Leica User Forum
Go Back   Leica User Forum > International User Forum > Leica Products > Leica M / M-E / M9 / Monochrom
Leica M / M-E / M9 / Monochrom The Leica M9 Forum is dedicated to everything around the new LEICA M, M-E, M9, M9-P and LEICA M MONOCHROM.
 Leica Products
Leica M silver Leica M-E Leica M Monochrom Leica S LEICA D-LUX 6 LEICA X2
Leica M
» eBay | Adorama | B+H | Dale
Leica M-E
Leica M Monochrom
Leica S
» eBay | B+H | Dale
LEICA D-LUX 6
LEICA X2
Amazon | » eBay | Adorama | B+H | Dale
Old 17/02/12, 17:13   #81 (permalink)
Erfahrener Benutzer
Default Re: Help needed: real-world M9 moiré problems
Quote:
Originally Posted by pgk View Post
Well now that depends very much on the lenses being used ...
No, it doesn't.
My Canon EOS 5D Mk II for example shows significant softening when stopping down from around f/11.
Sure. So does my Konica-Minolta Dynax 7D (APS-C format, 6 MP). It's a consequence of diffraction, and it will happen with any camera with approx. that format size and at around that aperture, no matter what the pixel count may be.
So more megapixels are simply not going to help ...
If that was true then we all would still use digital cameras with 4 or 5 MP.
... although they will probably produce more detailed images at say f/8ish—is this useful I wonder.
Hint: Photographs taken at apertures wider than f/11 exist. Some of them even are pretty good actually.
Fast lenses too are problematic, in as much as their performance wide open is often [...] already showing signs of stress, with images shot wide open lacking real sharpness and showing colour fringing at times. More megapixels won't help here ...
That's a reason to develop better lenses rather than cameras with less resolution. Apart from that—photographs taken at apertures narrower than f/1.4 exist. Some of them even are pretty good actually.
... but there will be many situations where the greater megapixels are not an advantage.
Sure. But that's no reason to declare high-resolution cameras pointless generally. In terms of image format and pixel count, there's a sweet spot to you somewhere—you would not want less than X but have no use for more than Y. Fine. To someone else, that sweet spot may be somewhere else. There are hobbyists, photo-journalists, wedding photographers, fanboys who are in for the bragging potential, artists, scientists, beauty/fashion/sports/wildlife photographers, and those who shoot the pictures for international commercial ad campaigns. And many others. Horses for courses.
More megapixels generally are useful as they are one factor (among others) to improve image quality, and they hardly have any detrimental effects ... well, with the exception of faster-growing image archives, of course, forcing you to buy more external hard disks. But then, these are growing fast, too.
More reading on this topic here: The Online Photographer: Myths About Megapixels (...And, Does the D800 Have Too Many?)
01af is offline   Reply With Quote
Old 17/02/12, 17:37   #82 (permalink)
pgk
Erfahrener Benutzer
Default Re: Help needed: real world M9 Moire problems
You are entirely missing my point O1af. Lenses DO matter because they have SPECIFIC purposes for practical photography. In many instances more MPixels are irrelevant because of the particular requirements of a specific genre of photography - macro and fast aperture were two examples. Using f/8 on a macro subject will almost certainly not provide sufficient depth of field so the image cannot be enlarged as far, etc., etc..
I hve never said that more MPixels are inherently pointless, but I do believe that for the vast majority (not all though) of photographers, they are. Producing ever bigger files for the sake of doing so is a somewhat academic exercise don't you think. Shooting 5" x 4" to reproduce as 10" x 8" prints may have some relevance but not to most of us.
As it happens I do have a scientific photography background and over the lat few years I have recently been involved in some scientific research where more detailed information about the subject matter would be really helpful. But I'm far from convinced that upping the MPixels will really yield sufficient the extra information to make it worth while considering, given that it will require higher degrees of accuracy at the taking stage and a reduced aperture which will reduce the acceptable 'hit' rate. Both Canon 5D and 5D2s have been used in this work and whilst the 5D2 yields a little more data it isn't as dramatically better as might be hoped.
However the original OP was actually about moire. My own experience of moire being a problem over the last 5 years on the M8 and now the M9 is very limited - its not a problem that I often see although for specific types of subject it might well prove to be - I've seen it on clothing and just once or twice on buildings.
__________________
Paul
www.paulkayphotography.co.uk
pgk is offline   Reply With Quote
Old 17/02/12, 22:48   #83 (permalink)
Erfahrener Benutzer
janki's Avatar
Sigma SD1, DSLR, with FOVEON APS-C sensor, has just dropped to about a third of its original price.
The manufacturer advertises fine beautiful transitions between the various colors.
janki is offline   Reply With Quote
Old 18/02/12, 02:20   #84 (permalink)
Neuer Benutzer
Are they also advertising that each camera comes with a pony?
nikonuser2012 is offline   Reply With Quote
Old 18/02/12, 05:47   #85 (permalink)
lct
Erfahrener Benutzer
lct's Avatar
Sigma SD1, DSLR, with FOVEON APS-C sensor, has just dropped to about a third of its original price. The manufacturer advertises fine beautiful transitions between the various colors.
Yes Foveon colors are superb really and no moiré problem there. Pity that they don't make a full frame sensor.
lct is offline   Reply With Quote
Old 18/02/12, 08:26   #86 (permalink)
Benutzer
siglo's Avatar
This is a technique that helps reduce the moire to a usable point. It does not completely eliminate moire, but certainly better than nothing. I hope it helps.
Moiré Patterns: Ep 229: Digital Photography 1 on 1: Adorama Photography TV - YouTube
__________________
Flickr
siglo is offline   Reply With Quote
Old 18/02/12, 12:26   #87 (permalink)
Erfahrener Benutzer
janki's Avatar
Thanks Siglo!
This was a very interesting little lecture about the problem.
But, perhaps morality may still be; Sigma FOVEON for weddings and fashion, and our beloved Leica to everything else.
Old 18/02/12, 15:21   #88 (permalink)
Erfahrener Benutzer
Thanks Siglo!
As everyone on this forum should well know, there is more to cameras and camera selection then sensors. That is why we use Leica's.
... H
haroldp is offline   Reply With Quote
Thank You says
hifigraz (20/02/12)
Old 18/02/12, 23:10   #89 (permalink)
Erfahrener Benutzer
janki's Avatar
Coincidentally, today I should make some scans of two insane brave Swedish flying acrobatic girls, from an air show back in 2007.
In one of the images, - is revealed, - this uncovered nine-cylinder air-cooled radial engine.
If this picture had been taken with a digital camera with a weak AA filter, it is very likely that it would boil with moiré around all the cooling fins on the cylinders.
KODAK film + R9 camera + Nikon cool scan 9000 = no moiré.
PS
Actually, these two cat girls climbed on top of the wing while the plane did spectacular movements in the air.
Old 21/02/12, 03:12   #90 (permalink)
Erfahrener Benutzer
NZDavid's Avatar
Yikes, brave aerial cat girls!
To cut moire, I am informed the latest version of Graphic Converter (an excellent program for Macs) contains corrections under Filter/Core Image Filter.
I have found very little difference comparing JPG with RAW for moire with the M9. (first three images, below). I also compared a JPG from the D-Lux 5. That, too, has moire (and the camera has an anti-aliasing filter). So perhaps the only surefire way to avoid it is indeed film!
NZDavid is offline   Reply With Quote
Thank You say...
janki (21/02/12), wattsy (21/02/12)
Reply
Bookmarks
Current eBay Ads
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
