 1600-2500 range (in my so-far limited 4 gigs of shooting). And that's too bad, unless Leica produces a firmware upgrade to control noise smoothing by the users.
OTOH, the big sensor means I can shoot my 21 f/2.8 instead of the C/V 15mm f/4.5 - so I can skip ISO 1600 and use ISO 400 in the same light (or spring for the 21 Summilux and shoot ISO 160).
Also remember that at the same print size (with more, smaller pixels from the M9) the noise speckles will be 1.33x smaller.
adan is offline   Reply With Quote
Old 12.09.2009, 05:11   #4 (permalink)
Erfahrener Benutzer
Yes, about one stop better in prints. I think people had hopes of Canon/Nikon level high ISO performance but even a gain of one stop works well for me.
Cheers,
Sean
__________________
Sean Reid
http://www.reidreviews.com
sean_reid is offline   Reply With Quote
Old 12.09.2009, 05:12   #5 (permalink)
Erfahrener Benutzer
There's careful discussion about how this relates to print size and yes that is important.
Cheers,
Sean
__________________
Sean Reid
Old 12.09.2009, 05:34   #6 (permalink)
Erfahrener Benutzer
adan's Avatar
Hi, Sean. So are we going to have to relive the whole Digilux 2 thing? (Shoot 2 stops under to dodge the noise suppression, and then push it ourselves?). I thought Leica had learned from that.
Old 12.09.2009, 05:40   #7 (permalink)
Erfahrener Benutzer
No, I don't think that is needed at all.
Basically, for a given print size and a given level of noise, the M9 can go a stop faster in ISO than the M8. A stop gain is good even if it doesn't make the M9 a world champ at high ISO.
As for the high ISO smoothing - its not heavy handed at least.
Cheers,
Sean
__________________
Sean Reid
Old 12.09.2009, 05:42   #8 (permalink)
Erfahrener Benutzer
Quote:
No it couldn't match them because one has 18 MP. Check out that last part of the ISO section again.
Cheers,
Sean
__________________
Sean Reid
Old 12.09.2009, 05:48   #9 (permalink)
Neuer Benutzer
Andy,
thanks for the reply in the other thread.
You wrote just now:
"OTOH, the big sensor means I can shoot my 21 f/2.8 instead of the C/V 15mm f/4.5 - so I can skip ISO 1600 and use ISO 400 in the same light (or spring for the 21 Summilux and shoot ISO 160)."
Maybe there is more to IQ improvement you mentioned due to wide lenses? Maybe also the sensor? JL
jl4069 is offline   Reply With Quote
Old 12.09.2009, 05:59   #10 (permalink)
Erfahrener Benutzer
Although the M9 will have a noise advantage in prints, I don't think that is quite the reason. Noisy areas of the photograph will be shrunken, but there will be more of them. I think the right technical explanation is what Sean said: down-sampling, which is just averaging, increases signal to noise. When you average N pixels, noise should go down by sqrt(N) while signal remains constant.
On the other hand, I believe that Leica's choice isn't as good for noise as simply having fewer pixels to begin with on the full size sensor. My understanding is that the relevant noise is read noise and doesn't grow with pixel size (dark current, on the other hand, is proportional to pixel area so larger pixels do nothing to help with signal-to-noise when dark current is the limiting factor).
To take a simple example, if you start with twice as many pixels and then down-sample by making every output pixel the average of two input pixels, you increase signal to noise by a factor of only sqrt(2) because signal stays the same and noise goes down by sqrt(2). But if you start with half as many pixels, giving each pixel twice the area, then you increase signal to noise by a full factor of 2 since signal doubles and noise is constant. Of course actual down-sampling algorithms aren't this simple, but I don't think that changes the basic insight.
I'm disappointed with Leica's choice. I may not be representative, but I don't need more than 10 megapixels. The largest prints I've ever made are 20x30 and those are rare. But I often shoot under dim, tungsten light and love the freedom my D3 gives me to skip the flash and still choose my DOF. When I can get away with it, I prefer to shoot my M8 and was hoping the M9 would more substantially increase the fraction of the time I can get away with shooting the Leica instead of the Nikon.
dalippe is offline   Reply With Quote
Old 12.09.2009, 06:03   #11 (permalink)
Erfahrener Benutzer
To take a simple example, if you start with twice as many pixels and then down-sample by making every output pixel the average of two input pixels, you increase signal to noise by a factor of sqrt(2) because signal stays the same and noise goes down by sqrt(2). But if you start with half as many pixels, giving each pixel twice the area, then you increase signal to noise by a factor of 2 since signal doubles and noise is constant. Of course actual down-sampling algorithms aren't this simple, but I don't think that changes the basic insight.
I'm sure a lot of us would have loved truly clean ISO 2500 but you're still gaining a stop which is worthwhile certainly.
We agree on the down-sampling thing and its obvious in the test pics when they're matched in pixel dimensions.
Cheers,
Sean
__________________
Sean Reid
Old 12.09.2009, 06:04   #12 (permalink)
Erfahrener Benutzer
People sure are funny. Leica essentially do the impossible (make a FF digital M) and give an extra stop to a stop and half iso but still not good enough. But then again it doesn't fit in my pocket, doesn't focus to 6", doesn't zoom from 18-300mm, and so on.
