Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
090909 Promo
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
LinkBack (9) Thread Tools Display Modes
Old 15.07.2008, 18:35   #21 (permalink)
Erfahrener Benutzer
James Mitchell's Avatar
Default Re: UV/IR filter for Leica Summicron-C 40mm
I had DAG take an old screw-in rubber hood made for the 90mm-C Elmar, cut down the length of the rubber hood, then weld in a 39mm threading facing out. He put in an old piece of UV glass and the thin retaining ring. Then I took a 39mm UV/IR fliter out of its mount and replaced the glass into the hood. This is a very effective filter/hood combination for the M8.
James Mitchell is offline   Reply With Quote
Old 15.07.2008, 20:29   #22 (permalink)
Benutzer
That is what I was thinking about the hood, just to get a 39mm screw in one.
It's weird, because I had read before that the Leica filters will screw in part way, but my UV/IR just wouldn't take at all. More than one B+W fit snugly, no problem... bizarre!
Thanks!
Ben
benkelley is offline   Reply With Quote
Old 16.04.2009, 11:08   #23 (permalink)
Erfahrener Benutzer
epand56's Avatar
I know I'm late with this thread, but here is my 2 cents.
When I bought my Cron-C 40 i put a 39mm UV/IR filter on it and screwed the hood on the filter and since then anything is Ok and firm. I used it extensively, always hanging on my side with a Y-Strap, and nothing weird happened, filter and hood are always in their place.
I sometimes thought I could sell all my lenses and just keep this little gem.
But in the end, I love them all.
P.S.
You guys should try the other one, the Elmar-C 90/4. Another light and sharp little guy.
__________________
All the best,
Enrico
Mourir pour des idées, l'idée est excellente. Moi j'ai failli mourir de ne l'avoir pas eue
www.flickr.com/photos/27472131@N08/
epand56 is offline   Reply With Quote
Old 22.04.2009, 22:40   #24 (permalink)
Erfahrener Benutzer
jevidon's Avatar
I found that the 39mm B&W IR/UV filter screws into the standard 5.5 series 40mm Summicron, but don't force it since the threads may cross or spall.
I also found that the standard 5.5 series collapsible rubber hood made by Leitz/Leica threads all the way into the B&W filter very securely with no resistance.
But, since the filter is held to the lens by a few threads due to the different thread pitch, it would be a good idea to fix a lanyard from the rubber hood to the camera strap in the event that the filter wants to come loose from the lens barrel.
I found that it is a non-problem.
jevidon is offline   Reply With Quote
Old 23.04.2009, 19:40   #25 (permalink)
Benutzer
After waiting for months for a serie 5.5 filter I decided to go for the grinding solution of a
E39 filter. So I bought a Heliopan uv/ir E39 filter. After removing the glass out of the holder I noticed to my surprice that the glass fitted without any grinding.
I just needed a rubber ring to make it fit tight into the sunshade. Perfect solution!
Co Morriën
como is offline   Reply With Quote
Old 23.04.2009, 20:55   #26 (permalink)
lct
Erfahrener Benutzer
lct's Avatar
The Heliopan must be smaller than the Leica UV-IR i guess otherwise grinding the hood of the filter would be mandatory.
lct is offline   Reply With Quote
Old 25.04.2009, 08:54   #27 (permalink)
Erfahrener Benutzer
jevidon's Avatar
I am having a Leitz 5.5 p/n 11251 machined to accept the standard Leica 39mm filters including the IR/UV. I'll not say who is doing it until I get it back and try it. If it works, I'll tell you all about it. And if it works, it will be the most cost effective secure method of adapting these filters to the 40mm Summicron C.
Old 25.04.2009, 15:45   #28 (permalink)
Erfahrener Benutzer
If you know the size of the O-ring you want, you can get anything from McMaster-Carr (McMaster-Carr). This is a great source for all sorts of parts and tools. The O-rings can be searched by material, shape, thickness, inside diameter, and outside diameter.
Unfortunately, you'll have to buy a package of 10 or 50, depending on the ring. But if a few people can figure out how to share a package, you can mail two or three O-rings in a one ounce letter. (A confession: I bought a package of 50 to replace the missing (oxidized) O-ring on the bottom of a Gitzo tripod center column. Mailed a bunch to people who needed them so I didn't feel so silly for spending twelve or fifteen dollars for a package of O-rings.)
stephengilbert is offline   Reply With Quote
Old 25.04.2009, 19:47   2 links from elsewhere to this Post. Click to view. #29 (permalink)
lct
Erfahrener Benutzer
lct's Avatar
Quote:
Would be interesting to compare it with mine. 100% DIY but needs a bit of grinding though.
One just needs:
- a 39mm UV-IR Leica filter (#13410)
- a Leica hood #12518 dedicated to the 'cron 40/2
- a 37mm rubber ring
- a pin and a die grinder
1. Grind the filter housing of the hood in order to enlarge its inner diameter to 37mm:
2. Remove the blocking ring of the filter with a pin or same:
3. Insert the glass into the filter housing:
4. Insert the rubber ring over the glass:
5. Screw-in the hood and that's all.
Old 25.04.2009, 19:48   #30 (permalink)
lct
Erfahrener Benutzer
lct's Avatar
Here's the result:
Old 25.04.2009, 19:55   #31 (permalink)
Erfahrener Benutzer
graeme_hutton's Avatar
Very neat indeed!
(from a man who simply screwed in a Leica E39 'fit and forget'!)
Best
Graeme
graeme_hutton is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/leica-m8-forum/33989-uv-ir-filter-leica-summicron-c.html
Posted By For Type Date
Forum - UV/IR filter used on Summicron-C 40mm Post #0 Refback 11.05.2009 04:30
Forum - UV/IR filter used on Summicron-C 40mm Post #0 Refback 10.05.2009 15:41
Lens choice for my futur M8 - Rangefinderforum.com This thread Refback 22.02.2009 06:05
Lens choice for my futur M8 - Rangefinderforum.com This thread Refback 18.02.2009 14:02
40mm f2.0 Summicron? - The GetDPI Workshop Forums Post #0 Refback 30.09.2008 05:04
40mm f2.0 Summicron? - The GetDPI Workshop Forums Post #0 Refback 19.08.2008 23:59
40mm f2.0 Summicron? - The GetDPI Workshop Forums Post #0 Refback 19.08.2008 23:08
40mm f2.0 Summicron? - The GetDPI Workshop Forums Post #0 Refback 19.08.2008 21:48
UV/IR filter for Leica Summicron-C 40mm - Leica User Forum This thread Refback 06.10.2007 09:26
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
