| Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8. |
LinkBack (4) | Thread Tools | Display Modes |
#21 (permalink) | |
Erfahrener Benutzer
Quote:
It's much more difficult to access the 6bit code reader...
__________________
"Il y a trois sortes d'hommes: les vivants, les morts, et ceux qui vont sur la mer." Platon |
#22 (permalink) | |
Neuer Benutzer
Quote:
If you are still waiting, you better get yourself an analog M (while you still can) and a good scanner :-) |
#24 (permalink) |
Erfahrener Benutzer
'Never' is a very, very long time and has been the source of many famous last words.
- Carl
__________________
The M8 Metadata project Join the 2010 Leica One Challenge, Venice Italy, Saturday October 16th. |
#25 (permalink) | |
Neuer Benutzer
Quote:
If a full frame M one day sees the light, it would be in a whole new series. Not an M9, nor M9.2 ! :-) Cheers, |
#26 (permalink) | |
Erfahrener Benutzer
Quote:
I certainly agree that the 6 bit code reader along with the circuit board which drives it is probably the most difficult part of the camera to replace. In addition to the above, you have to remove the shutter, sensor, light meter, battery housing/lens throat, lens mount and so on. In these two pictures, you can see the LCD "package" between the mounting plates and also the lens sensor where it connects to the circuit board. Clamshell Rear without DSP.jpg Frame Selector 2.jpg
__________________
Mark |
#27 (permalink) | |
Erfahrener Benutzer
Quote:
I haven't opened any M8 yet, so you're in a better position to have an accurate opinion ![]() I've just repeated what the technician from Leica told me. Maybe at Leica they consider these operations as normal work. Cheers
__________________
#28 (permalink) |
Neuer Benutzer
I had the exact same thing surface on my LCD a week ago. Mine is a little smaller, and a little more oval, but the exact same issue. Very visible on light colored background shots.
I was glad to see this post because I thought I had done something to cause the damage. I take extremely good care of my equipment and have been trying to figure out what I did. At least I know it isn't something I did. Hopefully Leica will find a solution and take care of it. One more trip to NJ or Solms... |
#33 (permalink) |
Benutzer
Hi,
This was the response from Leica: Dear Mr. Hopf, We have seen this problem in the past and the only solution is to replace the LCD screen. This work can be done here in Solms. mit freundlichen Grüßen / best regards Leica Camera AG / Customer Service Solmser Gewerbepark 8 / D-35606 Solms -----Ursprüngliche Nachricht----- Gesendet: Montag, 9. Februar 2009 10:19 An: Wagner, Gerald Betreff: WG: Ghost image of sensor on LCD -----Ursprüngliche Nachricht----- Gesendet: Montag, 9. Februar 2009 02:53 Betreff: Ghost image of sensor on LCD Good morning, I own an M8 for more than 2 years now and I am very happy with the results I am getting. Recently I found an odd ghost image on my LCD when I was doing test images with my newly acquired Summicron 75. It looks like the outline of the sensor projected on the LCD. I attach 2 photos which show the effect reasonably well. This does not impact the quality of the pictures but it is a nuisance and I am concerned that it might get worse. Do you have any experience with this problem? If yes what would you suggest I should do? I hope to hear from you soon. Best regards -----------------------------------------------------Second mail asking what would happen if I don't change the LCD. For the english speaking community: "Nothing just an inconvenience" Hallo Herr Hopf, Normal ist das natürlich nicht und wir sind dabei, die Ursache zu ergründen. Passieren kann weiter nichts, wobei wir noch keine Erfahrung haben über die Zeit. Da es aber lokal am LCD liegt, ist die Kamerafunktion weiterhin gewährleistet. mit freundlichen Grüßen / best regards Leica Camera AG / Customer Service -----Ursprüngliche Nachricht----- Gesendet: Montag, 9. Februar 2009 18:25 Betreff: Re: WG: Ghost image of sensor on LCD Hallo, Danke fuer die schnelle Antwort. Keine guten Nachrichten. Was wird passieren, wenn ich mit der Kamera so weiter arbeite? Ist es normal, das das nach zwei Jahren passiert? Beste Gruesse --------------------------------------------------------------- Volker Hopf, PhD Director Blome YVH Pty Ltd Last edited by admin; 17.06.2009 at 08:26. Reason: Deleted personal data |
#34 (permalink) |
Neuer Benutzer
Does any of the M8 users, who detected the "coffee ring", permanently use a LUIGI or LEICA or any other leather case?
If so, the ring could stem from the humidity/dye/leather care in the case's leather creeping under the LCD cover. Just my 2 cents. Regards Falk61462 |
#35 (permalink) | |
Erfahrener Benutzer
Quote:
#37 (permalink) | |
Erfahrener Benutzer
Quote:
[Edit: Looks like it's made in Taiwan by this company: http://www.tpo.biz/index.htm]
__________________
Mark Last edited by marknorton; 17.06.2009 at 08:50. |
#40 (permalink) |
Erfahrener Benutzer
Hahaha...that's a good one, are you related to Bill Gates?
__________________
Best Regards Alexander Tufte www.alexandertufte.com www.icelandworkshop.no www.galerielux.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/leica-m8-forum/79713-new-m8-issue-coffee-ring.html
| Posted By | For | Type | Date | |
| Cost to replace an M8 LCD screen - Rangefinderforum.com | This thread | Refback | 20.06.2009 00:34 | |
| Cost to replace an M8 LCD screen - Rangefinderforum.com | This thread | Refback | 18.06.2009 16:52 | |
| Cost to replace an M8 LCD screen - Rangefinderforum.com | This thread | Refback | 16.06.2009 23:06 | |
| Cost to replace an M8 LCD screen - Rangefinderforum.com | This thread | Refback | 16.06.2009 22:58 | |
