| Leica M / M-E / M9 / Monochrom The Leica M9 Forum is dedicated to everything around the new LEICA M, M-E, M9, M9-P and LEICA M MONOCHROM. |
Leica Products
Leica M » eBay | Adorama | B+H | Dale |
Leica M-E » eBay | Adorama | B+H | Dale |
Leica M Monochrom » eBay | Adorama | B+H | Dale |
Leica S » eBay | B+H | Dale |
LEICA D-LUX 6 » eBay | Adorama | B+H | Dale |
LEICA X2 Amazon | » eBay | Adorama | B+H | Dale |
#61 (permalink) |
Erfahrener Benutzer
The next digital M will almost certainly have a better screen. A current 3" 3:2 aspect ratio screen with the same resolution as the S2 is used on the DLUX-4/5, and could fit by widening out the rear controls a bit (no need to move into the top plate at all, perhaps a little into the bottom).
The next digital M will likely be faster because Leica has already developed what they need to make it faster in the S2. It's likely the next M will use fewer electronic parts (the Maestro includes dual cores, DSP, SD/CF and USB interfaces in one chip). Leica would benefit from a single code base for firmware, for cost, speed to market, common bug fixing, and common base code libraries (I have not heard about SD card compatibility problems with the S2---the SD firmware for the S2 comes from Fujitsu with the Maestro). The more parts in common between the M and S lines (and even the X) the better for Leica and customers. A smaller, low resolution LCD and slow processing (whether some care or not) is not a selling point. We have the screen and slow processors because the M9 had to be based on the M8. The M10 will be based on the M9 and S2, and will be a better camera for it. Until later, Clyde |
#62 (permalink) |
Erfahrener Benutzer
Nothing wrong with the M9 as it is - don't reinvent the wheel and ruin a great design. Want a bigger screen, then maybe best to go and buy another camera.
#63 (permalink) |
Erfahrener Benutzer
[quote=Swanny66;1759122]I do not take 10 extra shots ..quote]
So do I. I set the focus when I look through the viewfinder. Regards Steve |
#64 (permalink) |
Sponsoring Member
So, here's a quick sanity check... All these paragons of photographic virtue with bigger rear screens are either physically bigger already (DSLRs) or designed to be held at arm's length with that peculiar "fastidious zombie" grasp. What matters to me is the amount of real-estate on the back of the camera that I can use to grasp it firmly while holding it to my eye without accidentally thumbing a button or sticking prints on a screen. Most modern digicompacts have already gone too far in this regard.
Regards, Bill
__________________
Bill Palmer Gentleman Amateur & Leica Ambassador emeritus Take One a Day Lightmancer ~ Rangefound 12 of my best ~ Some of my images |
| Thank You say... | charlesphoto99 (05/07/11), paulmac (05/07/11) |
#65 (permalink) | |
Sponsoring Member
Quote:
A chisel is a fine tool for carving wood. You can also use it to slice cheese. If you need to slice cheese you don't start by buying a chisel and wishing that it was a cheese knife and arguing that it should be modified to suit that purpose. Regards, Bill
__________________
#66 (permalink) | |
Erfahrener Benutzer
Quote:
Time moves on and with it comes change. Some for better, some for worse. I know what I want, you seem to know what you want. Let's leave it at that, eh? |
#67 (permalink) |
Moderator
I don't think Bill is talking about form, i think functionality is more on his mind. I agree that there is always room for improvement, but there are no reasons to graft functions onto the M whatever that are better on other tools, and certainly not at the expense of the concept of the Leica M series. Up until now Leica has done a great job retaining the basic ideas of the M3 in the latest iterations, and I am sure they will not deviate. It would be suicide.
| Thank You say... |
#68 (permalink) | |
Erfahrener Benutzer
Quote:
The other thing is, there seems to be some God written rule which some members doggedly adhere to that the Leica M should only be used as a street camera. Quite why is beyond me, and surely it serves Leica better if people use it for other purposes as well, thereby increasing the customer base. Why come out with a lens like the Noctilux and then limit it's capabilities to street work when it's capable of creating beautiful portraits. Unfortunately, portraits wide open require critical focus, and this (for me) is where the M9 fails. It doesn't have to though, hence my various suggestions which - and let me just reiterate this for the panic brigade - would not move the M away from it's core values (IMO) |
#69 (permalink) |
Erfahrener Benutzer
Perhaps along with the bigger display Leica will give us a a bigger sensor for the M10. Sources tell me this is one under consideration (and it's still a CCD):
What a 268-Megapixel Sensor Looks Like ![]()
__________________
http://www.charlespeterson.net |
| Thank You says | jan_kappetijn (06/07/11) |
#70 (permalink) |
Moderator
I don't think that real estate on the rear of the camera for a 3 inch LCD screen would be a problem if that sensor were to be used on the M10.
