Leica User Forum
Go Back   Leica User Forum > International User Forum > Leica Products > Leica M8 / Leica M8.2
Leica M8 / Leica M8.2 The Leica M8 Forum is dedicated to everything around the Leica M8.
 Leica Products
Leica M240 Leica M Monochrom Leica M9 Leica M-E Leica X Vario
Leica M240
Amazon US | B&H | Dale | Adorama | eBay US | Leica Deals
Leica M Monochrom
Leica M9
Amazon US | B&H | Dale | eBay US | Leica Deals
Leica M-E
Leica X Vario
B&H | Adorama | Dale | Amazon | eBay US | Leica Deals
Old 23/09/10, 13:25   #41 (permalink)
lct
Erfahrener Benutzer
lct's Avatar
Default Re: M8 and Summicron 40mm f2
Ad
The original lens cap is the hood cap # 14191.
To put a red nose to your 40/2 you just need:
- a 39mm UV-IR Leica filter (#13410)
- a Leica hood #12518 dedicated to the 'cron 40/2
- a 37mm rubber ring
- a pin and a die grinder
Works fine with M8 and R-D1. Never used it with the M9 but a thinner rubber ring would be advisable to avoid vignetting presumably.
1. Grind the filter housing of the hood in order to enlarge its inner diameter to 37mm:
http://tinyurl.com/34lxqtd
2. Remove the blocking ring of the filter with a pin or same:
http://tinyurl.com/34oqgnx
3. Insert the glass into the filter housing:
http://tinyurl.com/38paj9m
lct is offline   Reply With Quote
Old 23/09/10, 13:25   #42 (permalink)
Erfahrener Benutzer
Yogibear's Avatar
Default AW: Re: M8 and Summicron 40mm f2
Quote:
Originally Posted by bboynic View Post
Hi, i have a 40mm F2 Summicron-c and my Leica M8 is on the way now. I am just wondering which 39mm UV/IR cut filter are you guys using? can you guys show some pictures with the lens and the 39mm UV/IR cut filter on? Is the B+W SCHNEIDER 486 39mm UV IR CUT FILTER will fits on the 40mm Summicron-c? Can anyone also suggest me a lens cap for the 40mm Summicron-c? Thank you.
Hello and welcome to the forum!
The Summicron-C has a 39mm thread but with the wrong pitch, 0.75 instead of 0.5!!
It was meant for the rather rare Series 5.5 filters kept in place by the dedicated rubber sunshadewhich after some years very often broke or deteriorated enough to become useless. As far as I know, there are no Series 5.5 UV/IR-cut filters. I use a normal 39mm filter and carefully screw it in until it stops. You can then use any original Leitz lens hood of the correct size.
__________________
My equipment: two eyes. And a camera.
Last edited by Yogibear; 23/09/10 at 13:29. Reason: Described lens shade, not lens hood.
Yogibear is offline   Reply With Quote
Old 23/09/10, 13:26   #43 (permalink)
lct
Erfahrener Benutzer
lct's Avatar
4. Insert the rubber ring over the glass:
http://tinyurl.com/2u25xj6
5. Screw-in the hood and enjoy:
http://tinyurl.com/2wun8hg
Old 23/09/10, 19:25   #44 (permalink)
Neuer Benutzer
Thank you for the advice. Do you think is it a good idea if i glue the B+W 39mm UV/IR filter on top of the rubber hood is a good idea? will it have vignette or effecting the image?
bboynic is offline   Reply With Quote
Old 23/09/10, 19:41   #45 (permalink)
Neuer Benutzer
hey guys, i got an idea. With the rubber hood pulled up. i am able to fit in a 46mm size filter nicely and firmly inside the rubber hood. Do you guys think it is a good idea to stuck in a 46mm filter there and glue it? will it effect the image quality by moving the UV/IR filter a bit far from the lens? or it will cause some vignetting? Thank you.
Old 23/09/10, 19:58   #46 (permalink)
lct
Erfahrener Benutzer
lct's Avatar
No vignetting problem IMO, at least with crop bodies (R-D1, M8) but you would have to glue the filter into the hood, you would get more flare and you could not fold down the hood any more.
Thank You says
bboynic (23/09/10)
Old 23/09/10, 20:05   #47 (permalink)
Neuer Benutzer
Quote:
sigh...it wasn't a good idea then. >.<
Old 23/09/10, 21:56   #48 (permalink)
Erfahrener Benutzer
epand56's Avatar
I do not understand all this clutch at straws about mounting a UV/IR filter on the Cron-C 40.
I simbly bought a B+W filter and screwed it on the lens untill it gripped and then screwed the hood on the filter. It is still in place after almost two years. Didn't have a single problem with it.
__________________
All the best,
Enrico
Mourir pour des idées, l'idée est excellente. Moi j'ai failli mourir de ne l'avoir pas eue
www.flickr.com/photos/27472131@N08/
epand56 is offline   Reply With Quote
Thank You say...
bboynic (24/09/10), WestMichigan (12/11/12)
Old 24/09/10, 08:55   #49 (permalink)
Neuer Benutzer
Hi, i got a question, with the M8 and Summicron 40mm F2 lens, if i'm shooting landscape and wanted the image sharp from the front to the back, what aperture and focus should i set to? i'm new to the M8 hope to hear something from you guys. Thank you.
