Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
090909 Promo
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
Old 11.05.2009, 13:07   #1 (permalink)
Erfahrener Benutzer
Default Lens Coding for Tri-Elmar 28-35-50
Bit the bullet over the weekend and coded my 24mm, 35mm and 50mm lenses. I used a Dremel to 'mill' the recesses into the lens flange and then filled with Matt Black and Matt White enamel modelling paint. Everything worked out great but I couldn't find a code for the Tri-Elmar ...... anyone have any ideas?
I was also going to code my 90mm Summicron but as one of the black marks coincided with a screw and I understand it isn't essential to code anything over 50mm, I didn't bother.
As a note to anyone thinking of using a Dremel to code; I was a bit apprenhsive before actually doing it but it's very straight forward. I was tempted to use a slower speed on the drill but that tends to 'snatch', it's much smoother if you use a high speed. Biggest problem is protecting the lens from brass filings entering.
_________________________
Regards, Tom
Photography by Tom Lane
lanetomlane is online now   Reply With Quote
Old 11.05.2009, 13:25   #2 (permalink)
Erfahrener Benutzer
Default Re: Lens Coding for Tri-Elmar 28-35-50
Brave Man. How did you ensure the edges of the pits were flat and are not now going to scratch the bayonet ring?
Check out Carsten's posts (user: carstenw). He has a link at the bottom which shows the codes for the lenses including the Tri-Elmar.
__________________
Mark
marknorton is offline   Reply With Quote
Old 11.05.2009, 13:49   #3 (permalink)
Erfahrener Benutzer
cbretteville's Avatar
Brave man indeed. Code for the MATE is 42 See Leica M8 Lens Codes
BTW, what did you put on the Dremel to make the grooves?
- Carl
__________________
The M8 Metadata project
Join the 2010 Leica One Challenge, Venice Italy, Saturday October 16th.
cbretteville is offline   Reply With Quote
Old 11.05.2009, 14:03   #4 (permalink)
Erfahrener Benutzer
Hi Carl, many thanks for the information.
I used an extremely small router bit in conjunction with a flexible drive from the Dremel.
_______________________________
Thanks & regards, Tom
Old 11.05.2009, 14:11   #5 (permalink)
Erfahrener Benutzer
Thanks for your help Mark. I used a small spherical router bit and flexible drive, therefore raised edges on the grooves were not a problem. I checked for flatness after 'milling' and if there had have been any raised edges I would have levelled using a needle file.
Thanks & Regards, Tom
Old 12.05.2009, 01:49   #6 (permalink)
Erfahrener Benutzer
Thinking about trying this myself. But I think I'll start with the LTM adaptor on my UC hexanon. That's easy enough to replace if I mess up.
__________________
Tim Barker
my website
my flickr
tbarker13 is offline   Reply With Quote
Old 12.05.2009, 08:41   #7 (permalink)
Erfahrener Benutzer
Quote:
I tried it on a piece of scrap aluminium alloy before attacking the actual lens' flange. It really is very easy but I would recommend to use one of the higher drill speeds. At first I tried with a low speed on the assumption that if anything went wrong I wouldn't do as much damage. However, using the lower speeds the router bit tended to snatch and I didn't have as much control.
After this success I thought I may have a go at dentistry .... and volunteers?
Regards, Tom
Old 12.05.2009, 09:02   #8 (permalink)
Erfahrener Benutzer
michali's Avatar
Using an M Coder and engraving tool I coded my MATE.
Very important how the lens is orientated: I position the red dot in the 2 O'clock position, which places the aperture scale etc. in the 12 O'clock position, area to be coded ends up in the 7 O'clock position.
Working anti-clock-wise the code is BWBWBW (obviously B=Black W=White). I've only milled the Black notches, painted them black with nail polish & left the White blank.
I've done all of my old Leitz Lenses including the 1954 35mm Summaron & 50mm Summicron, I read somewhere that these can't be coded, on the contrary it's worked on all of them. I've done this mainly for EXIF purposes.
Good luck!
__________________
MIKE
http://michali.zenfolio.com/
michali is offline   Reply With Quote
Old 12.05.2009, 09:09   #9 (permalink)
Erfahrener Benutzer
Good luck!
Thanks for the information Mike. Now I have the actual coding I cannot see any problems as the other three lenses were easy to do. Problem was that the M Coder doesn't provide the code for the MATE.
Old 12.05.2009, 18:36   #10 (permalink)
Erfahrener Benutzer
michali's Avatar
QUOTE: "Thanks for the information Mike. Now I have the actual coding I cannot see any problems as the other three lenses were easy to do. Problem was that the M Coder doesn't provide the code for the MATE."
Tom- My pleasure. The M Coder I have does show the MATE code it's on the flip side of the rotating scale, off the top of my head it's shown under the lenses manufactured up to 1999 or 2000 if I recall correctly.
__________________
MIKE
Old 13.05.2009, 09:05   #11 (permalink)
Erfahrener Benutzer
Hi Mike
I never thought to check the flip side of the M Coder ....... dummy! I will when I get home tonight and I bet it's there. Again, many thanks for your help.
Cheers, Tom
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
