Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
Old 06/23/08, 03:04 PM   #1 (permalink)
Erfahrener Benutzer
Default The green zone
I saw something green in my M8 shots, so I used an expodisc and captured as many different stops as I could from black to clipping. The white balance was manual in the camera, adjusted with the expodisc at auto exposure.
The zones -3, -4 and -5 was green and noisy, the other zones was fine and very close to perfect gray. I tried this at ISO 160 in Lightroom, C1 and RAW developer.
Have any of you experienced this?
Best Regards
Henrik
ammitsboel is offline   Reply With Quote
Old 06/23/08, 03:44 PM   #2 (permalink)
Erfahrener Benutzer
Default Re: The green zone
Um, no...I've done similar tests for profiling neutrals, and didn't see this.
What lens were you using? Is it coded? Oh--and what lighting and target?
PS--my *guess* is you underexposed the shot badly or mis-used the expodisc, which is easy to do with the expodisc on auto. You should be trying to push the expodisc exposure into the mid-upper quartertone, not a midtone (*around* RGB 200 200 200 in sRGB). Much easier to do on manual
__________________
James H (Jamie) Roberts
Site: James Roberts Photography
Blog: Photography behind the scenes
Jamie Roberts is offline   Reply With Quote
Old 06/23/08, 04:11 PM   #3 (permalink)
Erfahrener Benutzer
Thanks, this is what I did.
I put the expodisc in front of the lens, adjusted WB manually with auto exposure.
I then did a series of exposures from -4 to +4 for capturing the full range of the M8.
The lens is a new summilux 35mm with UV/IR. The test was done in a bright sunny day in the shadow.
Did I do something wrong? isn't it valid to determine color cast in the noise this way?
/Henrik
Old 06/23/08, 04:17 PM   #4 (permalink)
Erfahrener Benutzer
Aha!
So the expodisc might not be valid at RGB 1 to around 100?
Old 06/23/08, 09:47 PM   #5 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by ammitsboel View Post
Aha!
Exactly... I would expect it to yeild some rather poor results in the shadows with that kind of exposure (which is what you got ) Try it with a higher level of exposure on the expodisc.
__________________
Old 06/24/08, 01:08 AM   #6 (permalink)
Erfahrener Benutzer
Thanks Jamie, the idea was to capture the different zones to get some kind of idea of the tone curve in different raw converters and maybe do some calculations to make a linear one. But I guess I'll have to use something else than the expodisc for this.
I tried shooting a scene in -5 stop and bossting it to see if I could see any green, and nothing appeared so I guess I'm ok.
Best Regards
Henrik
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