Old 24/09/10, 09:42   #50 (permalink)
Erfahrener Benutzer
epand56's Avatar
Nic, the Cron 40 is a lens like all the others. I suppose that with an aperture of 5.6 - 8 you will have anything sharp focusing on distant objects.
I'm not a landscape photographer, but looking at some of my pictures I've noticed that even at aperture 4 the Cron 40 gives you quite a good DOF.
__________________
All the best,
Enrico
Thank You says
bboynic (24/09/10)
Old 24/09/10, 11:29   #51 (permalink)
Erfahrener Benutzer
Ad
Agree...it is a non issue.
andy
__________________
“No man hath given his child anything better than good manners.”
- Prophet Muhammad (570-632)
andym911 is offline   Reply With Quote
Old 24/09/10, 11:47   #52 (permalink)
Erfahrener Benutzer
kanzlr's Avatar
maybe you should read up on the issue of depth of field and aperture...
you can try this for a start: Online Depth of Field Calculator
__________________
Bernhard
www.flickr.com/photos/kanzlr
kanzlr is offline   Reply With Quote
Old 28/09/10, 01:45   #53 (permalink)
Erfahrener Benutzer
I agree with Enrico. I just use a 39mm B+W filter and have never had any problems with the filter falling out or even coming loose.
piblondin is offline   Reply With Quote
Old 03/10/10, 19:36   #54 (permalink)
Erfahrener Benutzer
graeme_hutton's Avatar
A bit late on this, sorry......FWIW I've used a standard Leica 39mm and simply screwed it in carefully until it grips firm.
Graeme
graeme_hutton is offline   Reply With Quote
Old 04/10/10, 15:27   #55 (permalink)
Neuer Benutzer
B+W make 486 UV IR Cut MRC
Serie 5,5 (36,0 mm)
Foto Huppert sell it. www.foto-huppert.de/default2.asp
__________________
Vidar
odin is online now   Reply With Quote
Old 06/10/10, 05:52   #56 (permalink)
Erfahrener Benutzer
thompsonkirk's Avatar
I thought I posted this before, but now I don't see it here.
DAG offers an inexpensive adapter to use 39mm filters on Summicron-C's.
Then you can screw into the filter either a Chinese-made threaded hood with vents, or one of the snub-nosed hoods for 50 Elmar (still available new). I was surprised to find that the former didn't vignette.
Kirk
thompsonkirk is offline   Reply With Quote
Old 01/11/12, 21:57   #57 (permalink)
Neuer Benutzer
As a relative newcomer to M- world and also having a family to feed, I am always up for ways to get the best out of it on a budget. Recent aquired a summicron 40mm and am totally smitten with it on M8.
The frameline modification is simple enough to do although one or two things to bear in mind. The brass filings look pretty but WILL get all over your camera and inside if you are not careful.
Wrap your lens up in paper and tape it up so is sealed except for the little flange to operated on. Make sure it is clear of golden speckles before trying it on your camera.
Job done you now have a superb lens configuration and the frame lines are near as damn it!
Leicas are expensive and a deligt to own and handle. I am over the moon with my M8. In these days of all singing all dancing gadget filled cameras, this one takes real photographs and thats it. Also its not an ornament, I got i t to use and use it i will. I like this forum full of tips from photograhers who use their kit and enjoy it.
chipchip is offline   Reply With Quote
Thank You says
WestMichigan (02/11/12)
Old 01/11/12, 22:02   #58 (permalink)
Erfahrener Benutzer
iedei's Avatar
this is one hell of a fantastic lens. One of the finest lenses around for the money, IMO....
here's a thread i made dedicated to it after i got mine a few weeks ago:
http://www.l-camera-forum.com/leica-...pt-secret.html
__________________
SYED
Leica M5 & Leica M8.1
Elmarit 21mm F2.8
Komura 35mm F3.5
Summicron 40mm F2.0
Summilux 50mm F1.4
Super Rokkor 50mm F1.8
Ricoh GRD-3 & GXR
500px
iedei is offline   Reply With Quote
Thank You says
Old 02/11/12, 03:40   #59 (permalink)
Erfahrener Benutzer
WestMichigan's Avatar
Hey there ChipChip, I have the 'same/yet different' Rokkor Forty and really enjoy the lens a lot. My big fingers are slowing my adaptation down a bit, but it's worth the effort to build the muscle memories. The picture memories are definitely worth it. I agree abiut the 35mm framelines lining up wonderfully, but I'm terrified to make the adaptation myself. It is really a cost/benefit gem in LeicaLand.
RW
__________________
Gear: Leica M8 with CV 28 Ultron Asph, Rokkor 40, CV 75 Heliar, Elmarit 90, Hektor 135, and Nikkor 135, to use with it.
WestMichigan is offline   Reply With Quote
Old 02/11/12, 06:09   #60 (permalink)
Moderator
jaapv's Avatar
Default Re: AW: Re: M8 and Summicron 40mm f2
Quote:
Serie 5,5 (36,0 mm)
Not any more. But you can take the filter glass out any 39 mm filter and drop it into the lens hood instead. It will rattle, but it will work.
__________________
Jaap
WWW.JAAPVPHOTOGRAPHY.EU
Posts in blue bold font are made as a moderator
jaapv is offline   Reply With Quote
Reply
Bookmarks
Current eBay Ads
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
