Leica User Forum Robert White
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
Tags: , ,
Old 12/07/07, 10:43 PM   #1 (permalink)
Neuer Benutzer
Default Help with viewfinder problem
I just bought a used Noctilux, when I put it on my new M8 the marking in the viewfinder show the 90mm crop rather than the 50mm marks. My 50mm Summicron and other lens are showing the correct marks. Any ideas what's wrong?
raymondy is offline   Reply With Quote
Old 12/07/07, 11:01 PM   #2 (permalink)
Erfahrener Benutzer
bradreiman's Avatar
Default Re: Help with viewfinder problem
did you try giving the frame selector a little nudge? sometimes it sticks a bit. otherwise your noctilux mount may be compromised or not even a 50mm mount.....b
bradreiman is offline   Reply With Quote
Old 12/07/07, 11:05 PM   #3 (permalink)
Erfahrener Benutzer
Check the lengths of the flanges on the bayonet rings, specifically the one opposite the cut out in the bayonet ring.You should find the one on the Noctiluxis exactly the same length as other 50s.
__________________
Mark
marknorton is offline   Reply With Quote
Old 12/08/07, 01:25 AM   #4 (permalink)
Neuer Benutzer
Mark, your right. There's a slight difference is the length of the flange. Can that be adjusted in some way?
Old 12/08/07, 01:57 AM   #5 (permalink)
Erfahrener Benutzer
bradreiman's Avatar
Quote:
only if its longer chop chop....brad
Old 12/08/07, 01:57 AM   #6 (permalink)
Erfahrener Benutzer
Is this a NEW Noctilux??? If so you should have it adjusted by Leica.
If you bought it used then I still send it to Leica and have it checked over or return it to whoever you bought it from.
Also make sure your not turning it past the locking lug when you're mounting it.
Shootist is offline   Reply With Quote
Old 12/08/07, 02:47 AM   #7 (permalink)
Erfahrener Benutzer
Raymond,
I'd suggest taking the camera and lens to Steve Choi in Culver City. (¢Æ Steve's Camera Service Center ¢Æ) He's a camera tech recommended by the LHSA (and by me). He'll be able to look at the lens and tell you what's up.
Steve
stephengilbert is offline   Reply With Quote
Old 12/08/07, 02:53 AM   #8 (permalink)
Neuer Benutzer
Thanks for all your help.
Old 12/08/07, 03:58 AM   #9 (permalink)
Benutzer
If your Nocti calls up the 90 frame, then you can file down the lug on the bayonet until it calls up the 50/75 frame. That's because the 28/90 lug is longest, 50/75 slightly shorter, and 24/35 (on the M8) the shortest. Be careful, though: it doesn't take many swipes of a rat-tail file.
But I agree that it might be best to send it in so that other aspects can be checked.
Stan Yoder is offline   Reply With Quote
Old 12/08/07, 09:52 AM   #10 (permalink)
Erfahrener Benutzer
Sounds like the Noctilux had been fitted with an incorrect bayonet mount at some point.
__________________
Mark
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
