Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
Old 06/05/08, 09:38 PM   #1 (permalink)
Neuer Benutzer
Default Advice for an M8 rangefinder newbie
I received this beautiful camera yesterday and have been playing around with it and doing some comparison shots with my 5D and it is definitely a different beast altogether, that's for sure.
That said, there are things I really love about the M8 (the solid build, the deliberate *thunk* of the shutter when you take a shot, and just the feel of getting back to basics to name a few).
And then there are some things that I have questions about...the white balance is very inconsistent (I have it set to automatic and it seems to vary almost from shot to shot) and many shots taken in low light tend to look somewhat muddled and too often have a red tint/hue.
I am aware of the IR issue, but I'm kind of surprised that this issue surfaced so quickly (if, in fact that's what this is) as in my research, it seems to be an infrequent occurance that only occurs once in a while and mainly with black and gray synthetics whereas I see it across the entire image. As a side note, I do have the current firmware installed. Also, I have the lens detection set to "on" now...correct me if I'm wrong, but I think it's supposed to be set to "ON + UV/IR" only if you have the IR filter attached (haven't sent away for my free ones from Leica yet). Anyway, I had the lens detection set to "on" initially, and discovered that it somehow gotten set back to off-perhaps that will make a difference as well.
I also have it set to RAW, which is what I normally shot in....as well as aperture priority mode which is what I prefer to shoot in given the choices.
I am also having a lot of issues with focusing-especially using a narrow depth of field. I've tried several test shots and nothing is anywhere near sharp....very soft and the focus is lacking. Not sure if it's me or the camera at this point...although I have a feeling it's probably me-I guess it's been a while since I've gotten back to the basics of photography...talk about a humbling experience! I plan to take it out and shot some landscapes and buildings, etc. later today.
In the meantime, here's a couple of links to two test shots-any input would be greatly appreciated. These are the .jpg's, so they have a little in-camera processing and they were both shot in Aperture priority (which is what I usually shot in). There is no aperture info listed in the exif (I thought the lens detection fixed this...?) but I think I shot the yard at f/8 or f/11 and the porch at f/4. If you click in the original size, you will see that really nothing locks focus in either shot-I was focusing on the arm of the chair in the porch shot just fyi.
M8 test shot on Flickr - Photo Sharing!
suden is offline   Reply With Quote
Old 06/05/08, 10:07 PM   #2 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Default Re: Advice for an M8 rangefinder newbie
Welcome!
IR - it is nearly omnipresent and messes up the colour rendering of nearly everything. I bought a new lens recently and was really unhappy until I got the filter.
For excellent AWB load the newest firmware. You should have 1.201
Focussing : make sure your eyesight is excellent. For a range finder you need to correct the dioptre to your eyesight. Small aberrations which you did not notice until now will show up.
For the rest: practice. There are some camera/ lens combo's out there that misfocus, but don't jump to that conclusion without extensive testing.
And - have fun!
__________________
Jaap
WWW.JAAPVPHOTOGRAPHY.EU
Skype: JAAPVPHOTOGRAPHY
jaapv is offline   Reply With Quote
Old 06/05/08, 10:12 PM   #3 (permalink)
Erfahrener Benutzer
Jaap,
FW should be 1.201,
Everything that Jaap said, send off for those filters right away,
Jeff
delander is offline   Reply With Quote
Old 06/05/08, 10:14 PM   #4 (permalink)
Neuer Benutzer
Thanks for your replies...I just updated the firmware last night, so hopefully that will do the trick. I think that the diopter adjustment is ok...not sure how to adjust that...?
I forgot to mention that I purchased the Summarit 35mm f/2.5 lens with the M8 as a "kit" (wanted to take advantage of the current rebate)!
And thanks for the warm welcome...glad to be here!
Oh, do you have any issues with lens flare of reflections with the IR filters that Leica supplies? I always use a multicoated UV filter on my lenses and purchased one to go on my Summarit lens when I got the camera.
Old 06/05/08, 10:17 PM   #5 (permalink)
Erfahrener Benutzer
jaapv's Avatar
You can adjust it by screwing in diopter lenses. I use the Megaperls 1.15x diopter to make focussing easier on my ageing eyes.
__________________
Jaap
Old 06/05/08, 10:18 PM   #6 (permalink)
Moderator
andybarton's Avatar
Welcome to the forum!
