| Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8. |
#1 (permalink) |
Erfahrener Benutzer
I have a strange behavior with my M8.
It suddenly resetted the counter, so the images started at 1 again. When I switch the camera on, is states I can still stores about 440 images on my 2G card, although I have DNG selected. But after the first shot it jumps directly to 130 left. Anyone seen this behavior before? Reinier |
#2 (permalink) |
Erfahrener Benutzer
First format the card in a PC using FAT, NOT FAT 32, Then follow these instructions.
Here is a procedure that will allow you change to anything you want: 1. Set the Picture Number in the menu to "Standard". 2. Format the SD card in camera. 3. Reset the File Number in the menu. It actually says “Reset fold. No”, that is the one you want. 4. Set Picture Number back to "Continuous" 5. Take one image 6. Shut off camera, remove SD card and place in card reader attached to a computer. 7. Access the image in your Finder or Explorer (Mac or PC); rename the image number to whatever file number/image number you want. I would suggest Lyyyxxxx, with "y" being your preferred folder number (See Note Below) and "x" being the frame number you want to start with. (You are making these changes to the file name on the card in the card reader.) NOTE If you want to change the first or second digit of the L100 (Lyyy above) in the file name, like to L200 or 120 or 220, then you have to change the folder name also. The directory/folder structure on the card when in a card reader is [Drive Letter]:\DCIM\100LEICA\. You need to change the 100LEICA to whatever you want the file number to start with. Like if you want it to be L200xxxx then you need to rename that folder to 200LEICA. If you want L120 then you need to change that folder name to 120LEICA. It would look like this [Drive Letter]:\DCIM\120 or 200LEICA. 8. Properly remove card from card reader and return to camera. 9. Turn the camera on and press "Play". The file will now display with newly renamed folder and file number. (Use "Info" to see this data.) 10. Expose another image to confirm and check file numbers. 11. Format SD card, and you are good to go from that point on. |
#3 (permalink) | |
Erfahrener Benutzer
Quote:
Always first format a new card in your camera! And do reformat that card in your camera too! Last edited by vanhulsenbeek : 05/17/08 at 04:02 PM. |
#4 (permalink) |
Erfahrener Benutzer
Yes that worked, thanks. I asume that out of the box they will be formated FAT32?
I bought 5 more 2G cards for my backpack trip to greenland this summer. Is easer to carry than an Image tank and much cheaper at current prices (8euro!) as well And I bought two more batteries. Sould take me trough the 3 weeks I guess. Just to be sure I will also carry a M3 and some film... |
#5 (permalink) | ||
Erfahrener Benutzer
Quote:
Quote:
You get about 2GB's of images per battery IF you don't leave the camera on all the time and you don't review images. Otherwise I would bring more batteries and a charger. |
#6 (permalink) |
Erfahrener Benutzer
I could take a charger but I'm afraid there will be no power-outlet in my back-pack
It should give about 250-300 shots (preview off) per battery so about 900 shots. I think it will do and else I still have the M3. Also I bought the upgraded non-original batteries (1800mAh instead of 1700) but that will probably just compensate for the low temperatures Last edited by imported_reinierv : 05/17/08 at 05:28 PM. |
#8 (permalink) | |
Erfahrener Benutzer
Quote:
I am not sure this book: Fotoboek Poollicht - Jolanda Linschoten • De Zwerver will provide you with necessary tips, but I could bring you in contact with the writer. If you aren't already ![]() |
#9 (permalink) |
Erfahrener Benutzer
That photovoltaic pack looks great, I will carry it next to my 70+15ltr backpack I guess. But you do remind me that the Leica charger indeed has a 12v option. Just may there is something that will do.
I'm afraid there will not be much polar light to see in juli. I hope there is, I really would love to see it, but there is hardly and dark period then I would like some phototips, certainly on expiriences with equipment. I'm not fearing it too much though, the temperature is not that extreme in Juli (0-20C). |
| Thread Tools | |
| Display Modes | |
