| Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8. |
#1 (permalink) |
Benutzer
Some good news, my dealer rang me today to say that he had received my order this morning, the lens having been delivered some four weeks ago. All being well, I should be picking it up on Saturday.
Incidentally, I can only agree with Erwin Puts, this is a stunning lens. SEM18, part 2 Mike |
| Advertisement (gone after free registration) |
#2 (permalink) |
Erfahrener Benutzer
Picked up mine today :-) When you get yours could you do me a favour. Blow on the filter from the underside (the recessed side that attaches to the lens) and see if you hear a vibration. Mine makes a vibration sound (but not when I blow from the outside of the filter) and I assume either it is normal and the filter glass itself is supposed to be slightly loose or mine is faulty and should not be loose at all.
Thanks. Simon PS. I agree about the 18/3.8 - an extremely good lens. Last edited by sclamb; 30.04.2009 at 23:36. |
#3 (permalink) |
Benutzer
Simon
I'll check the filter out as you suggest and let you know. I cannot think of any reason why the filter glass should be loose, so thanks for the warning. I hope that it is OK, as it is very easy to leave detection on when changing lenses and I now have a sequence of shots that are very magenta in the corners! Mike |
#4 (permalink) |
Erfahrener Benutzer
The filter works as it should and it is neat the way it firmly attaches to the lens and then the hood to the filter. It does increase the length of the lens by around 5mm though.
I don't think the filter glass is loose but something on the inside vibrates when you blow on it. Guess I should just leave it on and stop blowing on it :-) Simon |
#5 (permalink) |
Erfahrener Benutzer
The regular Leica IR filters are made by Hoya and the glass is held in by a "C" ring - and definitely some of those have loose glass that rattles. I don't know if the version for the 18, with its special ring, is also Hoya-made.
(Not a knock on Hoya - they supply some of the raw glass for Leica lenses and partnered with Leica in developing the pressed-ASPH manufacturing process) I fixed my rattling filters by popping out the "C" ring and the glass, and putting 4 tiny drops of Elmer's Glue (woodworker's glue, for those not familiar with US brand names) on the rim of the glass - letting it dry BEFORE remounting the glass. I.E. the glue bumps did not "glue" the glass in place - but just became little soft plasticky bumpers to make the fit tighter. |
#6 (permalink) |
Erfahrener Benutzer
I was told by Leica UK that the 18mm filters are made by B&W. To be honest, it does not rattle when you shake the filter, just this vibrating sound when you blow on the back of it.
I shall just stop blowing :-) I can't see me taking it off the lens now anyway, so not really a problem. Simon |
#7 (permalink) |
Benutzer
I've been considering this lens as well but knowing that with a few hundred more euros I can get the Tri-Elmar WATE, I'm having doubts now.
Why would one choose the Super Elmar 18 over a Tri-Elmar WATE besides the price difference? Pros cons? ![]() |
#8 (permalink) |
Erfahrener Benutzer
Well, I decided to go for the 18mm as I am used to the 24mm FOV and that is of course what I get with the lens on the M8. I also decided in my own mind that there would be fewer compromises in image quality with a prime versus a three-in-one lens, although I did not have any firm evidence to support my theory!
The 18mm is definitely easier to use than the set-up requirement for using the WATE. I also figured that to get to 16mm I would take three steps back :-) Simon |
#10 (permalink) |
Erfahrener Benutzer
Just spoke to my dealer. The other 18mm filters he has had are all fine. If I shake mine from side to side it rattles as the filter glass is loose.
Yet again (as I had a bad M8.2 out of the box and a bad 18mm f/3.8 out of the box) I now have a bad 18mm filter out of the box. Leica QC is as bad as it gets right now. Simon |
#11 (permalink) | |
Erfahrener Benutzer
Quote:
Matter of fact I had used a WATE for more than a while too. I simply prefer the 18 when it's up to wide angle lenses.
__________________
Maurizio www.mauriziobeucci.com http://www.photographerspro.eu/mauriziobeucci/ http://www.facebook.com/profile.php?id=1329755400 |
#12 (permalink) | |
Erfahrener Benutzer
Quote:
#15 (permalink) |
Erfahrener Benutzer
I guess that is true. However, if I was taking pictures by the side of a road and a large articulated lorry drove past, how could I be sure that the vibrations caused by the lorry would not cause the filter glass to vibrate (similar to windows vibrating if near traffic) and that then having an adverse effect on the image quality?
Simon |
#16 (permalink) |
Erfahrener Benutzer
OK, might have to eat a bit of humble pie here!
The glass itself in the filter is not what is rattling. There is a black ring of stiff card or plastic inside the filter housing (about 5mm wide) which reduces the effective diameter of the filter by blocking off the outermost 5mm all the way round. Not sure what it is for but it is not a tight fit in the filter housing and it can be rotated quite freely. The actual glass itself does move a bit if you press on the outside and push gently, but I am OK with that as some give is necessary I would imagine. So I guess the rattling sound when you shake the filter is normal as the baffle is quite loose fitting. Simon |
#17 (permalink) |
Erfahrener Benutzer
On a personal note: I love a good blow, and oh boy would I be scared if it rattled
__________________
Sander Amsterdam Holland ' When afraid your digital M-camera is getting too wet or damp, whip out the battery. Instantly!' www.vanhulsenbeek.com sanderva.blogspot.com sanderva.zenfolio.com |
#18 (permalink) | |
Erfahrener Benutzer
Quote:
__________________
Nicole Never stand between an old bat and her Leica! |
#19 (permalink) |
Erfahrener Benutzer
ahahahaha! This is getting hot.
__________________
#20 (permalink) | |
Erfahrener Benutzer
Quote:
![]() Rocky |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