You cannot adjust the dioptre on camera, unless you use separate screw-in adjustment lenses. Otherwise, you have to do it "on face".
Judging by your Flickr posts, you aren't having too many problems. Be sure to share your M8 work (in the Photo section here), when you feel ready
__________________
Cheers,
Andy
___________________________
2008 Spring Collection now released
andybarton is offline   Reply With Quote
Old 06/05/08, 10:18 PM   #7 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Quote:
Originally Posted by delander View Post
Jaap,
FW should be 1.201,
Jeff
Sure, Jeff Typo... A long day at work. I'll edit it.
__________________
Jaap
Old 06/05/08, 10:25 PM   #8 (permalink)
Erfahrener Benutzer
luigi bertolotti's Avatar
Well, compliments for your new M8, first of all ! And welcome here, too.
Your questions require ather questions to you... first of all, which lens did you use ? and was it coded ? (the code is a 6 black and white "dot string" engraved into the lens flange). If it isn't, no reason to set lens detection ON, and if you set it ON with uncoded lenses, maybe can happen that it has some instabilty, even if i cannot remember to have read something about. Btw, the lens aperture is not, definitely, available in the EXIF data, for the simple reason that the camera hasn't a sure system to "know" the aperture itself , there is no coupling of the diaph ring to any device that can record it (to be precise, camera software does compute an "estimated aperture" and records it somewhere, but the value isn't precise, and Leica decided apparently not to make it available in the exif editable data).
Focusing: sorry but I cannot make any constructive consideration... I'm not familiar with flickr images... don't know how to enlarge them to give a look at focus... my only observation is that the arm of the chair looks jagged... is the pic the original jpg from M8 or a jpg converted from RAW in some editing tool like PS or similar ?
IR issue: no doubt that it's probably the M8 point that is most striking at first : before acquiring my M8, I red about it, saw some example... my inner thought was "oh, well, sometimes, maybe...", then when in one of my first pics taken with M8, no filter, I shoot my daughter in a blue gown... ouch ! a n awful violet ! Ok, IT'S really a problem: so, to make it simple, the rule is "mount always the UVIR filter, period".
White balance: has been a problem for many, and for me too, but general consensus is that with the last firmware release it has been rather well tuned : personally, I prefer not to use AWB in standard daylight or incandescent lamps in interiors, but observed anyway that some vary situations I got with AWB prior to the last firmware update have disappeared... but my problem is that I haven't direct comparision with other digital cameras... M8 is my only digital... you have a 5D... I do not find it strange that you have the feeling of a different, and possibly less stable AWB behavior.
Go on, take other pics, and, if you like, post some issue directly as attached images in your post (it's easy to learn how to make it)... and, of course, when you'll get some NICE pic, post them in the photo section !!!
luigi bertolotti is offline   Reply With Quote
Old 06/05/08, 10:26 PM   #9 (permalink)
SJP
Erfahrener Benutzer
SJP's Avatar
It looks like you have a 35/2.5 summarit from the EXIF data? If so are you using a lens hood? If not it could be flare. Any summarit users out there to confirm this hypothesis?
The sharpness itself looks OK to me - but the images are a bit small to really judge. I tried examining the actual file for the yard but that did not help much.
__________________
Stephen
________________________________________________
my flickr site
SJP is offline   Reply With Quote
Old 06/05/08, 10:27 PM   #10 (permalink)
Neuer Benutzer
Thanks...of course, only two most recently posted are from the M8 (the test shots)...the others are from my trusty 5D...which I am thinking of selling to help finance the M8-unless I win the lottery..then I could keep both!
Of course, I'd better learn to use it first...I still can't figure out what I'm doing wrong with focusing...should I have set it to infinity for the yard shot? There's got to be an easier way to achieve focus...I mean, Rangefinders synonymous with street photography which requires some fast focus skills to say the least. I know the theory of zone focus, but I'm a bit fuzzy on it. Feel like a need to enroll in photography 101 at this rate! LOL
Old 06/05/08, 10:33 PM   #11 (permalink)
Neuer Benutzer
No lens hood...yet! If you click on where it says "all sizes" above the photo, it will take you to a page where you can choose "original size" then you can see that it's actually totally out of focus
Even better, here's the direct links for both:
http://www.flickr.com/photos/susande...03233/sizes/o/
http://www.flickr.com/photos/susande...n/photostream/
Old 06/05/08, 10:43 PM   #12 (permalink)
Neuer Benutzer
Aha...well, I will change the lens detection setting right away as I definitely have a coded lens attached....that very well could make a difference.
