Leica User Forum
Go Back   Leica User Forum > International User Forum > Leica Products > Leica M / M-E / M9 / Monochrom
Leica M / M-E / M9 / Monochrom The Leica M9 Forum is dedicated to everything around the new LEICA M, M-E, M9, M9-P and LEICA M MONOCHROM.
 Leica Products
Leica M silver Leica M-E Leica M Monochrom Leica S LEICA D-LUX 6 LEICA X2
Leica M
» eBay | Adorama | B+H | Dale
Leica M-E
Leica M Monochrom
Leica S
» eBay | B+H | Dale
LEICA D-LUX 6
LEICA X2
Amazon | » eBay | Adorama | B+H | Dale
Old 11/02/13, 22:10   #1 (permalink)
Erfahrener Benutzer
Stealth3kpl's Avatar
Default Sensor Cracks
Did they ever get to the bottom of why some sensors cracked on the M9. Did they make any adjustment to the design to stop it happening and is it likely that no such issue will arise with the M?
Pete
Stealth3kpl is offline   Reply With Quote
Old 12/02/13, 07:19   #2 (permalink)
Erfahrener Benutzer
Default Re: Sensor Cracks
The new sensor is entirely different, designed by a different company and also made by a third party. It may have problems all its own but just because Kodak (as was) had the problem, there's no reason to believe the new sensor will have the same.
__________________
Mark
marknorton is offline   Reply With Quote
Thank You says
Stealth3kpl (12/02/13)
Old 12/02/13, 07:43   #3 (permalink)
Erfahrener Benutzer
Quote:
I don't think so (at least "they" being Leica) – my slightly less than one year old M9P cracked recently. As Mark states, this is not relevant to the new M which uses an entirely new sensor.
__________________
Ian Watts
ianwatts.co.uk // flickr
wattsy is offline   Reply With Quote
Thank You says
Old 12/02/13, 15:52   #4 (permalink)
Sponsoring Member
JCharlton's Avatar
Wait... I thought the glass sensor cover is what has been cracking on the M's, not the actual sensor itself.
__________________
M9-P / 35 Summicron V4 / 35 Summilux FLE / 50 Summilux Pre-ASPH /
JCharlton is offline   Reply With Quote
Old 12/02/13, 16:08   #5 (permalink)
mjh
Erfahrener Benutzer
mjh's Avatar
Default AW: Re: Sensor Cracks
Quote:
When talking about ‘the sensor’ one usually refers to the whole unit, i.e. not just the silicon chip, but also the Bayer filters, microlenses, the cover glass etc..
Whether (as we may presume) Truesense Imaging, Inc. in the US has learned to avoid the cracking has no bearing on the new sensor that was designed by CMOSIS in Belgium and is manufactured by STMicroelectronics in France.
__________________
Michael J. Hußmann
mjh is offline   Reply With Quote
Thank You say...
JCharlton (12/02/13), Stealth3kpl (14/02/13)
Old 12/02/13, 16:24   #6 (permalink)
Sponsoring Member
JCharlton's Avatar
Daumen hoch Re: Sensor Cracks
Thank you Michael. I was unaware of the many layers above the silicon chip.
__________________
Old 12/02/13, 23:32   #7 (permalink)
Erfahrener Benutzer
earleygallery's Avatar
I recall some mention being made of the bonding process for sensor to glass. Clearly there is some undue stress being applied to the glass causing it to crack in some cases.
I'm not sure that it's been fixed as such but Leica do acknowledge the problem.
__________________
Regards,
James
croydonconfidential.blogspot.com
earleygallery is online now   Reply With Quote
Old 13/03/13, 18:21   #8 (permalink)
Erfahrener Benutzer
Does anybody with a cracked sensor use a collapsible Elmar lens?
jdlaing is offline   Reply With Quote
Old 13/03/13, 21:00   #9 (permalink)
Erfahrener Benutzer
Quote:
What about the Leica Monochrom, it does use a sensor similar to the one in the M9 doesn't it? If speculating, could sensor cracking issues arise with the Monochrom as well?
