LotharZhou Posted April 27, 2013 Share #1 Posted April 27, 2013 Advertisement (gone after registration) My 8 months old M9P is showing a red pixel in the center of almost every under exposed photos, not obvious unless heavily under exposed at all. Interestingly I try to shot ISO 160 to 1250 with the lens cap on, can't see that pixel at all. I have contact Mayfair and hesitating to send to Leica for the fix, a few advice will be appreciated indeed, should I send to Solms or not? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/203528-should-i-worry-about-this-pixel-or-not/?do=findComment&comment=2308695'>More sharing options...
Advertisement Posted April 27, 2013 Posted April 27, 2013 Hi LotharZhou, Take a look here Should I worry about this pixel or not?. I'm sure you'll find what you were looking for!
TomB_tx Posted April 27, 2013 Share #2 Posted April 27, 2013 I have a similar red pixel on my M9 that shows up on the LCD when I zoom in. However, I always use LR4 to import and convert images, and it disappears in LR, even before exporting to jpg. I assume LR4 eliminates such hot pixels, so I chose not to worry about it. Quote Link to post Share on other sites More sharing options...
k-hawinkler Posted April 27, 2013 Share #3 Posted April 27, 2013 With the lens cap on the dead pixel gets subtracted out in the second part of the exposure step. I don't worry about isolated dead pixels as they easily can be corrected in post. If it bothered you Leica can map it out for you. Quote Link to post Share on other sites More sharing options...
LotharZhou Posted April 27, 2013 Author Share #4 Posted April 27, 2013 Thanks a lot, it's annoying me because it's in the dead center of the frame. And it appears and disappears unpredictable. I have a similar red pixel on my M9 that shows up on the LCD when I zoom in. However, I always use LR4 to import and convert images, and it disappears in LR, even before exporting to jpg. I assume LR4 eliminates such hot pixels, so I chose not to worry about it. Quote Link to post Share on other sites More sharing options...
LotharZhou Posted April 27, 2013 Author Share #5 Posted April 27, 2013 Thanks, it could be fixed easily, my only concern is that the dead pixel numbers might increase over the time? As my camera is still under warranty. With the lens cap on the dead pixel gets subtracted out in the second part of the exposure step.I don't worry about isolated dead pixels as they easily can be corrected in post. If it bothered you Leica can map it out for you. Quote Link to post Share on other sites More sharing options...
k-hawinkler Posted April 27, 2013 Share #6 Posted April 27, 2013 They will increase over time - as with any other camera. It's not really specific to your camera. As the camera is still under warranty have it mapped out. Quote Link to post Share on other sites More sharing options...
Guest Duane Pandorf Posted April 27, 2013 Share #7 Posted April 27, 2013 Advertisement (gone after registration) Thanks, it could be fixed easily, my only concern is that the dead pixel numbers might increase over the time? As my camera is still under warranty. You may want to see what my experience was: Leica M-E Dead Pixel issue Remember if you plan on shooting JPG out of camera that pixel error will be retained in the in camera JPG. LR would quickly fix the dead pixel in the DNG files as they were imported but the vertical column issue was a serious cause of alarm for me. The US Leica repair facility in NJ repaired the CCD by replacing it and the sensor board along with a rangefinder adjustment. Quote Link to post Share on other sites More sharing options...
LotharZhou Posted April 27, 2013 Author Share #8 Posted April 27, 2013 Thanks Duane, I have already contacted Both Leica Mayfair and Solms and will send in my camera, hope the turn around won't take too long. You may want to see what my experience was: Leica M-E Dead Pixel issue Remember if you plan on shooting JPG out of camera that pixel error will be retained in the in camera JPG. LR would quickly fix the dead pixel in the DNG files as they were imported but the vertical column issue was a serious cause of alarm for me. The US Leica repair facility in NJ repaired the CCD by replacing it and the sensor board along with a rangefinder adjustment. Quote Link to post Share on other sites More sharing options...
