Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
090909 Promo
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
LinkBack (3) Thread Tools Display Modes
Old 22.08.2008, 11:51   #21 (permalink)
Erfahrener Benutzer
Default Re: Nikon SB 900 and the M8
Jamie after reading the links provided in this thread and looking at my SB800 I would say the SB900 is not going all the way into the M8 hot shoe. It's going in far enough for the center and back pins on the flash to hit the center and back contact on the M8, the center and back contacts on the M8 are longer, but not for enough for the locking pin and hole to line up.
This could be caused by a tight shoe and thicker plate on the flash or the plate is hitting 45° on the M8 body.
On my SB800 and M8 I can look down inbetween the flash and the body to see the plate hitting the post at the front of the shoe. I suspect you can do the same with the SB900, yes I need a second pair of reading glasses to see this clearly (Just call me six eyes).
Looking at some of the comparison images of the 800-900 it seems there is less clearance between the inside of the plate and the plastic body of the flash on the 900 then on the 800. this couls also casue the 900 to fit tight in most shoes.
Shootist is offline   Reply With Quote
Old 23.08.2008, 15:57   #22 (permalink)
Erfahrener Benutzer
OK, I've now got my SB-900 and it's a remarkable flash, Nikon are certainly on a roll.
Mine fails to lock on the M8 as well, fine on a D3, D2x, D100; does not lock on a Digilux 2 and M8, so clearly Leica's interpretation of the ISO standard is different from Nikon's. An SB-800 locks fine and the difference between the two is that there is more lateral play on the locking pin on an SB-800 (and an SB-80 too) so that these will lock. An SB-26, where there is next to no lateral play, will not lock, just like the SB-900.
My SB-900 is in pieces (what did you expect?) so I'll see if we can get more lateral play on the locking pin...
__________________
Mark
marknorton is offline   Reply With Quote
Old 23.08.2008, 16:16   #23 (permalink)
Erfahrener Benutzer
How about filing a slot in the front of the flash shoe, to go around the screw/post in the front of the M8 shoe. So that you can push it in a little farther. You might also need to file a angle on the left side of the flash shoe so it doesn't hit the angle of the top plate of the M8 that is in the shoe area.
Doing either or both of these things will not interfere with how the flash works, IE the pins on the flash.
Old 23.08.2008, 20:10   #24 (permalink)
Erfahrener Benutzer
Indeed; there are two options; fractionally enlarge the locking pin hole in the M8 hot shoe or, maybe easier, file a small round at the front of the metal flash foot, a fraction of a millimetre deep where it strikes the M8 screw at the front to allow the hot shoe to sit very slightly forward.
Increasing the lateral play of the pin is not really an option.
To release the shoe on the SB-900, remove two screws on each side and disconnect a connector. Removing the 4 screws you can see inside (unhook the spring to get at one of them) allows the plate to be detached; the M8 post will have left a mark where you need to file.
The round I filed is about 1mm wide and less than 0.5mm deep.
Another thing to notice is that as the flash is mounted on the camera, the weight tips it forwards in the shoe; Tilting the camera back helps the pin to engage.
My SB-900 now locks perfectly with all three M8s.
__________________
Mark
Old 24.08.2008, 05:28   #25 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by Jamie Roberts View Post
David--
..... It won't, for example, let me dial in f1.6 at ISO 800--it considers that silly, I guess, which it is, if you're directly using the flash.
Its not silly, Jamie. Its all about extending the photographer's scope. Thanks for doing the groundwork. I might just go for the SB900(Canon user myself)
Alex
lxlim is offline   Reply With Quote
Old 24.08.2008, 05:31   #26 (permalink)
Erfahrener Benutzer
Ah, Mark. Bear in mind this is a Leica forum, so if disassembled images of SB900(s) may not meet the approval of the moderators. But I do look forward to the dissections.
Old 24.08.2008, 09:36   #27 (permalink)
Erfahrener Benutzer
No, I'm, not posting pictures of the SB-900 - I only removed the hot shoe foot in the end. I've modified the foot plate as I described and it locks perfectly with the M8 and D3, so it's done.