It's interesting to see how large that is. I wonder if it's the astronomical use that drives that? After all, a few Hasselblad sensors stuck together would soon get to 268 mpixel, in a much smaller area.
__________________
Andy Any comment here is just my opinion. Yours may differ. Any comment posted in a dark red bold font is posted as a Moderator Website: 1st April 2013 Blog: "Still My Turn This Year": 30th April 2013 __________________________________________________ Leica User Forum Book 2012 for AICR Charity still available |
#71 (permalink) | |
Erfahrener Benutzer
Quote:
The reason why I join this forum is that I enjoy to discuss the different point of views and learn from the experience of other users. In this respect I kindly decline your recommendation. You might reevaluate your motivation to join this forum. Kind regards, Steve Last edited by jaapv; 05/07/11 at 18:08. Reason: quotemark added |
#72 (permalink) | |
Moderator
I haven't seen much about street shooting in this thread, anyway I am not guilty. I am probably the worst street shooter on the forum, so I tend to stay far from the subject.
For me the M(9) is far more universal than many would give it credit. I think the changes that will be created for a successor will be non-invasive in a superficial sense, complicated as they might be to implement. Things like weatherproofing, a better LCD at the same size, processing improvements through newer electronic technology, maybe even a new sensor if Leica can find one they like and such are far more likely than vast changes in specifications, hybrid viewfinders, focus confirmation and the rest that have been proposed in this forum. Btw. Your M9 should not fail in critical focus on portraits, on the contrary, that is one of its strong points. Quote:
#73 (permalink) | |
Moderator
Quote:
__________________
| Thank You says | jaapv (05/07/11) |
#74 (permalink) | |
Erfahrener Benutzer
Quote:
I also agree that if doing it screws up the camera, Leica should not (and will not) do it. Until later, Clyde |
#76 (permalink) |
Erfahrener Benutzer
There are more elegant solutions to allow an external monitor to connect with an M. So, instead of Leica changing everything in the camera they can simply add a wifi chip and connect with everything.
Either way however, Leica should make the current screen OLED if possible for lower power and better llumination. They also need to make it faster too. But come on guys, seriously, don't tell me that you need that shitty LCD monitor to validate your focus: just trust the RF mechanism and your eyes, and you will never miss focus again. |
#77 (permalink) |
Erfahrener Benutzer
I also cannot imagine that the correct focus can be evaluated on a small rear screen in a reliable way, no matter if it is 2.5 or 3 inches. Please think about how an M camera would look like with a really large screen. In addition, please think about the power consumption with all technical add-ons one could imagine (wifi, GPS, etc.). In the end, somebody calls for an integrated shoe-shining brush or a built-in coffee mill...
#78 (permalink) | |
Erfahrener Benutzer
Quote:
Discuss and learn. Perhaps you'd better add teaching to that. Your original recommendation was presumptuous and ill informed. Perhaps, therefore, there's a lesson in there to be learned. Let's leave it at that ![]() |
#79 (permalink) |
Erfahrener Benutzer
Well, as I've mentioned elsewhere, glasses are an issue for me and I struggle to obtain critical focus where I want it as much as I would like, especially in portrait mode. Some of that is my issue. Some of it is, as I see it, a camera failing that could be improved upon.
| Thank You says | Steve Ash (05/07/11) |
| Bookmarks |
| Current eBay Ads |
Current bid:
7894.3 USD (0 bids)
Current bid:
34.99 USD (0 bids)
Current bid:
720 GBP (26 bids) |
| Tags |
| image review, improvements, m9 screen, m9 speed, processor power |
| Thread Tools | |
| Display Modes | |
