Welcome to the Leica Forum! Please click here to register - it's free.
Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
 Leica Products
Leica S2
Leica S2
Leica M9
Leica M9
Leica M9-P
Leica M9-P
Leica MP
Leica MP
Leica M Objektive
Leica M Lenses
Leica X1
Leica X1
Leica D-Lux 5
Leica D-Lux 5
Leica V-Lux 2
Leica V-Lux 2
Amazon | eBay | B+H Amazon | eBay | B+H Amazon | eBay | B+H Amazon | eBay | B+H Amazon | eBay | B+H Amazon | eBay | B+H Amazon | eBay | B+H Amazon | eBay | B+H
Old 22/08/09, 07:15   #1 (permalink)
Erfahrener Benutzer
Default Leica M9 FF Mock-Up
With all this talk about a possible FF camera being announced at some point, I thought I'd show you some tests I did to try to answer the question: "Will a FF sensor fit in the M8 body?"
You might think that replacing the existing sensor with a FF one and a new Maestro electronics board might be a simple development but one concern I've had is when you look inside the M8 lens throat and compare it with a film M. The film M lens throat is more open compared to the M8 throat which is more crowded and my question was whether this would cause problems in a full-frame camera.
I decided therefore to fit a "Full Frame" sensor in place of the existing sensor to see how things worked. Sadly, my parts drawers were not overflowing with 18-24MP FF sensors but I did have a piece of ground glass to act as my sensor...
Why is the lens throat more crowded in the M8? The answer of course is that it's the battery getting in the way, as these pictures show.
Here's the front casting with most parts removed, just the strap eyelets, the frame preview lever and the lens mount in place.
Turning around, you can see at the back of the bayonet ring the 4 leaf-springs which press against the lens bayonet flanges to keep it tightly seated on the bayonet ring. Bottom right, you can see the brass plate which "lubricates" the latch on the base and it's this part which, on rare occasions, has fractured. Not much else to see but you can make out the 3 mounting points each for the shutter and sensor.
This is the plastic moulding which is both part battery compartment and lens throat, viewed from the back. The inside surface of the moulding from the front is flocked to avoid reflections.
Installed in the camera with the battery in place, you can now see why space had to be taken from the lens throat to make space for the battery which accounts for the M8 lens throat being more crowded than in a film M.
So, with the lens throat moulding in place, we want to see whether there's enough space to fit a full-frame sensor. Regular readers will recognise this - the M8 sensor and its mounting plate and sensor circuit board which generates the timing signals the sensor requires and performs the all-important analog-to-digital conversion. The 27 * 18mm green area is the light sensitive area and the sensor is bonded to the back of the aluminium carrier plate. You can see, however, that the sensor is rather larger than the frame size.
For this test, I needed a "sensor" area of 24 * 36mm, so produced an alternative aluminium carrier plate with this size aperture, importantly using the same horizontal and vertical centre lines measured from the original - best not to look at the quality of the metal working too closely...
Here is the carrier plate mounted in the front shell with my ground glass screen acting as a FF sensor attached to the back.
With the camera mounted on a tripod and a 90mm Elmarit-M mounted, you can see the projection of one of the skylights in my lab onto the ground glass screen. With only half the shell to secure to the base, the elastic bands help keep everything in place. UK readers will recognise these as recycled from what your mail comes bundled with...
This then is an M8 with a FF "sensor" and you can now see that looking at the upside down view out of my lab, there is clear vignetting left and right and in the corners. Interestingly, the effect is much less pronounced with a wide angle lens which has its exit pupil much closer to the sensor and can see around the obstruction presented by the lens throat.
Conclusions then? For a FF camera, the lens throat needs to be made bigger. There's no problem on the right hand side as shown here because the space required is currently taken up by the folded light meter flex-print which could be relocated elsewhere. The other side presents more of a problem because of the battery. If you assume that Leica will want to retain the same size battery - and I think most of us would want to be able to interchange batteries and chargers between the M8 and M9 - one way would be to stretch the body by a few mm to move the battery further out from the lens throat. That comes at a price though. A slightly wider body needs new castings, top and bottom plates, new grips, new cases and coverings - Luigi and Morgan at Camera Leather would not be happy.
The alternatives are to move the lens over by a fraction - unlikely IMHO - or use a smaller battery. We know from my power consumption thread that the major user of power is the processing electronics which are expected to be replaced by the Maestro chip set. We also know from comments on the S2 forum that the power requirements of the Maestro are low so it might be possible to use a smaller battery and still obtain a satisfactory battery life. There is still the question of different chargers and batteries for the old and new cameras but maybe that's the price to pay.
I do not think there is a "do nothing" option. It just doesn't appear possible to fit an FF sensor in the current body with the current battery.
So, my prediction, for what it's worth, is that a FF Leica Digital M camera will need be slightly wider than the M8 or else use a smaller battery.
I may of course be proved completely wrong in a few weeks...
__________________
Mark
marknorton is offline   Reply With Quote
Leica Deals
Leica
Right now more than more than 9,000 Leica auctions worldwide
Brand new Leica S2 37.5 MP Digital+Summarit-S 70mm/2.5
Current price: 28900 USD
Auction ends: 2012-05-20 11:06:33
Old 22/08/09, 07:27   #2 (permalink)
Erfahrener Benutzer
Default Re: Leica M9 FF Mock-Up
Whew! Mark, you are amazing.
You do stretch the limits, you know that. Three weeks isn't that long to wait for rumours or facts to be proven.
lxlim is offline   Reply With Quote
Old 22/08/09, 07:34   #3 (permalink)
Erfahrener Benutzer
Looks like a fun project!
I wouldn't mind new batteries. Maybe they can also make the body thinner while they are at it.
__________________
- Roey Horns | http://www.roeyhorns.com | http://www. amatteroffocus.com
roey is offline   Reply With Quote
Old 22/08/09, 07:56   #4 (permalink)
Erfahrener Benutzer
Would a taller body with batteries lying horizontally be a possible choice?
Old 22/08/09, 08:08   #5 (permalink)
Erfahrener Benutzer
garygsandhu's Avatar
Great work; and not much of a s-t-r-e-t-c-h( sorry, I just loved the elastic band!) to get FF -- although I was hoping for a smaller body.
garygsandhu is offline   Reply With Quote
Old 22/08/09, 08:13   #6 (permalink)
Erfahrener Benutzer
efftee's Avatar
Mark, you continue to stun me. For what it's worth, a 'source' commented that the upcoming M9 would be slightly wider and thicker, not much (just mm's). If that's true and by your analysis, it would have room for the existing battery and possibly (leaping off a building here) better control of vignettes?
efftee is offline   Reply With Quote
Old 22/08/09, 09:32   #7 (permalink)
Erfahrener Benutzer
adli's Avatar
Great work. Interessting that they actually have to redo the body to avoid obstacles in the light path.
When it comes to the battery, I am sure that Leica will come out with a new battery. Battery technology have improved since the M8 battery were designed, so it shuld be possible to design a smaller battery with the same or better capasity.
adli is offline   Reply With Quote
Old 22/08/09, 09:44   #8 (permalink)
Erfahrener Benutzer
Steve Ash's Avatar
Default AW: Leica M9 FF Mock-Up
Mark, all respect for what you are doing. I would rather prefer to buy some new spare batteries than a bigger M-camera.
Regards
Steve
Steve Ash is online now   Reply With Quote
Old 22/08/09, 10:07   #9 (permalink)
Erfahrener Benutzer
jonoslack's Avatar
Splendid Mark
I really enjoyed that.
How long did this take you?
__________________
kind regards
jono slack
Field Testing the Leica M9 (Book)
jonoslack is offline   Reply With Quote
Old 22/08/09, 10:11   #10 (permalink)
Erfahrener Benutzer
biglouis's Avatar
Mark
You are clearly dedicated to the Leica family. Awesome.
LouisB
__________________
My new book "School Work" now available
Take a look at my Flikr stream
My website: http://www.louisberk.com
biglouis is offline   Reply With Quote
Old 22/08/09, 10:15   #11 (permalink)
Erfahrener Benutzer
hx911's Avatar
Surely a smaller battery can be made (flattened on the side that is in the way. Otherwise the same. this way the new battery fits in the M8 and the M9. the old M8 batteries wont fit in the M9 though.
