Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 07/09/08, 08:18 AM   #1 (permalink)
Erfahrener Benutzer
Default Battery capacity Test for M8 battery
Few weeks ago I have ordered 2x HK Battery which many people said good and bad.
I asked my friend to modify my old trusty charger Powerex MH-C777Plus-II charger which I used to charge a lot of nicad battery and lihium eg. Nikon D1H battery, Sony camcorder, Phaseone battery etc. to connect M8 battery.
Please find the attached picture.
The reason I modify the connector of this charger because it is able to discharge and recharge automatic by self adjust voltage and show the capacity by digit.
I have 2 Leica original batteries and 2 HK batteries.
After run the test twice in each battery. I can conclude that.
1. Each battery has slightly capacity.
2. Leica battery both has over 1900 mAh. 1st ~2500, 2nd ~ 2300
3. HK battery 1st ~ 1700, 2nd ~ 2000
I don't know about the battery life. Time will tell.
It seems Leica has better capacity than HK slightly but big price different.
kitty
Kittyphoto is offline   Reply With Quote
Old 07/09/08, 11:44 AM   #2 (permalink)
Erfahrener Benutzer
Default Re: Battery capacity Test for M8 battery
I think you will also notice that the aftermarket batteries do NOT register on the M8 meter like the real Leica batteries.
With aftermarket batteries you need to fully discharge them and then recharge for the M8 meter to show 3 bars. Otherwise the M8 will only show 2 or even only 1 bar even though the battery is fully charged. This could be due to the lower capacity of the aftermarket batteries.
As for the overall running time of the camera I find both makes of batteries give the same usage.
Having said all that I don't use my aftermarket batteries anymore. I do have them fully charged and in the bag for the Just In Case scenario.
Shootist is online now   Reply With Quote
Old 07/09/08, 12:13 PM   #3 (permalink)
Erfahrener Benutzer
Mauribix's Avatar
Even if the mA capacity should be slightly different, usually the durability difference should be exponential when related to the same power use (not constant by the way).
i.e.
the durability of a 2000mA vs 2500mA battery is not just 20% less, it should be something getting more and more evident as the use goes on.
I guess Mark (Norton) should be able to calculate it exactly.
Anyway, I just bought once an HK battery (3 times cheeper than Leica's), but that never made my day, so I bought 2 other original ones, and I'm quite happy with them.
__________________
Best Regards
Maurizio
www.mauriziobeucci.com
Mauribix is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
