Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
Old 07/15/08, 11:17 AM   #1 (permalink)
Erfahrener Benutzer
Default flash
i need to get a simple flash unit... just for a bit of fill on grouop people shots
mainly outdoors so can't really bounce... diffuser would be nice though
does anyone know of a suitable cheap-ish unit I could use ?
thanks
Rich
jackal is offline   Reply With Quote
Old 07/15/08, 11:28 AM   #2 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Default Re: flash
I got a Metz MZ off the Internet for 5$, bought an SCA adapter (3502M4 if memory serves) and it works like a dream.
__________________
Jaap
WWW.JAAPVPHOTOGRAPHY.EU
Skype: JAAPVPHOTOGRAPHY
jaapv is offline   Reply With Quote
Old 07/15/08, 12:10 PM   #3 (permalink)
Erfahrener Benutzer
ArtZ's Avatar
Default Re: flash
I have the Leica SF-24D but I use more often the Panasonic DMW-FL28 with my M8s.
The Panasonic DMW-FL28 was the recommended flash for the Panasonic Lumix DMC-LC1 It is small, very easy to use, it bounces, it has AUTO mode (no TTL), SLAVE mode, wide angle diffuser and you can use rechargeable AA batteries. I use it mainly for daylight flash fill.
ArtZ is offline   Reply With Quote
Old 07/15/08, 12:43 PM   #4 (permalink)
Erfahrener Benutzer
Default Re: flash
ok thanks
so presumably i couldn't just fit the panasonic and the snap away in auto mode on the m8 ?
Old 07/15/08, 12:53 PM   #5 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Default Re: flash
You can do that with nearly every flash unit.
__________________
Jaap
Old 07/15/08, 12:56 PM   #6 (permalink)
Erfahrener Benutzer
Default Re: flash
ok great
i have an opportunity to buy the Leica unit for ~150 gbp
would it be superior in any way to the Panasonic ?
Old 07/15/08, 01:06 PM   #7 (permalink)
Erfahrener Benutzer
Default Re: flash
I'm using the Nikon SB-15, small flash, with tilting head for bounce (I know you said you don't need it but others reading this might).
__________________
Mark
marknorton is offline   Reply With Quote
Old 07/15/08, 01:08 PM   #8 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Default Re: flash
If it is the SF 24D you get M-TTL,which is a distinct advantage for fill-in flash, Otherwise, no advantage and no tilting head.
__________________
Jaap
Old 07/15/08, 01:18 PM   #9 (permalink)
Erfahrener Benutzer
Default Re: flash
a quick search seems to suggest that the 24D TTl is not necessarily that desirable with a distracting pre-flash
Old 07/15/08, 01:33 PM   #10 (permalink)
Erfahrener Benutzer
Default Re: flash
Quote:
Actually when I want fill flash I use the 24D in Auto or manual mode and dial it down to what I want. In Auto or manual there is no preflash.
Let me add that I also use a Nikon SB800 if I want bounce.
Shootist is offline   Reply With Quote
Old 07/15/08, 01:38 PM   #11 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Default Re: flash
The pre-flash is actually not that bad. Far less that red-eye reduction. A matter of personal taste if one finds it distracting.I find flash in general quite bothersome and will avoid it whenever I can.
__________________
Jaap
Old 07/15/08, 02:58 PM   #12 (permalink)
Erfahrener Benutzer
ArtZ's Avatar
Default Re: flash
ok great
- The Panasonic is a discontinued model and not very easy to find. There're still some in the Internet. I found mine in Zurich (I just paid 70 Euros new).
- I like to be able to bounce the flash. That's for me a most important inconvenience with the Leica.
- I hate to throw away batteries (not very ecological)
- I use the Panasonic with the Ricoh GRII, with a Canon G9 (the Canon 580 is too big) and sometimes as slave with other cameras.
Hope that helps you
Old 07/15/08, 03:15 PM   #13 (permalink)
Erfahrener Benutzer
Default Re: flash
ok thanks chaps
i just went to my local shop and they had a used Nikon SB-26
its probably overkill for what I need but tried it in the shop and it seemed to do fill in ok
it swivels and tilts and has a built in diffuser and all sorts of options
was only 70 quid with 6 months warranty so all is well
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