Per the IR issue...guess it's more prevalent than I thought and I'd better register and send off for my filters...I just hope that don't present a problem as far as lens flare and picking up reflections too much...guess it's a matter of which one you'd rather live with.
If you see my other post, I provided direct links to the original files of the test shots...these are jpg files, but I always shoot in RAW.
Thanks again for everyone's help and input so far... you make me feel right at home here!
Old 06/05/08, 10:43 PM   #13 (permalink)
SJP
Erfahrener Benutzer
SJP's Avatar
Weird, for some reason the links do not seem to work (no permission to see this page) & viewing your photostream the other sizes option does not seem to be available (works fine for my own photo's on flickr).
Are you sure you have fully mounted the lens (i.e. you hear the click of the locking lever)? This has happened before & could also explain loss of sharpness. If you are focussing at f/11 basically anything goes because the depth of field is so large.
__________________
Stephen
my flickr site
Old 06/05/08, 10:46 PM   #14 (permalink)
Erfahrener Benutzer
stunsworth's Avatar
Welcome to the forum.
The latest version of the software made a big improvement to AWB.
Focussing is down to practice I'm afraid - if you've used a rangefinder camera before I apologise for being patronising <grin>.
__________________
Steve
Website - www.steveunsworth.co.uk
Picture a week - http://www.steveunsworth.co.uk/PAW_blog/?page_id=9
stunsworth is offline   Reply With Quote
Old 06/05/08, 10:49 PM   #15 (permalink)
Neuer Benutzer
I just checked my Flickr settings and apparently you have to have a Flickr account and be signed in to get to the "all sizes" page...sorry...that's news to me! I will try to figure out a way to post the files directly to the forum.
Old 06/05/08, 10:54 PM   #16 (permalink)
Neuer Benutzer
Nope, I am a bona fide rangefinder virgin...but what's bugging me is how hard can it be to focus on something...especially if it's immobile?! Again, I am humbled by this experience so far...and determined to figure it out! Guess I've just gotten lazy with DSLR's and using AF the majority of the time.
Old 06/05/08, 10:55 PM   #17 (permalink)
SJP
Erfahrener Benutzer
SJP's Avatar
you need to set 'download' to 'anyone' then it should work:
Quote:
When people are looking at the main display page for one of your photos or a video (e.g.), they will see a button labeled "all sizes" underneath the title. From there, they can download any of the different sizes available, including the original file, unless you choose to prevent it.
Preventing people from downloading something also means that a transparent image will be positioned over the image on the main photo page, which is intended to discourage* people from right-clicking to save, or dragging the image on to their desktop.
If people are unable to access a photo or video of yours -- for example if you've marked it as private -- they won't be allowed to download the original either.
People with free accounts aren't able to offer their original files for download.
__________________
Stephen
my flickr site
Old 06/05/08, 10:57 PM   #18 (permalink)
Neuer Benutzer
Ok! I think it was a setting that I missed and I fixed the Flickr thing...you should be able to see the images if you give it another try! Sorry and looking forward to more of your comments!
SJP: we must have posted right at the same time!
Old 06/05/08, 11:00 PM   #19 (permalink)
Erfahrener Benutzer
Daniel Ortego's Avatar
Welcome Suden,
You’re in luck because I was exactly like you not long ago when I couldn’t focus a damn thing! I was certain that my camera and/or lens was the culprit. There was no way that I could shoot an entire session without one keeper’. As it turned out, I simply didn’t understand the basics. Now, I’m shooting and smiling. When you first nail it, the feeling is unforgettable! There is simply no other camera that provides as much personal satisfaction as the Leica with a quality lens. Ok, IMHO of course.
Regards,
__________________
"Live as though you were going to die tomorrow and learn as though you were going to live forever."
~ Mahatma Gandhi
Daniel Ortego is offline   Reply With Quote
Old 06/05/08, 11:02 PM   #20 (permalink)
Erfahrener Benutzer
stunsworth's Avatar
Quote:
Practice I'm afraid. To gain some confidence try shooting at something like f8 to start with, that'll give you lots of depth of field. And make sure the lens has firmly clicked into place.
__________________
Steve
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBu
