Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
090909 Promo
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
Old 20.07.2009, 10:53   #1 (permalink)
Erfahrener Benutzer
ptarmigan's Avatar
Default M* (nor card reader with SD card) recognised by Mac
Not tried to hook up my M8 to the iMac before but couldn't get the CF/SD multi reader to be recognised and so thought I would try - but nothing visible in Finder and if I disconnect - no complaints from the Mac.
As soon as I pop a CF card in the reader 'up' it pops in Finder but no go with either the camera or SD card. Any suggestions?
Only had the M8 3 weeks and the SD card/reader has worked before but it was not always recognised immediately but today - nothing!
__________________
Cheers
Ian
ptarmigan is offline   Reply With Quote
Old 20.07.2009, 10:58   #2 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Default Re: M* (nor card reader with SD card) recognised by Mac
I cannot help you (I am on PC) but I know there is a shoal of threads on the subject. The search function will help you dig them out.
__________________
Jaap
WWW.JAAPVPHOTOGRAPHY.EU
Skype: JAAPVPHOTOGRAPHY
jaapv is offline   Reply With Quote
Old 20.07.2009, 11:30   #3 (permalink)
Neuer Benutzer
You should use either Image Capture or iPhoto as my understanding is that M8 / M8.2 don't show up as disk drive. Both applications are provided with OSX and are easily located with Spotlight.
teemulaine is offline   Reply With Quote
Old 20.07.2009, 11:31   #4 (permalink)
Erfahrener Benutzer
ptarmigan's Avatar
Jaap
Thanks. Have done a search but found nothing yet! Will have to try a different search.
__________________
Cheers
Ian
Old 20.07.2009, 12:02   #5 (permalink)
Erfahrener Benutzer
ptarmigan's Avatar
Quote:
Bizarrely I downloaded using my 12-1 card reader several times but just checked and the one I own does not support SDHC - actually, only just used the SDHC this weekend - all previous 'shoots' were with a 2gb SD card!
Thanks anyway. Will try as suggested but having hooked the M8 up to my Mac, it seems to have drained the battery!
__________________
Cheers
Ian
Old 20.07.2009, 12:52   #6 (permalink)
Erfahrener Benutzer
wlaidlaw's Avatar
You have to run Image Capture (should be in Applications under iDVD - see screen print) just once and your M8 will thereafter connect via the cable. Generally this is not recommended - see dozens of threads - a card reader or if it has it, a direct SD slot on your computer is safer and faster. If you cannot find Image Capture PM me and I will email you a copy or you can do an Archive Reinstall of your system and it should appear.
Wilson
wlaidlaw is offline   Reply With Quote
Old 20.07.2009, 12:57   #7 (permalink)
Erfahrener Benutzer
Sounds like a bad card reader. Have you tested by borrowing someone else's?
Walt Calahan is offline   Reply With Quote
Old 20.07.2009, 13:02   #8 (permalink)
Erfahrener Benutzer
wlaidlaw's Avatar
Quote:
I had to change all but one of my readers and my Macally combined USB hub and card reader to read SDHC cards. My new Macbook has a built in card reader - very useful but stupidly it is SDHC only and is not firmware upgradeable to the new SDXC standard.
Wilson
Old 20.07.2009, 13:13   #9 (permalink)
Moderator
andybarton's Avatar
Lots of older card readers don't read newer SD cards
It pays to buy a new reader each time you move forwards with the card technology
Ridiculous, really
__________________
Andy
_________________________________________________
__________________________________________________
andybarton is offline   Reply With Quote
Old 20.07.2009, 14:15   #10 (permalink)
Erfahrener Benutzer
Quote:
I found my Fuji card reader (fine for SD) not recognised by iMac when loaded with SDHC, so I had to buy a Sandisk reader (fine with both types of storage card). Download was faster however with the SD files, so a worthwhile replacement.
Image Capture ought to be in the Mac Applications folder. although it's not a good idea to connect M8 direct to computer, not least because of the fragility of the plastic door on the camera.
microview is offline   Reply With Quote
Old 20.07.2009, 15:36   #11 (permalink)
Erfahrener Benutzer
ptarmigan's Avatar
Ridiculous, really
Yep! Just ordered one. In the meantime, downloaded images via iCapture but will switch back to the 2gb card until the new reader arrives I think as it will make life easier.
__________________
Cheers
Ian
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
