Leica User Forum
Go Back   Leica User Forum > International User Forum > Leica Products > Leica M / M-E / M9 / Monochrom
Leica M / M-E / M9 / Monochrom The Leica M9 Forum is dedicated to everything around the new LEICA M, M-E, M9, M9-P and LEICA M MONOCHROM.
Old 05/03/12, 19:34   #1 (permalink)
Erfahrener Benutzer
Lindolfi's Avatar
Default M9 metering pattern
Ad
Since I was curious how the M9 metering pattern was distributed over the film plane, I decided to measure it with 216 white blocks against a black background, together filling the focal plane. The blocks were arranged in an 18x12 matrix. Each time the meter reading was noted. Also a fully white and a fully black surface was measured. It appeared that the fully white surface had the same reading as the sum of the separate readings of all blocks together. The data were slightly smoothed and plotted in the following figure:
http://www.photoplaza.nl/lindolfi/M9sens2.png
You can see that the pattern of gray shutter elements of the M9 comes through slightly, but the total result is very much like that of the Leica M6.
The values are scaled to the maximum reading in the center (1.0), while 0.0 is the lowest readings I got from the fully black image. The value is relative light intensity measured, not stops!
The scaling of the axes of the figure are in mm relative to the center of the focal plane.
For the readings the Macro Elmar 90/4 at f/8 was used, which gives minimal vignetting.
__________________
Bert
PhotoBlog
Lindolfi is offline   Reply With Quote
Thank You say...
01af (05/03/12), Bundestrainer (09/03/12), darylgo (06/03/12), digitalpowershot (05/03/12), dwbell (06/03/12), Gerard (09/03/12), giordano (09/03/12), jaapv (09/03/12), k-hawinkler (05/03/12), kdriceman (05/03/12), Mark Pope (10/03/12), MarkP (06/03/12), pedaes (05/03/12), pico (13/04/14), Ralf (05/03/12), sblitz (06/03/12), StephenPatterson (07/03/12), stussy2k (06/03/12), turner (09/03/12)
Old 05/03/12, 19:49   #2 (permalink)
Erfahrener Benutzer
Default Re: M9 metering pattern
Interesting... It is somewhat larger and rounder than I thought.
Thanks!
__________________
http://www.ecar-photo.com/
Ecar is online now   Reply With Quote
Old 05/03/12, 20:22   #3 (permalink)
Erfahrener Benutzer
Bert--Very nicely done!
A request: Consider trying the same thing with a wide-angle or ultra-wide as well, just as a comparison.
In the M8 introduction, my class was told that the camera "becomes more center-weighted average" with longer focal lengths, and "becomes more like a spot meter" with shorter focal lengths.
Just curious whether the M9 shares this tendency to any great degree.
It's good to see someone with your technical accuracy taking on the meter pattern!
__________________
Best,
Howard
ho_co is offline   Reply With Quote
Thank You say...
k-hawinkler (05/03/12), Lindolfi (06/03/12), mby (05/03/12)
Old 05/03/12, 22:28   #4 (permalink)
Erfahrener Benutzer
chris_tribble's Avatar
My experience with lenses from 18 through to 135 is that this is very much the case. Meter and compose has to central to M exposure practice - especially when the light is complex.
chris_tribble is offline   Reply With Quote
Old 06/03/12, 00:14   #5 (permalink)
Erfahrener Benutzer
Lindolfi's Avatar
That is not the case in the M9: I've tested a 21/2.8 at f/5.6 and it produced a similar result as with the 90/4 at f/8.
So that's nice: you only have to visualize one area during measuring, independent of focal length.
It is obvious that in absolute measurement angle, the longer focal length covers a smaller angle in the outside world than a wide angle lens. So if you want to use your M9 as a 5 degree spotmeter, mount a 135mm lens and nothing shorter.
__________________
Bert
PhotoBlog
Thank You says
ho_co (06/03/12)
Old 06/03/12, 04:36   #6 (permalink)
Erfahrener Benutzer
Daumen hoch Re: M9 metering pattern
Sounds as if Stefan Daniel was right when he said the M9's metering pattern was similar to that of the M6!
Sounds like a noticeable improvement from the M8 as well. The M8 introduction class specified that the spot effect was stronger with wide angles, and reduced with longer focal lengths: just the opposite of your description with the M9. (Speaking of metering pattern, not lens field of view.)
Thanks for your graphic effort, Bert.
Seems to me that a chart like yours would be helpful either in the M9 manual or in the M9 FAQ here on the forum.
__________________
Best,
Howard
Old 06/03/12, 05:22   #7 (permalink)
Erfahrener Benutzer
sblitz's Avatar
interesting how the sensitivity leaks to the bottom and not to the top but seems fairly even left to right. thanks for doing this, very interesting and helpful.
steve
sblitz is offline   Reply With Quote
Old 06/03/12, 09:35   #8 (permalink)
Erfahrener Benutzer
Lindolfi's Avatar
Quote:
steve
Imagine shining a cone-shaped beam of light on a wall at an angle upward. You will get a deformed ellipse that spreads out more above the center of the beam than below. Now if this cone-shaped beam is analogous to the cone-shaped sensitivity of the light meter in the bottom of the M9, it is understandable that if it is aimed at the middle of the focal plane, there is more sensitivity above the middle of the focal plane, than below it.
