| Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8. |
LinkBack (7) | Thread Tools | Display Modes |
#23 (permalink) |
Erfahrener Benutzer
Gave a quick look... sufficient to say "GREAT !" to our friend Carl ; together with Mark's exceptional work & pics on the M8 disassembled, it stands as a document to save with care and be studied in depth.
#24 (permalink) | |
Erfahrener Benutzer
Quote:
At most, there may be detailed logic or hardware setup changes such as: If CCD_BoardID <= 2 Then Do_This Else Do_That
__________________
Mark |
#25 (permalink) |
Erfahrener Benutzer
Carl - many thanks!
Do any of you really clever people out there think that there's a way of getting aperture and lens information across to Lightroom... or will it pick up the information from the exif that CF re-writes during a batch process? Just tried to do this with a small set of files - but LR still shows Leica lenses as "unknown" - an annoyance. Grateful if any of you have thoughts... |
#26 (permalink) | |
Erfahrener Benutzer
Quote:
If you run the images through CornerFix 0.9.1.6 with the "Update EXIF" option enabled the "Lens" information should show, and the aperture should show under "Exposure". But you have to enable the "Update EXIF". It's disabled by default. Sandy |
#27 (permalink) |
Benutzer
Thank you for such a detailed and thorough work.
I do not know if I missed anything, but will maker notes be affected by Adobe DNG converter? You mentioned a number of problem under the heading "Maker notes safety", but Adobe DNG converter is not included. Again, thanks |
#28 (permalink) |
Erfahrener Benutzer
Great job, many thanks to Carl, Scott and Sandy.
I did a quick scan of the PDF, will be happy to spent more time with it.
__________________
Best regards, Paul Steunebrink http://www.psfotografie.nl/ http://web.me.com/paul.steunebrink/ |
#29 (permalink) |
Erfahrener Benutzer
Sandy - got this - thanks. The issue then is that CF (sensibly) creates a copy rather than over-writing the original DNG. My problem is that I rarely need to use CF as my wide lenses coded + I have IR cut filters on all lenses... What I would love to be able to do is to run a batch across gigabytes of files adding the exif data to Leica files ... creating copies would clearly not do the job.
I suppose what I'm asking for is something that CF isn't designed to do - so please don't take this as a criticism of an outstandingly good piece of work ... still looks as if I'm going to have to live with unknown lenses in LR unless I can put enough pressure on the LR developers to treat Leica users as well as they treat owners of Canon systems... Many thanks |
#30 (permalink) | |
Erfahrener Benutzer
Quote:
Yes, that's correct - CornerFix will not overwrite original files in batch mode - a safety feature. One possible work around might be to convert with CornerFix in batch mode, then use a batch renaming tool - there are a lot around - to convert back to the original filename. Pretty much any batch renaming tool should be able to handle removing a trailing _CF Sandy |
#31 (permalink) | |
Erfahrener Benutzer
Quote:
I think most of us wished Leica had provided an accurate method to report aperture in the EFIX data. However, based on Carl's paper and design limitations inherent in M lenses it is understandable to see why Leica chose not to use the f-stop estimate provided by the blue dot. I am sure the M8 community would be screaming at Leica if they had reported the f-stop in EFIX with the inaccuracy I saw in my limited trial. The M8 community is fortunate to have talented people who are able to provide features/fixes that may not fit the confines of a corporation. Grass roots efforts such as this are not met with the same expectations and liabilities as if it came from a corporation.
__________________
______________ Mark Gowin |
#32 (permalink) | |
Erfahrener Benutzer
Quote:
CV21: actual f/8 Leica 11.3 Sandy 8.0 35/2 asph actual f/8 Leica 9.5 Sandy 8.0 " actual 5.6 Leica 6.7 Sandy 5.7 " actual 2.0 Leica 2.4 Sandy 2.0 This is consistent with all of Carl's data. Maybe the Summarits do something unexpected. Try some more, with "normal" lighting -- a wide scene, not backlit, and see if you still get such big errors. scott |
#33 (permalink) |
Erfahrener Benutzer
Scott, I definitely plan to run Coner Fix to update the EFIX data on photos other than the Summarit. I chose the Summarit lens tets photos as a trial simply because I kept good notes on the actual f-stop.
__________________
#34 (permalink) |
Erfahrener Benutzer
Thank you for your kind words all. I really appreciate it. It has been a lot of work so I'm glad it is of interest.
- Carl
__________________
The M8 Metadata project Join the 2010 Leica One Challenge, Venice Italy, Saturday October 16th. |
#35 (permalink) | |
Erfahrener Benutzer
Quote:
The list in the paper is by no means an exhaustive one. I had not considered the DNG converter so I had to test it. Turned out I had to do a little work on my decoder to be able to read all the metadata in the converted files. As I expected, it does not save the maker notes. The DNG Converter follows the DNG specification (I'm glad Adobe takes it's own medicine) and ignores the maker notes when it writes the converted file. Yet another reason for Leica to add this tag to the files. - Carl Edit: Hold the phone! It seems I may be wrong. There are indicators that make me think the maker notes block is saved as "DNG Private Data". I will need to investigate this further and report back.
__________________
The M8 Metadata project Join the 2010 Leica One Challenge, Venice Italy, Saturday October 16th. Last edited by cbretteville; 22.11.2007 at 20:06. |
#36 (permalink) | |
Erfahrener Benutzer
Quote:
- Carl
__________________
#37 (permalink) | |
Erfahrener Benutzer
Quote:
#38 (permalink) | |
Erfahrener Benutzer
Quote:
3.5, 3.4, 2.8 5.6, 5.7, 4.8, 8, 8.0, 6.7 11, 11.3, 9.5 Last edited by scho; 23.11.2007 at 04:00. |
#40 (permalink) |
Erfahrener Benutzer
Just an idea.
I could imagine that big lenses or lenses with large hoods tend to shade the blue dot somewhat. In this case, wouldn't the camera tend to underestimate the f-stop? (Thinking there was less ambient light than there really is, it would think the lens is wider open than it really is). I guess all I am trying to say is that there may be a relationship between lens geometry and quality of f-stop estimate. But I do realise they have set the blue dot as high as possible to minimise this effect. And that would hardly be something one could possibly correct for. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/leica-m8-forum/39117-secrets-blue-dot-revealed-other-m8.html
| Posted By | For | Type | Date | |
| Leica m8: primeras imagenes - Pgina 58 - OJODIGITAL | This thread | Refback | 28.01.2009 16:01 | |
| Apperture does not appear in EXIF - Rangefinderforum.com | This thread | Refback | 20.09.2008 10:22 | |
| Leica m8: primeras imagenes - Pgina 58 - OJODIGITAL | This thread | Refback | 07.02.2008 00:53 | |
| Leica m8: primeras imagenes - Pgina 58 - OJODIGITAL | This thread | Refback | 07.01.2008 20:10 | |
| summilux.net :: Voir le sujet - M8 Metadata | This thread | Refback | 30.11.2007 17:14 | |
| summilux.net :: Voir le sujet - M8 Metadata | This thread | Refback | 23.11.2007 19:02 | |
| summilux.net :: Voir le sujet - M8 Metadata | This thread | Refback | 22.11.2007 19:58 | |
