Leica User Forum B+H
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 08/17/07, 01:03 PM   #101 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Default Re: Best M8 DNG converter?
Quote:
Originally Posted by guy_mancuso View Post
So folks a good lesson today , is if you run into this just back off the focusing very slightly, images will still be plenty sharp but you can avoid this.
Kinda puts the backfocus threads into perspective doesn't it? It's an asset!
__________________
Jaap
WWW.JAAPVPHOTOGRAPHY.EU
Skype: JAAPVPHOTOGRAPHY
jaapv is offline   Reply With Quote
Old 08/17/07, 01:14 PM   #102 (permalink)
Erfahrener Benutzer
hankg's Avatar
You can fix it manually in post (providing there is no detail in the moire). Mask out the offending section and copy and paste it to another layer. The green channel has the least moire in this case so I used channel mixer to make all 3 channels duplicates of the green so less blur is needed. Blur the image until the moire is gone. Use the mask to KO the bleed at the edges. Color balance to match the original.
It doesn't take long for something like this but I wouldn't want to be fixing a whole catalog of images. I did a partial section indicated by the red lines so you could compare. Second one has a slight amount of grain added for texture.
__________________
Hank Graber
www.hankgraber.com
hankg is offline   Reply With Quote
Old 08/17/07, 01:17 PM   #103 (permalink)
Erfahrener Benutzer
hankg's Avatar
You could also composite in focus and slightly out of focus shots if you are photographing static objects from a tripod. But that won't be the case for event photographers or the odd bit of moire that unexpectedly pops up.
__________________
Hank Graber
www.hankgraber.com
Old 08/17/07, 02:13 PM   #104 (permalink)
Erfahrener Benutzer
Thanks Hank I will try that today
__________________
Guy Mancuso
www.guymancusophoto.com
Upcoming GetDPI.com Photographic Workshops
"It's not always about what the client will accept but about what you want to deliver to your client."
guy_mancuso is offline   Reply With Quote
Old 08/17/07, 02:45 PM   #105 (permalink)
jlm
Erfahrener Benutzer
re the M8 and tethered: any hints about Capture 1, 4 still due out in 2007?
jlm is offline   Reply With Quote
Old 08/17/07, 02:50 PM   #106 (permalink)
Erfahrener Benutzer
John if you want to shoot tetehered with C1 you still have to use the digital capture software , than with C1 like LR you have to point to the same folder for it to work. So both software packages are open and working. i think that is the work around for C1 , in LR you auto import from that same folder. I usually make a folder on the desktop and use that
Version 4 is overdue from there promised dates
__________________
Guy Mancuso
Old 08/17/07, 05:24 PM   #107 (permalink)
Erfahrener Benutzer
I was under the impression that 4.0 lite was due out in early summer (hence overdue) but that heavy(?) was due at the end of 07.
ericperlberg is offline   Reply With Quote
Old 08/17/07, 05:32 PM   #108 (permalink)
Erfahrener Benutzer
I heard May for LE and July for Pro.
__________________
Guy Mancuso
Old 08/17/07, 05:41 PM   #109 (permalink)
Erfahrener Benutzer
... it can happen and you don't know until post time.
When working in a controlled environment (like Guy's studio shot,) if you notice the moire at the time of capture, often rotating the camera a few degrees will eliminate or greatly reduce it. Also, moving slightly closer or farther away from the subject can have a similar effect. Making the pattern of the weave a different size or orientation is the key. Then you simply straighten the shot with a re-crop in post.
Doesn't always work completely, but it does almost always HELP, and reduces post-process fiddling (and time!)
T
__________________
Tom Hassler
www.tomhasslerphoto.com
teehas53 is offline   Reply With Quote
Old 08/17/07, 05:57 PM   #110 (permalink)
Erfahrener Benutzer
That was in the original photokina 06 press release wasn't it? Here's a thread with posts from Keith Carpentar at Phase One Support comments on releases.
A summary might be:
Posted on June 14 2007
"Full Support with Free UpDate 3.7.8 due at end of this month / early July
4.0 LE version UpGrade will arrive first followed by the PRO and DB versions.
All versions are expected later this year ~ 2007~ when they are ready for Final Release."
Posted on June 26 2007
"Currently, there is only an LE Alpha version, and No Beta Version of 4.0 is available. "
With LE in Alpha in late June one can only guess the rest.
Old 08/17/07, 06:00 PM   #111 (permalink)
Erfahrener Benutzer
Thanks Eric for finding that
__________________
Guy Mancuso
Old 08/17/07, 06:52 PM   #112 (permalink)
Erfahrener Benutzer
Well I did it and it took some work but i did a lot of lasso and feather and used surface blur which wiped it out completely but than i had to be careful with lines and such . But than added grain and brought it back . It looks pretty good now. Whew that was a little work
__________________
Guy Mancuso
Old 08/17/07, 06:54 PM   #113 (permalink)
Erfahrener Benutzer
heres the orginal again
__________________
Guy Mancuso
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Using the Jobo Giga Vu Pro Evo with M8 DNG files 4season Leica M8 Forum 20 03/05/08 04:35 PM
The Shrinking M8 Files roccoriley Leica M8 Forum 10 04/24/07 07:59 AM
DNG und JPAG in Lightroom B/W Fotografie M8 querstrommotor Digitalforum 2 04/20/07 10:11 PM
16bit DNG Please -Nanny does not always know best. eronald Digital Forum 65 03/25/07 10:59 PM
M8 Yachts on the Horizon at Sunset DNG Challenge! Asher Kelman Digital Forum 0 12/24/06 01:44 AM
