| Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8. |
#2 (permalink) | |
Benutzer
Quote:
- Vikas |
#3 (permalink) | |
Erfahrener Benutzer
Quote:
#4 (permalink) |
Erfahrener Benutzer
Bent / broken pin where the battery slips in to the charger?. Perhaps dirt or grease on one of the pins preventing good electrical contact?. I suppose the most obvious answer is try a 2nd battery and I'm sure if you had one you'd have done that, you do have a spare battery?.
#5 (permalink) |
Erfahrener Benutzer
I had a similar problem and started a thread a couple of months ago.
http://www.l-camera-forum.com/leica-...8-charger.html In review (I couldn't remember the specifics), none of the lights would come on. Also, the 12 V charger adapter would work, so I would leave it in my car (garaged) overnight for a trickle charge until the new charger arrived (quite promptly from Leica NJ). |
#6 (permalink) |
Erfahrener Benutzer
Eoin: I have a second battery but of course I can't find it right now... that would be too convenient wouldn't it,
. I like how these things happen at the least convenient time.William: Thanks for the tip. The main difference between our situations seem to be the fact that my green Power light does come on. Then again, who knows what's going on inside. I called Leica NJ to find out if there was anything unusual, but it sounds like I just need a new charger. |
#7 (permalink) | |
Neuer Benutzer
Quote:
The M8 is build like a tank (I had dropped it on pavement twice already - no damage! I think) but the charger is a cheap plastic junk... I wish that Leica would build and sell heavy duty charger. If you dare to open up the charger (I asked electronics engineer to do it / using very specialized screwdriver bit - why would they do that?) you will see that the charger consists of two electronic boards that are connected by two thin wires to each other. The first fault was that the two wires broke off so there was no connection. Still the charger worked when using the 12V adapter cable. (Using the 12V adapter is great when you have your own car but try to charge the batter by "renting" for couple of hours a taxi in Cameroon so that you can charge your batteries.) The second time the charger stopped working this time both AC and DC charge. One of the resistors or transistors (whatever they are called) "fried" when I plugged it into AC at my home. Why that happened I have no idea. In both cases I asked friendly engineers (that fix pro-video cameras) to fix the charger for me. Thanks guys... cost to me was a round of beer... The lesson learned: 1. Now I have 3 batteries for my M8. 2. I always take 12V cable with me. 3. Soon I'll buy another charger and keep it/take it as spare whenever I travel. |
| Thread Tools | |
| Display Modes | |