Get real people! Learn how to take a photograph and the noise won't be a problem. Go shoot some high speed color neg or TMAX 3200 under low light and then come back and talk about noise. Or better yet lug around a D3 everywhere (and I'm a D3 owner).
There really is no single camera that will "do it all." And thank heavens for that.
__________________
http://www.charlespeterson.net
charlesphoto99 is offline   Reply With Quote
Old 12.09.2009, 06:15   #13 (permalink)
Erfahrener Benutzer
That really isn't very fair. Given the fact that Leica solved the FF problem, there was a simple design decision they could have made to increase the high ISO abilities of the camera so that we wouldn't have had to lug our D3's around as often. Had they made that decision, then they would have been giving up something else (the ability to make large, detailed prints). What' s wrong, on a discussion forum, with users discussing which trade-off works better for them?
Old 12.09.2009, 06:17   #14 (permalink)
Erfahrener Benutzer
Cheers,
Sean
Yes, I saw that in your review update. Been waiting for it all day
Old 12.09.2009, 06:20   #15 (permalink)
Erfahrener Benutzer
That definitely is the other side of the coin. Consider my friend Tod who will now do work with the M9 that he used to do with a 6 x 9 Fuji. Big prints - serious work for galleries and museums. 18 MP at lower ISO levels is just what he needed.
And of course with down-sampling one gets a much cleaner 10 MP file. So maybe it was good choice in the end...
Cheers,
Sean
__________________
Sean Reid
Old 12.09.2009, 06:20   #16 (permalink)
Erfahrener Benutzer
What a coincidence, I've been waiting all day to get that off my to do list.
Cheers,
Sean
__________________
Sean Reid
Old 12.09.2009, 06:29   #17 (permalink)
Erfahrener Benutzer
Sean, in that picture that immediately follows the noise section, under Wedding, of the woman on the phone next to the wall, what is going on with the wall to her left-is there a ridge on the wall going horizontally? or does it actually extend into the black on the left like I think it does?
could be weird compression artifact? or I won't say it...
robertwright is offline   Reply With Quote
Old 12.09.2009, 06:35   #18 (permalink)
Erfahrener Benutzer
It seems like banding to me and that's how I describe it above the picture. Its one of just two high ISO pics I've found like that. Both were consecutive and Leica is clued into this (but we can't replicate it yet). Thousands of other pics at same ISO look fine in that respect.
I included the picture because I like it and it also nicely connects the noise section to the wedding section. It was published out of context on TOP (Mike Johnston just liked the pic) and now there's a little discussion going there about "discovering" the banding. That's the problem when people freely comment on a review they've never read. Kind of funny that it is a banding *illustration* in the review.
Cheers,
Sean
__________________
Sean Reid
Old 12.09.2009, 06:38   #19 (permalink)
Erfahrener Benutzer
Okay, then maybe Leica should offer the M9 with either a CCD sensor or a CMOS? No problem discussing, but it really seems a damned if you do, damned if you don't situation for Leica. As far as I can figure the only sensor that works for the severe angle of light in an M RF is a Kodak designed CCD. A CCD sensor just will not allow for super high iso's. So why all the moaning then? It is what it is and either you spring for it (I most certainly am) or you don't. The 1600 iso I tested on the M9 is great. Maybe not quite as good as the D3 but good enough for real world situations.
I'm not saying the camera is perfect - the AWB is still over the place and where's the goddamn pc socket? And they didn't have to put sapphire glass on the lcd - how about some good ol' tempered glass like Nikon instead of plastic? Yes, Leica do seemingly live in their own stratosphere at times, but damn if they aren't wonderful tools to make photographs with.
__________________
Old 12.09.2009, 06:52   #20 (permalink)
Erfahrener Benutzer
Cheers,
Sean
goodness I read it twice and missed it both times.
"discover' is a funny word. I could show you pics where I 'discovered' banding on my 5DII but who cares.
If I were to make one comment it is that unless you know for a fact that Leica is doing in camera smoothing on ISO 1250 and 2500, why write that you think that they are?
It is conjecture.
We are awash in opinion on the net (like mine!) but we really need core reporting. Basic factual reporting. Unfortunately the kind that requires phone calls and people who know saying so. Stuff like that. I love your reviews but why guess at something? Unless Leica told you in the junket, we are doing some hocus pocus at high iso. The pixel pitch may be the same but everything else about the sensor is different, the microlenses, the filter thickness. So they will not image the same way. Also the signal processing is different.
I'm sure there is a reason for what you are seeing, just we don't really know what that is. If Leica says 'secret sauce' to guard their RD fine, but at least it is from the horses you know what
I also would like a really thorough explanation of the sources and causes of image defects like noise, banding, hot pixels etc. Just for the geek-factor of it. What do engineers have to content with in terms of things like RF interference, heat, signal path length, quantization whatevers, I think it would be enlightening.
done now.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/leica-m9-forum/98276-read-seans-iso-results-quite-disappointed.html
Posted By For Type Date
Leica Rumors - Part 2 This thread Refback 08.10.2009 07:03
List of Leica M9 issues & problems | Leica Rumors This thread Pingback 27.09.2009 04:49
Leica Rumors This thread Refback 27.09.2009 04:49
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.1
