Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 07/12/08, 06:12 PM   #1 (permalink)
Erfahrener Benutzer
Default Magenta Vignette with M8 and 15mm CV
I made a few photos of a street scene last week, using my M8, and the CV15 with its Milich adapters (the M-mount, and the IR filter holder/shade). I have gotten pretty tired of the usual cyan fringing even when using the Milich adapter, and since there there weren't any black objects in front of me that I felt would exhibit the usual IR problems, I decided I'd take the filter off and hopefully avoid cyan vignette issues in the corners.
So without the IR filter and holder/shade, the shots show a weird magenta cast that becomes more pronounced as you move outward toward the corners of the images--just like the cyan vignette issue, but magenta instead.
I am totally perplexed by this. Can anyone think of a solution? Could it be an issue with the camera not reading the coding on the Milich M-mount? I'm puzzled.
__________________
See some of my images on www.pbase.com/photolandscape. And, you can see my growing collection of photo books at www.blurb.com under "Photolandscape".
photolandscape is offline   Reply With Quote
Old 07/12/08, 06:37 PM   #2 (permalink)
Erfahrener Benutzer
Default Re: Magenta Vignette with M8 and 15mm CV
IR filter setting in the menu enabled, but no IR filter??????
Sandy
sandymc is offline   Reply With Quote
Old 07/12/08, 06:37 PM   #3 (permalink)
Erfahrener Benutzer
ArtZ's Avatar
Steve,
Could you post these images?
ArtZ is offline   Reply With Quote
Old 07/12/08, 07:29 PM   #4 (permalink)
Erfahrener Benutzer
To spell out Sandy's question, it sounds as if you left the camera in the Lens Detection Enabled-UV/IR filter setting, in which it will automatically correct for a cyan drift that is much stronger than the little that results from the thin green filter over the sensor. The result is pink corners. Instead, set either Lens Detection ON (slight cyan correction, fairly strong luminance vignetting correction) or OFF (no corrections at all, but also no EXIF info about what lens you used).
scott
__________________
___________________
www.pbase.com/skirkp
www.cs.huji.ac.il/~kirk
scott kirkpatrick is offline   Reply With Quote
Old 07/12/08, 07:30 PM   #5 (permalink)
Benutzer
mmk60's Avatar
I have never had any serious problems with the CV15..... No IR cut filter but the lens detection is ON.
cheers
mmk60 is offline   Reply With Quote
Old 07/12/08, 11:08 PM   #6 (permalink)
Erfahrener Benutzer
You have to set the lens detection turning off +UV/IR.
BerndReini is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
