Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 05/03/08, 12:54 AM   #1 (permalink)
Neuer Benutzer
Frage rogera
Can anyone give me some advice re: metering with my m8. I cannot seem to balance my exposures in situations where the center of the photo is very bright. My edges come out way too dark. What am I doing wrong?
rogera is offline   Reply With Quote
Old 05/03/08, 01:49 AM   #2 (permalink)
Erfahrener Benutzer
WPalank's Avatar
Default Re: rogera
Hit the Set button, drop down to EV in the menu and push it up 1/3, 2/3 or a full stop. Problem is if there is important detail in the "bright" area, it may be blown out.
__________________
William Palank
William Palank Photography
WPalank is offline   Reply With Quote
Old 05/03/08, 02:06 AM   #3 (permalink)
Erfahrener Benutzer
Default Re: rogera
Or try using the camera manually, IE setting the shutter speed yourself, and take two images. One at the normal meter reading and another at a lower, slower, shutter speed.
You can also do that when set to the Auto (A) mode by moving the metering area, center of the frame, to a darker part of the scene and pushing the shutter button down a little until you see a red dot in the center of the meter shutter speed reading in the viewfinder. That red dot signifies the shutter speed is locked at the current reading.
Once you have 2 images you can take the bright parts of one and combine it with the darker parts of the other, that are more properly exposed, to come up with a image that looks more evenly exposed.
Shootist is offline   Reply With Quote
Old 05/03/08, 09:43 AM   #4 (permalink)
Erfahrener Benutzer
Default Re: rogera
It is helpful to look at the metering pattern on page 105 of the M8 manual. In Leica's own words the metering has a 'strongly concentrated center-weighted characteristic'.
Jeff
delander is offline   Reply With Quote
Old 05/03/08, 02:09 PM   #5 (permalink)
Benutzer
Default Re: rogera
There is a limit to the dynamic range that digital sensors or film can record. Also the LCD on the back of the camera is not a true indication of what is recorded in the file. Check the histogram to see if the distribution is off the edge both right and left. If it is off to the left, overexpose using exposure compension to move the histogram as far to the right as possible without going off the edge. Camera Raw will then help you get both highlights and shadows.
Of course the other solution is to use auxiliary lighting to balance the light across the scene.
zeitz is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