Since later on the image is rotated to be viewed by us, there is more sensitivity below the middle of the image, but it's extension is limited by the blackness of the top shutter element (bottom of the image).
__________________
Bert
PhotoBlog
Thank You says
pico (13/04/14)
Old 06/03/12, 09:55   #9 (permalink)
Erfahrener Benutzer
People – even people who should know better – automatically think SLR though this is not applicable to any M camera. A M, like any well-regulated English household, has an Upstairs and a Downstairs, and only the most formal connections between them. And metering is done in the Servants' Quarters.
In his Leica M Compendium, Handbook of the Leica M system (Hove, 1994) Jonathan Eastland, who surely knows better when he stops to think, declares (p. 130) that
"The diameter of the measuring field is equal to 2/3 of the short side of the bright-line frame in use. – This is a useful piece of information because in practice it means that the photographer can accurately measure very small areas of the object to be photographed using the preselector lever. – For example, when using wide-angle lenses, the measuring field of the meter appears larger. [ ... ] By flicking the preselector lever to bring up the 90mm bright-line frame, particular areas of the scene can be measured and interpolated."
So the otherwise estimable Mr Eastland thinks that by changing the frames upstairs, he can change the metering angle downstairs, without changing lenses! Good try.
And I do suspect that this kind of thinking lies behind the statement that metering angles are different relative to the picture angle with wide and long lenses. Mr Eastland I presume cut his teeth on SLR cameras with TTL metering (he mentions Nikon). Today's amateur photographers, and future pros, cut their teeth on cell phones, holding their humonguous DSLR cameras with long zooms in front of them on outstretched arms. I wonder what other strange behaviours this will lead to.
Anyone who launches a DSLR that you can make phone calls from, has a winner.
LB
lars_bergquist is offline   Reply With Quote
Old 06/03/12, 10:51   #10 (permalink)
Moderator
jaapv's Avatar
Thanks, Bert, I have added this to the M9 FAQ
__________________
Jaap
WWW.JAAPVPHOTOGRAPHY.EU
Posts in blue bold font are made as a moderator
Leica user since 1976
jaapv is offline   Reply With Quote
Thank You say...
dwbell (06/03/12), Lindolfi (06/03/12)
Old 06/03/12, 17:06   #11 (permalink)
Erfahrener Benutzer
Lindolfi's Avatar
Ad
Indeed Lars, Jonathan Eastland was wrong there. The manual of the Leica M6 does show the measurement area correctly as scaling with the angle of view of the lens mounted and being constant in size relative to the correct framelines (not the one chosen with the preview lever), and thus keeping the coverage on the filmplane ("downstairs") the same.
I have superimposed the circle of the M6 from the manual onto my graph:
http://www.photoplaza.nl/lindolfi/m9andm6sens.png
You can see the strong resemblance between the meters of the M6 and M9 as Stephan Daniel already pointed out.
My graph can easily be viewed in stops also: 0.5 is 1 stop lost, 0.25 two stops and 0.1 slightly more than three stops lost in sensitivity.
__________________
Bert
PhotoBlog
Old 09/03/12, 02:19   #12 (permalink)
Neuer Benutzer
Correct me if i'm wrong, or if i missed something, but i think there is a misunderstanding of Eastland assertion.
He says "With a wide angle mounted", typically a 35 mm, you can preview the most active metering area for this lens by flicking the lever to show the 90 mm frame.
With any other lens, the metering area will vary in the same proportion : 2/3 of the height of the frame : so approximately for a 50 mm that would give an equivalent of a 135, and for a 28 something like a 50 mm frame.
But without touching any lever it's easy to imagine a center active metering spot of the correct size in the wiewfinder according to the lens mounted.
Anyhow you made a great job Indolfi
Pix_N is offline   Reply With Quote
Old 09/03/12, 02:30   #13 (permalink)
Moderator
jaapv's Avatar
See post #9
__________________
Jaap
Old 09/03/12, 02:39   #14 (permalink)
TBL
Benutzer
Thanks Jaap.
It is however confirming my objection to the system: if you shoot in portrait mode, it will give different results if you turn the camera 90 degrees to the left or 90 degrees to the right...
TBL is offline   Reply With Quote
Old 09/03/12, 03:50   #15 (permalink)
Moderator
jaapv's Avatar
Looking at the pattern I seriously doubt that difference would be perceptable in real life.
__________________
Jaap
Old 09/03/12, 17:53   #16 (permalink)
Erfahrener Benutzer
Lindolfi's Avatar
Quote:
Originally Posted by TBL View Post
Thanks Jaap.
Just did a test: filling the left half of the image with black and the right half with white in portrait orientation and taking the same image after turning the camera 180 degrees, so that now black is right and white is left. (care was taken that the boundary between black and white was exactly through the middle of the image).
The black and white had a difference of 7 stops in brightness.
Result: same measurement of exposure time in the 1/3 stop accuracy the M9 offers in both portrait orientations.
So no reason to be consistent in how you turn the camera to portrait orientation: just use the meter as though it is rotation symmetric around the centre of the image.
__________________
Bert
PhotoBlog
Thank You says
jaapv (09/03/12)
Old 09/03/12, 19:33   #17 (permalink)
Erfahrener Benutzer
zlatkob's Avatar
Leica should publish the metering pattern.
zlatkob is offline   Reply With Quote
Thank You says
M9reno (20/06/13)
Reply
Current eBay Ads
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
