| Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8. |
#2 (permalink) |
Erfahrener Benutzer
I once produced the pictures for a retrospective exhibition catalogue for a well known Canadian artist. Many of the originals were 7" x 10".
I used my 3-element elmar 90mm. I mounted it on my M2/visoflex III/bellows. This setup goes from infinity to 1:1 reproduction. The lens is outstanding, with a very flat field, no distortion. Speed was not an issue - I used flood lights with difusers on each side of the paintings, balanced for even light distribution. Since the lens is optimum at about f8, that is what I used consistently. It also allowed a little depth of field. The reason for the 90mm was to get a little distance from the painting, and minimize any errors by being a little off verticle (there was actually no issue). The publisher and artist were very pleased - they paid the bill, and the artist asked for some prints. And a informal portrait I made of him was used by the National Gallery of Canada for a later retrospective of the same artist. They must have been hard up - it is not a stunning portrait. Best of luck - it is a fun exercise. Cheers, Michael |
#3 (permalink) |
Erfahrener Benutzer
Yes, reproducing art paintings is really a fun exercise: for my experience, light is the most important issue with oils : it depends on the tecnique used, but you risk a number of annoying small reflections : I sometimes used a plorazing filter, and used with attention can be of help. Regarding the lens... rather simple: you need sharpness and undistortion, that is why the 90 mm can be really a good solution: now, it depends on what you do have: me too, if i had to do such a work, would consider my 3 elements Elmar 90 head on Visoflex+bellows: at 8-11 is incredibly sharp for its age. Probably from the present lenses, and if you haven't the Viso/bellows gear, the Macro Elmar 90 could be the best choice.
#4 (permalink) | |
Erfahrener Benutzer
Quote:
I doubt if they were hard up as the retrospective was about the artist not the photographer ![]()
__________________
blink and remember “doi knia” ....................................etrouko images........................................slide shows |
#7 (permalink) |
Benutzer
For flat work, I use the 65 Elmar on a Viso III. A flat field lens, very sharp.
For lighting, a couple of Lowel TotaLites at about 6 feet away, 45 deg to the work, but aimed at each other. The spill lights the work very evenly, avoids glare. If the paint is very textured, move one of the lights slightly further away to enhance the paint. Works very nicely, have fun Butch |
#8 (permalink) |
Erfahrener Benutzer
I think all are overlooking the 75 Cron. Especially since the OP is taking shots of 6"x 5" paintings. The close focusing of the 75 over all 90mm lenses just might be what is needed.
#9 (permalink) | |
Erfahrener Benutzer
Quote:
A better solution is to take three image captures from roughly the same distance; one from square straight-on, one from the left at about 75 degrees and one from the right at 75 degrees. Open each image file as a layer in PhotoShop and then align the layers, mask out unwanted reflections, and blend the layers. Usually, the reflections occur at different places on each layer so you can mask out the reflection (or erase it) only on one layer and still have 2 good layers left for blending. This way, you don't have to worry about the inevitable reflections until you get back to your computer where you can deal with them. Reflections occur not just on glass; a uncovered oil painting can also kick back bright light reflections. Last edited by Philinflash : 05/12/08 at 04:08 AM. |
#11 (permalink) | |
Erfahrener Benutzer
Quote:
................. Chris |
#12 (permalink) |
Erfahrener Benutzer
I've had some success using the 90mm APO for photographing large pastel drawings. Even under mixed lighting I can usually get a color balance that is very close to the original.
Despite the distance afforded by the 90mm lens the plane of focus will change across a 1m wide drawing. To compensate for the plane of focus and to minimize the slight parallax distortion I will often make a composite using 4-6 separate shots that I stitch in CS3 or something similar. The trick with that technique to take care to maintain camera and tripod strictly orthogonal to the surface of the artwork being photographed. With a smaller piece of artwork I probably would be comfortable getting in closer with a lens I was confident in, say the 50mm. |
#13 (permalink) |
Erfahrener Benutzer
Hi,
This doesn't really answer your question, but some have already started a discussion on lighting, so I thought I would add some experience. I recently had to fly across the country to shoot some paintings. I just used a standard lens, the tricky part is getting the painting square and dealing with the colors/reflection. You will need to double polarize - use linear polarizers, not circular. Put large polarizing gels over your lights and the cross polarize over the lens. (not sure if you have ever held two polarizers on top of each other, but they will black out at the point where they are cross polarized) Just mark the top of the filter/gell at this point and replicate once mounted on camera/light. You will see a HUGE improvement in the quality of the reproduction. Good luck. Per |
#14 (permalink) |
Erfahrener Benutzer
I have a PDF on how to professionally shoot paintings and print art reproductions. Anybody who is interested can drop me an email and I'll send it to you. I'm in a different time zone than most, so be patient.
printmaker@hawaiilink.net Oh yeah, my lenses for shooting art are a 150 Rodenstock Apo Sironar S and a 210 Schnider Apo Clarion. Occasionally, I use a 60 Micro Nikkor. As far as Leica goes, a long time ago I would unscrew the front of my 50 Summicron and mount it on a bellows and then onto a visoflex. It would be a pain, but today I could use a 50 Summicron on a M8, but only for art over 20x24 inches. Tom |
#16 (permalink) |
Erfahrener Benutzer
I have shot art for the purpose of making prints. The hardest thing for me was getting the color correct. You really need the original for PP. Good luck!
__________________
www.johnbrewton.zenfolio.com |
#17 (permalink) | |
Erfahrener Benutzer
Quote:
Again, my PDF will get you 90% of the way to a perfect reproduction without custom profiles. With profiles you should be 95% accurate, which is close enough to please the vast majority of customers. In fact, very few can even see that last 5%. Tom |
| Thread Tools | |
| Display Modes | |
