Leica User Forum B+H
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Tags: , ,
Old 01/24/08, 09:41 PM   #1 (permalink)
Erfahrener Benutzer
luigi bertolotti's Avatar
Default 1,35 x Megaperls - OK
I received my VF magnifier today - after some exhitations my choice was for the Megaperls 1,35x : here are my impressions - btw , I'm a glass-wearer:
- RF alignement is REALLY much better; I never tried such items before: well, now I understand why so many people consider it an almost mandatory accessory.
- Without glasses, the 28 frame is at the limit, but you can see it: there is a little distortion in the 28 field; I understand why Leica limited to 1,25x.
- 24 is out of discussion: unusable (the reason for I went for 1,35 is that I surely have no plan for a 24 - have 21+28)
- for 75 and 90 is a blessing : no appreciable distortion, and wow the frames are good
- So, for 135mm lovers (like me) I think is really a very good solution
- The diopter adjustment is someway rough: a simple screw (not loose,now, then... I'l see) with no scale, no references at all: unwearing my glasses, I found a good position, but surely I have to hand-make some reference for the right position
- There is, undoubtly, a certain loss of luminosity in the VF, and in low light (I made some tests at home) it can disturb.
- I never saw the Leica 1,25x, but I think that the price difference can be, for this item, well justified : the Megaperls has no bag, no instructions, the packaging is poor, and the optic I think is surely of a cheap kind.
- I haven't yet decided if it will be ALWAYS fitted on my M8... I sometimes used the 21 without external VF... with this device it's impossible... ; the absence of a small bag can be disturbing , but I have an old small bag for the Leitz 5cm VF (SBOOI)...it can be attached to the strap... can be a satisfyng solution if I'd decide to haven'it permanently attached: but I hope to end with having it permanent... I have the idea it's not an item one can be confident to mount and dismount many times.
In conclusion : a not too costly and very useful device, probably (time must pass to evaluate) with good value-for-money.
And... thanks to Jaap and Wladiwlaw and others in this forum : were their posts that convinced me to buy an accessory that, silly, I never considered before.
luigi bertolotti is offline   Reply With Quote
Old 01/24/08, 10:58 PM   #2 (permalink)
Erfahrener Benutzer
Mauribix's Avatar
Default Re: 1,35 x Megaperls - OK
Ciao Luigi!
sono contento che ti trovi bene con il megaperls!io utilizzo da tempo il modello 1,25x di HK supplies, e sarei tentato di usare il modello 1,35x dal momento che utilizzo solo il 35mm e il 50mm (qualche volta il 90) oppure i grandangoli 15 e 12 di CV.
Come risulta la cornice del 35mm con l'ingranditore 1,35x?è davvero ben visibile o devo ruotare l'occhio per vedere tutto il riquadro?
ciao e grazie per la risposta!
Mauri
__________________
Best Regards
Maurizio
www.mauriziobeucci.com
Mauribix is offline   Reply With Quote
Old 01/24/08, 11:40 PM   #3 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Do I have to tell you: "I told you so" ? because the 1.15x is just as good for your second body. (there will be one, won't it )
__________________
Jaap
WWW.JAAPVPHOTOGRAPHY.EU
Skype: JAAPVPHOTOGRAPHY
jaapv is offline   Reply With Quote
Old 01/25/08, 02:32 AM   #4 (permalink)
Erfahrener Benutzer
Daniel Ortego's Avatar
Well, I read on this forum where some folks really liked the 1.35 Megapearls so I jumped in and got it right before the holidays. Unfortunately, most every photo I took was out of focus when I downloaded them. I used the recommended o-ring to hold the adjustment but it was apparently off, and the device is now in my nightstand as it simply didn't work out.
Regards,
__________________
"Live as though you were going to die tomorrow and learn as though you were going to live forever."
~ Mahatma Gandhi
Daniel Ortego is offline   Reply With Quote
Old 01/25/08, 03:06 AM   #5 (permalink)
Erfahrener Benutzer
barjohn's Avatar
Daniel,
I don't understand that as I have it and the 1.25x and I can focus much better. Did you adjust the diopter adjustment to get the clearest focus first and then use it to focus? My 90mm is the hardest to get a real sharp focus with and I can do it with the 1.35x and it is very hard to get a sharp focus without it.
__________________
John
You are welcome to browse my photos and ALL comments are appreciated, good and bad!
www.barjohn.com/My Photographs/index.html
barjohn is offline   Reply With Quote
Old 01/25/08, 07:30 AM   #6 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by Mauribix View Post
Ciao Luigi!
Mauri
Ciao Maurizio: con l'occhio ben attaccato al Megaperls la cornice 35 si vede davvero bene e senza strani movimenti d'occhio: come ho scritto prima, tutto sommato si può usare anche quella da 28, anche se, in effetti "guardando un po in giro"... l'ho fra le mani da troppo poco per dare ulteriori giudizi, ma sono, direi, tranquillo sul fatto che, se non altro, sono ben a posto per 75-90 e ...135 ! al 135 ci tengo molto.
Old 01/25/08, 07:39 AM   #7 (permalink)
Erfahrener Benutzer
Quote:
My second film body, at M4's times, was a IIIf or a CL... unless they make a digital LTM "IVf / IVg" ... or the "CLD" you recently envisioned ... a 2nd M8 is not in my plans (... and fear some of my daughters crying "Dad, you have TWO... why don't you lend me ONE for this weekend with my boyscout group ?" (*) )
(*) The older would have liked to be invested of the prescripted role of "photographer" in her Boyscout brigade... decided to abandon the idea when I proposed her to use my folding 6x9 Super Ikonta (a very educative camera, mostly for learning to spare film....)
Old 01/25/08, 08:07 AM   #8 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Quote:
Regards,
It may be that you have an (unrecognized?) eye problem like astigmatism. That won't repond to a simple correction of the diopter, but might even be brought more to the foreground by mgnification.
__________________
Jaap
Old 01/25/08, 08:10 AM   #9 (permalink)
Benutzer
Regards,
Thanks Daniel I was about to sell my last Leica magnifier in favour of the Magapearls, so I guess I won't be going there after all.
Regards ... Jim.
highlander is offline   Reply With Quote
Old 01/25/08, 08:18 AM   #10 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Hi Jim - There is no telling - with me it is just the other way around- my 1.25 Leica sits unused.
__________________
Jaap
Old 01/26/08, 10:00 AM   #11 (permalink)
Benutzer
We must remember that each of us are individual and unique. However it is good to get guidance from friends.
Regards ... Jim.
Old 01/26/08, 04:07 PM   #12 (permalink)
Benutzer
Regards,
If you are interested in selling I'd like to give it a try...
monza is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