Great flash, makes the SF-24D look ridiculous in terms of scope and cost.
__________________
Mark
Old 24.08.2008, 16:41   #28 (permalink)
Erfahrener Benutzer
Actually, from the results I'm seeing, it makes most of them look pretty bad by comparison, though truth to tell I haven't used the newest Metz stuff yet...
FWIW, and one more confusing data point, the flash locks perfectly onto the DMR, too.
Mark--thanks for the instructions on flash foot. I'll take it to someone who knows how to do it
__________________
James H (Jamie) Roberts
Site: James Roberts photography
Blog: James Roberts wedding photography blog
Jamie Roberts is offline   Reply With Quote
Old 24.08.2008, 17:19   #29 (permalink)
Erfahrener Benutzer
Jamie, check whether it locks if you tip the camera back after sliding it into the hot shoe. Mine didn't, but as I filed more away step by step, it started to lock when I tipped the camera back but not when tipped forwards. It now locks whatever the orientation.
It's down to the amount of lateral free-play in the locking pin and the chamfer at the end of the pin which allows it to "find" the locking hole. We're talking fractions of a mm here.
__________________
Mark
Old 25.08.2008, 01:38   #30 (permalink)
Erfahrener Benutzer
robsteve's Avatar
Jamie:
If it is like some other flashes, you may have to make an indent in the Nikon shoe to accept the little screw on the Leica shoe. This way it will slide in further and the locking pin will engage.
This screw in the hot shoe is specific to Leica M, not the R. This is why it fits fine on the DMR. The older accesories for the M system have a little indent to make space for this screw. I don't have my SF-20 handy, but I bet it or the SCA shoes have the indent for this stop screw.
Robert
robsteve is offline   Reply With Quote
Old 25.08.2008, 02:25   #31 (permalink)
Erfahrener Benutzer
rafael_macia's Avatar
Nope--but that's next for sure. Should be fine with the right Nikon peice...
Of course, I'd rather not use a bracket to begin with...
FWIW, attached to a Wein Safe Synch, the whole thing is still pretty iffy...
I haven't advanced to beyond a 283 yet,but here it is on a modified Leica bracket.
I have always not liked the idea of mounting a flash in the cameras hotshoe. Leica made a nice bracket CTOOM, and it can be adapted for an M8
rafael_macia is offline   Reply With Quote
Old 25.08.2008, 04:11   #32 (permalink)
Erfahrener Benutzer
The only thing beyond a 283 is a 285 <G>
Cheers,
__________________
Sean Reid
http://www.reidreviews.com
sean_reid is offline   Reply With Quote
Old 25.08.2008, 05:42   #33 (permalink)
Erfahrener Benutzer
Quote:
Interesting that previous shoe accessories have the indent - which is effectively what I've added to my shoe foot. The SF-24D does not have this indent, but does lock on a Nikon D3 (looks ridiculous) because the pin hole on the D3 is over-sized.
Looks like combination of the hole being the minimum size and the presence of that screw makes it a problem on the M8.
__________________
Mark
Old 25.08.2008, 16:15   #34 (permalink)
Erfahrener Benutzer
Yes--that's it entirely. It's amazing to me that the new Nikon off-camera-cord "just works" though, while the SB 900 doesn't.
And for me, no amount of tipping the flash will get it to lock. So it's the file for me
__________________
Old 25.08.2008, 17:26   #35 (permalink)
Erfahrener Benutzer
Jamie
Here's a picture of my hot-shoe foot modification...
__________________
Mark
Old 26.08.2008, 00:21   #36 (permalink)
Erfahrener Benutzer
Mark--
Bless you Thanks!!
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/leica-m8-forum/61485-nikon-sb-900-m8.html
Posted By For Type Date
Misc M8 Questions - Page 2 - The GetDPI Workshop Forums This thread Refback 10.04.2009 12:13
Misc M8 Questions - The GetDPI Workshop Forums This thread Refback 09.04.2009 19:23
Misc M8 Questions - The GetDPI Workshop Forums This thread Refback 09.04.2009 18:58
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
