Einst_Stein Posted June 29, 2014 Share #1 Posted June 29, 2014 Advertisement (gone after registration) I've never noticed this, but today I find my M9 frame line will move when I turn the lens focusing ring. When focusing moves closer, the frame moves towards up/left. Focusing farther, the frame moves towards bottom right. Is this normal? or my M9 has problem? Quote Link to post Share on other sites More sharing options...
Advertisement Posted June 29, 2014 Posted June 29, 2014 Hi Einst_Stein, Take a look here Turning focusing ring moves M9 frame ?. I'm sure you'll find what you were looking for!
adan Posted June 29, 2014 Share #2 Posted June 29, 2014 Movement is normal - it corrects for parallax (the fact that your eye and the lens are seeing the world from different locations - and more so at close distances). The movement as you describe it is wrong, but may be your terminology. The lines should be moving down and to the right as you focus CLOSER (i.e. - move the lens out away from the camera). 2 Quote Link to post Share on other sites More sharing options...
erl Posted June 29, 2014 Share #3 Posted June 29, 2014 I've never noticed this, but today I find my M9 frame line will move when I turn the lens focusing ring. When focusing moves closer, the frame moves towards up/left. Focusing farther, the frame moves towards bottom right. Is this normal? or my M9 has problem? Adan is right, but it also depends on what you have been drinking! Quote Link to post Share on other sites More sharing options...
pop Posted June 29, 2014 Share #4 Posted June 29, 2014 It' a feature. Quote Link to post Share on other sites More sharing options...
Einst_Stein Posted June 29, 2014 Author Share #5 Posted June 29, 2014 Movement is normal - it corrects for parallax (the fact that your eye and the lens are seeing the world from different locations - and more so at close distances). The movement as you describe it is wrong, but may be your terminology. The lines should be moving down and to the right as you focus CLOSER (i.e. - move the lens out away from the camera). Well, I am on the other end of the globe. 2 Quote Link to post Share on other sites More sharing options...
Jeff S Posted June 29, 2014 Share #6 Posted June 29, 2014 FAQ Jeff Quote Link to post Share on other sites More sharing options...
erl Posted June 30, 2014 Share #7 Posted June 30, 2014 Advertisement (gone after registration) Well, I am on the other end of the globe. Well in that case, like me, you need to also hold the camera upside down! 2 Quote Link to post Share on other sites More sharing options...
jaapv Posted July 1, 2014 Share #8 Posted July 1, 2014 Not if you stand on your head. Quote Link to post Share on other sites More sharing options...
erl Posted July 1, 2014 Share #9 Posted July 1, 2014 Down here we stand on the ground, it just happens to be above our heads. 1 Quote Link to post Share on other sites More sharing options...
aldash Posted July 4, 2014 Share #10 Posted July 4, 2014 The Australian/NZ (and Antarctic) models M9 are built upside down for people who walk on their hands and use the camera with their feet. Northerners buying cameras from down under need only rotate the camera 180 degrees before using it. 1 Quote Link to post Share on other sites More sharing options...
farnz Posted July 4, 2014 Share #11 Posted July 4, 2014 Down here we stand on the ground, it just happens to be above our heads. I can never figure out how you people down there don't just fall off? Pete. Quote Link to post Share on other sites More sharing options...
erl Posted July 5, 2014 Share #12 Posted July 5, 2014 (edited) I can never figure out how you people down there don't just fall off? Pete. We just hold on upside-down with our feet. On his last visit even David Atteborough though we were all a little Batty! Edited July 5, 2014 by erl 1 Quote Link to post Share on other sites More sharing options...
