| Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8. |
#1 (permalink) |
Neuer Benutzer
I was under the impression that once you make an EV adjustment with the menu option, that the adjustment should remain unchanged until you go back in and change it; however, that's not what's happening my case. After I take the shot, it automatically resets to 0 every time.
Per the manual: "Particularly when taking several pictures in succes- sion, e.g. if you want a series of pictures to deliberate- ly have a slightly lower or higher exposure for a partic- ular reason, exposure compensation is a very useful function. Unlike Metering memory lock, once set it remains effective until you (deliberately) reset it..." Is there something I'm missing here? I usuallu shoot in Aperture mode. Last edited by suden : 07/03/08 at 12:38 PM. |
| Advertisement (gone after free registration) |
#2 (permalink) |
Erfahrener Benutzer
I have noticed that if i change some settings in the camera, and subsequently the camera 'hangs' and I have to pull the battery out, it occasionally resets to what was there before.
I presume this is because the camera doesn't write the altered settings to persistent memory until it receives a normal shutdown event (like you switching it off). If my supposition is correct, you might be able to work around your issue by switching the camera off and back on again after setting the EV adjustment. Let me know if it works ![]() David. |
#3 (permalink) |
Erfahrener Benutzer
I once set my M8 to -2/3EV. I've never touched that setting ever since, and it stores the value even when changing batteries. I have no clue whats going on with your camera and would show it your dealer. Cheers, Claus
#4 (permalink) |
Erfahrener Benutzer
There is nothing you are missing. Once you set EV to whatever it should stay. Unless you have set one of the User Profiles to NO EV comp and you then select that User Profile.
#5 (permalink) |
Moderator
I have 2 M8's, permanently set @ -2/3EV. Many switch offs, battery removals, card swaps, etc have not changed those settings, unless I change them, which I do occassionally.
I think you may have a problem of some kind, or I do. ![]()
__________________
Cheers, Erl Inventor of the StreetShooter for Leica M's Currently available at www.showplace.com.au/Streetshooter.html |
#7 (permalink) | |
Erfahrener Benutzer
Quote:
Otherwise whatever setting you change, in either menu options, should always stick. |
#8 (permalink) |
Neuer Benutzer
Hmmmm...I just tried setting a user profile and then setting the EV to -1/3 from a 0 setting. When I changed the EV I noticed that the user profile setting automatically changed from Profile 1 to Profile 0. This is something that I've really noticed before but then again I've not really used the EV adjustment very often.
#9 (permalink) | |
Erfahrener Benutzer
Quote:
That suggests there may be a problem with your camera. Try RESETTING all settings (Reset in the Menu button menu) and then reloading the firmware. After that make some changes to either menu and save it a a User Profile any profile will do. Load that profile, if it isn't automatically loaded, and then make one change to either menu and see if the User Profile goes to -. If it doesn't and it again goes to UP 0 then you have a problem that need to fixed by Leica. |
#10 (permalink) | |
Neuer Benutzer
Quote:
| Thread Tools | |
| Display Modes | |
