| Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8. |
#1 (permalink) |
Erfahrener Benutzer
I've got an M8 with the voigtländer 15mm which shipped with a 15mm viewfinder. I've marked the lines with a pen what works out well but I don't like the finder on when using my other lens. And taking the finder on and off is tough as it is stuck very firmly. It's almost raping the camera…
As I plan to by a 21mm lens and came across the leica 21-28 viewfinder I wonder if this is the solution. The wheel should make the switching easy. Any experiences with that finder? Thanks, Sven. |
| Advertisement (gone after free registration) |
#2 (permalink) |
Erfahrener Benutzer
It is nice and clear, but the framing is not very exact. I like using it. A common complaint is the shoe working loose, but that should not deter you from buying; A competent repairman can easily and cheaply fix that.
#3 (permalink) | |
Erfahrener Benutzer
Quote:
Look at the bottom of this page: Ricoh GR-Digital Review: 2. Body & Design: Digital Photography Review It also is (a lot) cheaper!
__________________
Sander Amsterdam Holland ' When afraid your M8 is getting too wet or damp, whip out the battery. Instantly!' www.vanhulsenbeek.com sanderva.blogspot.com |
#5 (permalink) |
Erfahrener Benutzer
I tried a RICOH- finder and found, the base is positioned differently from LEICA- finders.
The angle of your view might not be a problem with a w/a-lens, but it covers the speeddial and makes cameracontrol not easier. In >>A<< mode, it´s perhaps o.k. but for manual operation it is a nuicance. I was planning to use it with an M6 and sold it again ... Best |
#6 (permalink) | |
Erfahrener Benutzer
Quote:
I use the 15mm CV finder too but I don't it particularly difficult to put on or take off. The early M8 hotshoes were notoriously tight so I suggest lubricating the hotshoe mount and the finder foot by rubbing the contacting parts with the (graphite) lead of a black pencil for a while to see if that makes it easier. The softer the pencil the better and no less than, say, 2B. (Make sure to clean away any graphite dust that's left over because it's carbon and therefore conducts electricity.) Pete.
__________________
Eur. Ing. Pete F@rnsworth Live and let live. |
#7 (permalink) |
Erfahrener Benutzer
Having lost one CV 28mm finder during the scrum of a G.W. Bush event, I now put a strip of gaffer tape across the back of the replacement.
I use the CV 28 finder for the 21 lens, a CV 21 finder for the CV15 lens and the CV15 finder collects dust unless I use the 15 on my MP, or until I get a CV12, which is doubtful. Every time a finder goes into a hot shoe it gets taped down. I can re-use a little strip of gaffer tape -- which i stick across the top of the finder when not in use -- 8 or 10 times before I need a new strip. |
#8 (permalink) | |
Erfahrener Benutzer
As nobody has the same problem with too firmly sticking viewfinder I guess it may wear out after more use. Both the camera (M8.2) and the 15mm are new.
With the lens I got two problems: Framing (without finder) and "falling verticals". So I'm thinking of a spirit level, too. If I get a two-shoe adapter the fixing problem moves from the finder to adapter. Are there any alternatives to the "thumps up"? Quote:
thanks, Sven |
#9 (permalink) |
Erfahrener Benutzer
I have the 21-24-28 viewfinder and very rarely use it. On an early M8 I had the problem of a very tight shoe - used used a spot of ptfe loaded oil to help with that. The screw down foot clamp will scratch the top of the camera shoe. The two biggest problems I found were inaccurate framing and focus change as you switched the field of view. The framing depended on eye position, you have to get it dead central and the frame edges were not clearly defined. My eyes have limited accommodation and I found the strength of the diopter correction lens needed changed with focal length selected. If your eyes are able to focus from close to far distances easily then you may not notice this problem. I tried several viewfinders in a dealers and all suffered from this to some extent. I now use separate viewfinders or the "Frankenfinder" for the Wide Angle Tri Elmar.
Bob. |
#10 (permalink) | |
Erfahrener Benutzer
Quote:
No chance for field tests yet, but if the framing in half-way decent, I may pull off the shoe (easy to do), do a little filing, and re-attach the shoe with just 2 of the 4 mounting screws so that the shoe is on the viewfinder centerline. |
#12 (permalink) |
Erfahrener Benutzer
I find that is dependent on the way you look for the thing. It is inexact enough to let you move your eye around a bit and get the whole picture.
#13 (permalink) | |
Erfahrener Benutzer
Quote:
Do you mean that you marked the lines for a 21mm frame? If so, how did you locate this frame on the finder. I'm about to get the CV15 for an M8.2 that should arrive tomorrow but don't want to buy a 21mm finder because I have two in Bangkok, but won't get there until May and need a temporary solution. Is it possible to to frame with the outside of the frame of the M8 viewfinder? —Mitch/Paris Bangkok Hysteria©: Book Project - a set on Flickr |
#14 (permalink) | |
Erfahrener Benutzer
Quote:
#15 (permalink) | ||
Erfahrener Benutzer
Hi Sven,
Quote:
The Leica 21-24-28 finder is no bad, but it is bulky. If you need only one focal length, the Leitz SBKOO/12002 is good, metal body and small. The Zeiss is the best, but quite big and... very expensive. Quote:
http://www.l-camera-forum.com/leica-...tml#post731852 (and the illustration @ Post #19) |
#16 (permalink) | |
Erfahrener Benutzer
#17 (permalink) | |
Erfahrener Benutzer
Quote:
Once you get used to it it isn't nearly as bad as it feels at first :-) |
#18 (permalink) | |
Erfahrener Benutzer
Quote:
You need to allow for curvature of the front element so as to get the lines straight through the viewfinder but I did this over a year ago and haven't needed to replace it despite rain and being pulled in and out of its bag. Pete.
__________________
#19 (permalink) | |
Erfahrener Benutzer
Quote:
#20 (permalink) | |
Erfahrener Benutzer
Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