P.S. Mark, I so love your input, and the pictures. As an engineer I like to see 'what's inside' - but having taken apart many things that somehow never gor reassembled or functioned properly afterwards, in the case of the M8 you satisfy my curiosity without me incurring the cost!
thanks so much!
hx911 is offline   Reply With Quote
Leica Deals
Leica
Old 22/08/09, 10:33   #12 (permalink)
Erfahrener Benutzer
rick_dykstra's Avatar
Quote:
Oscar B just did another spin in his grave.
rick_dykstra is offline   Reply With Quote
Old 22/08/09, 10:48   #13 (permalink)
Erfahrener Benutzer
stunsworth's Avatar
Could the battery be moved to the right hand side, turned through 90 degrees, and used inside an integrated grip?
__________________
Steve
Flickr
Twitter
stunsworth is offline   Reply With Quote
Old 22/08/09, 10:50   #14 (permalink)
Sponsoring Member
carstenw's Avatar
At the moment the battery is rather forward in the body. Would it not be possible to move it slightly back in the body, relocation some electronics in front and behind the battery to make the room, and then to push it slightly towards the end of the body, not changing the size?
Failing this my preferences is for a different battery, not a different camera shape.
__________________
Carsten - Photo Blog - Leica M Lens Codes
carstenw is offline   Reply With Quote
Old 22/08/09, 10:56   #15 (permalink)
Neuer Benutzer
Quote:
Why? They should be happy to sell lots of new cases...
Seriously - as others already said, the size of the M9 would be more important to me than buying new batteries. I hope it's at least not bigger than the M8. If it were even smaller (like the M6) that'd be super-cool, but I guess that's hoping too much.
Thanks for your interesting analysis.
Jeanette is offline   Reply With Quote
Old 22/08/09, 11:03   #16 (permalink)
Sponsoring Member
spylaw4's Avatar
Very interesting and informative - many thanks Mark!
I'm just looking at the underneath of my M8 as I write.
It would at first sight seem possible to move the battery to the other side of the lens, relocating the SD card slot elsewhere. I am not sure however (without digging out Mark's original strip-down) how much this would impact on the other circuitry. But then if one is starting with virtually a blank sheet internally and aiming to at least retain the same size body to keep costs down....?
Re moving the battery rearwards - how would this impact on the screen control board?
Steve's suggestion is intriguing and seems worth considering - but then if we are to see an M9 in the immediate future the design will be finalised by now.
My preference would be for a battery of smaller/altered shape. M9 no larger than the M8 please.
__________________
Brian
Indecisive Moments - my website
spylaw4 is online now   Reply With Quote
Leica Deals
Leica
Leica X1 Body Black 24mm 2.8 ASPH CMOS 12.9MP FEDEX FST
Current price: 1287.37 GBP
Auction ends: 2012-05-21 12:02:48
Leica X1 Body Steel Grey 24mm 2.8 ASPH CMOS 12.9MP FAST
Auction ends: 2012-05-21 12:02:50
Old 22/08/09, 11:06   #17 (permalink)
Sponsoring Member
carstenw's Avatar
In fact, it should be possible to take the same basic battery shape, but to make one (or both) ends flat. The new batteries should fit in the old camera, but not vice versa.
__________________
Old 22/08/09, 11:46   #18 (permalink)
Erfahrener Benutzer
Thank you all for your comments. In answer to Jono - I did this a month or so ago to satisfy my curiosity in an afternoon (Dremel was red hot and diamond cutting discs worse for wear!) but just photographed everything yesterday for its 15 minutes of fame...
As for what will change, we can't be certain. There's an incentive to use as much as what exists as possible but we can be certain they will want to add volume to Maestro by using this chip set in a new camera to save space, power and cost. Having now sorted out the shutter - which is suitable for FF - I'd want to carry that over unchanged if I could and it's that which accounts for most of the space on the right hand side of the camera (viewed from the back).
I expect Leica will have changed the size of the camera only if they have to because of all the implications of doing so. Using a smaller battery and providing, for example, a longer life battery in a deeper base-plate might be an alternative.
__________________
Mark
Old 22/08/09, 11:51   #19 (permalink)
Benutzer
A Sfeir's Avatar
Great work, thanks for sharing.
Would the new larger shutter need more space?
A Sfeir is offline   Reply With Quote
Old 22/08/09, 12:12   #20 (permalink)
Erfahrener Benutzer
No, the shutter is already suitable for FF, in my view.
__________________
Mark
Reply
Bookmarks
Current eBay Ads
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
