Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
090909 Promo
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
Old 04.07.2009, 10:45   #1 (permalink)
Neuer Benutzer
Default Dead Pixel or Dust?
Hi everyone,
I found this nasty bright pixel on multiple photos of mine. Also notice the blue vertical line that goes right through the pixel. In each photo the bright green pixel is located at exact same spot. Could this be a dead pixel? What does that mean in terms of my camera and what can be done to fix this?
-Andy
jazztronikk is offline   Reply With Quote
Old 04.07.2009, 10:51   #2 (permalink)
Erfahrener Benutzer
Default Re: Dead Pixel or Dust?
I am not an expert but as I see it that would be a dead pixel.
I think there are 2 options - one is that you have a new sensor and the other is that Leica 'map' the sensor to get rid of it. I don't fully understand this second option but if you do a search (or wait a while for someone more knowledgable!) you will learn about it.
Either way I believe your camera must go back for service.
Julian Thompson is offline   Reply With Quote
Old 04.07.2009, 13:20   #3 (permalink)
Erfahrener Benutzer
Default AW: Dead Pixel or Dust?
Your sensor clearly shows a line - the hot pixel is just a bonus
Contact Leica customer service by email, send this photo with it and they will arrange everything else, unless you're in the US, which would probably mean that the cam has to go through NJ first.
They will exchange the sensor and some electronical components.
Venkman is offline   Reply With Quote
Old 04.07.2009, 16:03   #4 (permalink)
Erfahrener Benutzer
Hans Roggen's Avatar
Default Re: AW: Dead Pixel or Dust?
Do they do this free of charge?
__________________
Regards,
Hans Roggen
Hans Roggen Photography website
Hans Roggen is offline   Reply With Quote
Old 04.07.2009, 17:06   #5 (permalink)
Erfahrener Benutzer
mboerma's Avatar
Quote:
They did in my case. Fast and quick service. Pickup and delivery at my home in Amsterdam. Search for "Darn line" and you'll find an extensive thread about this.
__________________
Maarten Boerma
Portfolio MaartenBoermaPhotography
Weblog SoulPixels
mboerma is offline   Reply With Quote
Old 04.07.2009, 18:33   #6 (permalink)
Erfahrener Benutzer
LeicaMSeattle's Avatar
Default AW: Re: AW: Dead Pixel or Dust?
You have a pixel that is confused in the areas of underexposure. They will fluoresce either green, blue, or red under low light conditions when the camera is set to ISO 640 and greater. The white line is a writing error stemming from the pixel. I just experienced this again recently without the white line, since having Leica replaced the sensor earlier this year. Be sure to include files of your photographs when you return your camera so that the technicians can do an analysis of your camera's sensor.
They replaced the sensor on my camera which was out of warranty at no charge.
LeicaMSeattle is offline   Reply With Quote
Old 04.07.2009, 19:26   #7 (permalink)
Erfahrener Benutzer
sfokevin's Avatar
Default Re: AW: Re: AW: Dead Pixel or Dust?
Do you possibly work in Seattle for Microsoft Tech Support?... "You have a pixel that is confused"...
__________________
M8/SE18 - Elmarit 28 - Lux 50 - Cron 90 - TE135
BKK
sfokevin is offline   Reply With Quote
Old 04.07.2009, 23:51   #8 (permalink)
Erfahrener Benutzer
Default AW: Re: AW: Re: AW: Dead Pixel or Dust?
Quote:
No, I don't work for Microsoft, but I have had extensive conversations with Mark Brady at Leica in N.J. and this is pretty much his explanation for this occurance. They replaced the sensor on my M8 already this year. I'm afraid that the sensor is not up to the low light qualities as the sensor used in DSLRs like the D700.
Old 05.07.2009, 06:52   #9 (permalink)
Neuer Benutzer
It is a dead pix with line, I just received my Leica from NJ, and, yes, they replaced CCD.
photoshutter is offline   Reply With Quote
Old 05.07.2009, 08:15   #10 (permalink)
Benutzer
Dougg's Avatar
Does Leica USA in New Jersey change the sensor there, or is the camera sent on to Solms for this? And how long does this repair generally take?
I had the vertical "blue line" problem but without the hot pixel, sent it through my dealer to NJ about a month ago, along with a CD with a couple of DNG samples of the line, and a 100%-scale cropped TIFF with orange arrows indicating the position of the line.
Dougg is offline   Reply With Quote
Old 05.07.2009, 10:30   #11 (permalink)
Erfahrener Benutzer
jaapv's Avatar
It happens to all sensors, Leica is not immune. The Digilux 3 has an inbuilt sensor mapping facility. If you want to use the camera for a while before having it fixed, use this software to map the image in your computer: Pixel Fixer | Hot pixel removal utliity
It will also extract jpg files from the DNG. Practical if you forgot to go DNG+JPG when shooting.
__________________
Jaap
WWW.JAAPVPHOTOGRAPHY.EU
Skype: JAAPVPHOTOGRAPHY
jaapv is online now   Reply With Quote
Old 05.07.2009, 10:37   #12 (permalink)
Erfahrener Benutzer
Hi Jaap, have you used this?
Jeff
delander is offline   Reply With Quote
Old 05.07.2009, 18:22   #13 (permalink)
Erfahrener Benutzer
sfokevin's Avatar
If you regularly use Lightroom - It seems that you could create a Preset of the spot removal tool to correct the dead pixel...
__________________
BKK
Old 05.07.2009, 22:39   #14 (permalink)
Erfahrener Benutzer
gwelland's Avatar
Btw, I've found that LR will often de-mosaic out some hot pixels when it renders a 100% preview. I don't have any with my M8 but I do have one on my D3x and LR removes it (Nikon Capture NX does not).
Just a thought ...
__________________
Graham
gwelland is online now   Reply With Quote
Old 06.07.2009, 20:01   #15 (permalink)
Neuer Benutzer
I have one hot pixel, but the software (capture one) automatically removes it when I develop DNG to JPG. That doesn't mean the problem is solved, but at least I don't see it on my final output.
khiromu is offline   Reply With Quote
Old 07.07.2009, 09:57   #16 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Quote:
Jeff
I have it on my computer,Jeff, but I had no cause to try it out yet
__________________
Jaap
Old 08.07.2009, 13:18   #17 (permalink)
Erfahrener Benutzer
Default AW: Re: Dead Pixel or Dust?
Quote:
All questions that Leica themselves can answer best.
Old 09.07.2009, 02:38   #18 (permalink)
Benutzer
Dougg's Avatar
Well, with the passage of a little time, answers have appeared... My dealer, PopFlash, sent my M8 to Leica USA on June 4, and received it back on July 3. The sensor had been replaced and two upgrades were applied; shutter and frameline mask, apparently all done in New Jersey. I hope to see it tomorrow and get reacquainted.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