I'm growing a bit interested in the Monochrom, but would hate to end up in a situation where the sensor cracks +2 years from now, and no replacement sensor being available.
Best,
Richard
__________________
Best regards,
Richard Fossum
Richard.no is offline   Reply With Quote
Old 14/03/13, 04:30   #10 (permalink)
Erfahrener Benutzer
Yes, it's a similar sensor which goes through the same manufacturing processes so the same changes which were made to stop the M9 sensor failing will apply to the Monochrom as well.
__________________
Mark
Old 14/03/13, 17:32   #11 (permalink)
Erfahrener Benutzer
Thanks, Mark.
I tried searching both the forum and in general for information on changes that might have been made to the process - but have not found any. Can you point to a source for this, or is this something only a few knows of?
I don't know anything about the construction of these sensors, but I can believe it would be possible to maybe introduce a slightly thicker cover glass on the MM, since it has no bayer filter?
Truesense seems to have removed the M9 sensor (and the MM) from their product line, so I think it would be a fair guess that any cracking issue with the MM CCD, would become disasterous, unless Leica chose to stack up with loads sensors "just in case" (probably not). So either you're right and they have eliminated the problem, or they chose to take the risk and hope for the best.
__________________
Best regards,
Richard Fossum
Old 14/03/13, 17:52   #12 (permalink)
Erfahrener Benutzer
Quote:
Leica certainly haven't chosen to stack up with loads of sensors because they have currently run out of the M9 ones. I think we can safely assume that Truesense are still making the sensors or Leica would have a very serious problem indeed.
__________________
Ian Watts
Old 14/03/13, 17:56   #13 (permalink)
Benutzer
Quote:
I wouldnt assume anything sorry but I am a bit of a pessimist but I am interested if any MM sensors have cracked?
nicks500 is offline   Reply With Quote
Old 14/03/13, 18:15   #14 (permalink)
Erfahrener Benutzer
I think it's a reasonable assumption or they will have a bit of a problem explaining to me why they can't replace the cracked sensor in my 1 year old camera.
__________________
Ian Watts
Old 14/03/13, 19:10   #15 (permalink)
Sponsoring Member
Quote:
Yes I use collapsible lenses. There is no correlation at all between the two.
Steve
__________________
"The greater the artist, the greater the doubt. Perfect confidence is given to the less talented as a consolation prize." - Robert Hughes, art critic.
http://www.flickr.com/photos/steve_barnett/
250swb is online now   Reply With Quote
Old 14/03/13, 20:38   #16 (permalink)
Erfahrener Benutzer
Quote:
Steve
Im not suggesting the lens bumping anything.
I'm thinking of something else happening.
Old 14/03/13, 21:57   #17 (permalink)
Erfahrener Benutzer
Bill Wendlandt's Avatar
I may be wrong but I do not recall any reported cracked sensors on the MM. There was an issue that was deemed sensor related I believe concerning high ISO response.
__________________
Bill
http://photobilly.zenfolio.com/
Bill Wendlandt is offline   Reply With Quote
Old 15/03/13, 09:56   #18 (permalink)
Benutzer
Quote:
Well thats good because I hope to give my Leica to my cat when I die
Old 15/03/13, 13:18   #19 (permalink)
Erfahrener Benutzer
Quote:
I would not leave mine to my cat, she would have it on ebay within the hour to buy more food.
__________________
Bill
Old 15/03/13, 14:59   #20 (permalink)
Erfahrener Benutzer
Just an update but Truesense must have found a few sensors at the back of a drawer because Leica have apparently been able to replace my cracked sensor this week.
__________________
Ian Watts
Thank You says
Peter H (15/03/13)
Reply
Bookmarks
Current eBay Ads
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
