| Leica M / M-E / M9 / Monochrom The Leica M9 Forum is dedicated to everything around the new LEICA M, M-E, M9, M9-P and LEICA M MONOCHROM. |
Leica Products
Leica M240 Amazon US | B&H | Dale | Adorama | eBay |
Leica M Monochrom B&H | Dale | Adorama | eBay |
Leica M-E Amazon US | B&H | Dale | Adorama | eBay |
Leica X Vario B&H | Adorama | Dale | Amazon | eBay |
Leica M9-P Amazon US | B&H | Dale | eBay |
#21 (permalink) |
Sponsoring Member
Ad
I thoroughly agree.
__________________
May the light be with you Bill Allsopp ~ Treasurer and webmaster - The Leica Society www.billallsopp.co.uk |
#22 (permalink) |
Erfahrener Benutzer
and me too.
Prevention is better than cure. The only thing I can add is blow out the mirror chamber ( mirror up and down) or similar space in Leica after each outing. Do with shutter closed. The idea is to get rid of junk before it migrates to the sensor. Only open if there is a known problem. I have had digi cams for years and never had a sensor dirt problem. |
| Thank You says | bpalme (11/03/12) |
#26 (permalink) |
Sponsoring Member
I have a VisibleDust sensor loupe, and it works quite well to help you see the bits of dust.
Loupe for camera, sensor cleaning. Rocky |
| Thank You says | Paul J (02/03/12) |
#27 (permalink) |
Erfahrener Benutzer
The Lenspen company also makes an illuminating loupe with a cutout through which you can apparently use one of their SensorClear pens to get at the sensor.
I'd recommend the loupe but I have no experience with the pen gadget. Looks a bit scary. I like the Visible Dust swabs, myself. By the way - getting the batteries into this loupe almost requires neurosurgical training.
__________________
Mark Polis, MD Leica M9 / 21 Super Elmar ~ 35 Summilux ~ 50 Summilux ~ 75 Summicron ~ 90 Elmarit Perfecting my gear - the skill's next. flickr |
#29 (permalink) |
Erfahrener Benutzer
I really like the Steve Huff sensor cleaning method ... and the cat
__________________
Photography by Georg Pagenstedt |
#30 (permalink) | |
Sponsoring Member
Quote:
__________________
#31 (permalink) |
Erfahrener Benutzer
Ad
Steve's method is pretty much what I do but I would always blow dust out of the chamber before opening the shutter. If specks still persists I get the loupe out and check and have a go (very carefully) with the arctic butterfly. If that fails I will do a wet clean.
#32 (permalink) | |
Erfahrener Benutzer
Quote:
But my worries are over. I'll gladly pay him € 50,- for cleaning my camera's. This guy is simply the best!! Chipclean - Hoe werken wij?
__________________
Paulus |
#33 (permalink) | |
Erfahrener Benutzer
Quote:
The moment you put it on the camera, it will get polluted by this kind of plastic dust. So take a littel bit of eclipe and a swab, and clean the bajonet. The black stuff is no grease, but polymer.
__________________
Paulus |
#34 (permalink) | |
Erfahrener Benutzer
Quote:
I rarely change lenses, and only do so carefully in good environments, but still find need to do a wet-clean about twice a year. I don't know why, but even without changing lenses, cameras designed for interchangeable lenses pick up more sensor-grunge than point-'n-shoots. Just like every skier should be able to wax her/his skis, and every driver should be able to adjust tire-pressure, photographers should be able to wet-clean their sensors. Although it might be a little scary at first, it's easy and safe if done properly, with less chance of doing expensive damage than cleaning a lens (some products even guarantee against damage). Even if you choose not to clean your own sensors, do it a time or two to demystify the process and add an important skill to your quiver. |
#35 (permalink) | |
Moderator
Quote:
__________________
Jaap WWW.JAAPVPHOTOGRAPHY.EU Posts in blue bold font are made as a moderator More money is spent worldwide on chewing gum than on nature conservation. |
| Thank You says | Paulus (05/03/12) |
#36 (permalink) | |
Benutzer
Quote:
#37 (permalink) | |
Benutzer
Quote:
#38 (permalink) |
Erfahrener Benutzer
I also would never again use those sticky pads to clean my sensor. I had a very lucky escape, when the pad split as I was peeling it off the backing strip rather than peeling it off the sensor.
I just keep wishing that someone would start selling wet cleaning wands that did not have a 10,000% profit mark up on them. Not sure about recovering the wands with snipped up Pec Pads - a bit of a risk to take with a precious sensor. Wilson |
#39 (permalink) |
Erfahrener Benutzer
I was walking past the Mayfair Leica store yesterday and dropped into ask about a few things. As you do. They said they offer a one day sensor cleaning service at about £70 on site.
__________________
Perception. Not perfection |
#40 (permalink) |
Moderator
They must use sensor brushes with handselected female Yak hair and the finest Scotch single malt cleaning fluid to justily that price!
__________________
| Bookmarks |
| Current eBay Ads |
Current bid:
330 USD (23 bids)
Current bid:
449.99 GBP (1 bids) |
| Thread Tools | |
| Display Modes | |
