Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
 Leica Products
LEICA S2
LEICA M9
LEICA M7
LEICA MP
LEICA M Lenses
LEICA X1
LEICA D-Lux 4
LEICA V-LUX 20
eBay Amazon | eBay Amazon | eBay Amazon | eBay eBay Amazon | eBay Amazon | eBay Amazon | eBay
Register now
Old 22.05.2007, 23:34   #1 (permalink)
Erfahrener Benutzer
Default Base plate failure,
Something to watch for with these cameras. I was checking the focus of my 50 f1.4ASPH, and had the camera tilted forward and it suddenly came off the tripod. I thought I had forgotten to close the clamp on the tripod head, but when I looked at the camera I could see what happened. I don’t know if this was just metal fatigue with my particular camera (which has never been dropped or abused), or an inherent design weakness.
Other pictures are here:
http://homepage.mac.com/billh96007/PhotoAlbum228.html
Bill
billh is offline   Reply With Quote
Old 23.05.2007, 00:02   #2 (permalink)
Erfahrener Benutzer
jonoslack's Avatar
Default Re: Base plate failure,
Ouch
that looks horrible, it had never occurred to me, even as a possibility.
I will be very careful!
Truth be told, the only thing i really miss with the M8 is the way the base plate fitted, with that lovely curved piece of metal
__________________
kind regards
jono slack
Field Testing the Leica M9 (Book)
jonoslack is offline   Reply With Quote
Old 23.05.2007, 00:07   #3 (permalink)
Erfahrener Benutzer
James Mitchell's Avatar
I wonder how much the Luigi case with tripod screw would help to prevent this from happening.
James Mitchell is offline   Reply With Quote
Old 23.05.2007, 00:09   #4 (permalink)
Erfahrener Benutzer
george's Avatar
Oh, Bill . . .
sorry about your incident. They should replace this instantly - and I am confident that they will.
As to your question, in over fifty years of Leica use I never saw anything like this. The baseplate solution of the older models with the semi-round pin looked stronger. But that is the other side anyway.
The failed metal looks brittle as hell. Wonder what may have caused this. And white metal? What is it?
Hope you get a resolution fast!
__________________
George
george is offline   Reply With Quote
Old 23.05.2007, 00:31   #5 (permalink)
Erfahrener Benutzer
Wow, that's a failure of the magnesium alloy casting and because it's the front half, it's a huge job to replace.
Gulp. The sensor is attached to this casting and shims are used to set the correct alignment with the lens mount, so it's not just a case of unscrewing everything and attaching to a new casting, it has to go through a full sensor mechanical alignment.
My guess is they will give you a new camera...
__________________
Mark
marknorton is offline   Reply With Quote
Old 23.05.2007, 00:33   #6 (permalink)
Erfahrener Benutzer
Quote:
Some sort of magnesium alloy - a cheap and common material for the chassis of cameras, laptops, etc.
__________________
Ian Watts
wattsy is offline   Reply With Quote
Old 23.05.2007, 00:45   #7 (permalink)
Erfahrener Benutzer
DaveB's Avatar
Quote:
Originally Posted by wattsy View Post
a cheap and common material for the chassis of cameras, etc.
An example of the LHSA Plastic Edition, apparently.
DaveB is offline   Reply With Quote
Old 23.05.2007, 00:57   #8 (permalink)
Erfahrener Benutzer
After close examination of my baseplate locking side I see where there is a cracked off section that someone has tried to repair. See the images.
I'm going to be sending my M8 in to NJ shortly for the brass colored spots that seem to be under the cover glass so I will also send these images in with it and a very stern letter about the spots and this repair done on a $5000 camera that is supposed to be NEW.
To the OP can I make a copy of your image to send in with my camera?
Shootist is offline   Reply With Quote
Old 23.05.2007, 00:58   #9 (permalink)
Erfahrener Benutzer
fotografr's Avatar
I wonder if this weakness is caused by putting the tripod socket in the middle of the baseplate. When it was on the end, it was close to the point where the pin fits into the opening. That area is fairly secure. After seeing Bill's photos, I grasped the base plate on my M8 with my thumb and forefinger and exerted pressure front to back. There was enough play in the metal to cause me to wonder if using a tripod might not be a bad idea with this camera.
__________________
Brent
http://brentnicastrophotography.com/
The hardest thing is to photograph a black cat in a dark room. Especially if there is no cat.
fotografr is offline   Reply With Quote
Old 23.05.2007, 01:01   #10 (permalink)
Erfahrener Benutzer
Eoin's Avatar
Sorry to see your plight Bill. Just a thought, if you place the QR plate with the base plate onto the RRS clamp and close the leaver is there any distortion on the M8 base plate?.
Looks like a weak spot and as mark says very expensive to repair once out of warranty.
Eoin is offline   Reply With Quote
Old 23.05.2007, 01:03   #11 (permalink)
Erfahrener Benutzer
gravastar's Avatar
That certainly makes me wonder about the wisdom of tripod mounting the camera with a heavy lens such as the 135/2.8 with goggles or bellows - best to use the tripod mount on the lens. It looks as if any long lens could exert a large turning moment on the base plate attachment point. A weakness would appear to be that the attachment is at the unsupported end of the casting - it's not joined to the other half of the casting.
Bob.
gravastar is offline   Reply With Quote
Old 23.05.2007, 01:11   #12 (permalink)
Erfahrener Benutzer
Ed, of course you can. A link to them is:
Your photos are illuminating too - that does not look very good....
The odd thing is, if the bloody camera was focusing accurately, it never would have been on a tripod for the lens focus test.
Old 23.05.2007, 01:37   #13 (permalink)
Erfahrener Benutzer
Eion,
I can't because it still has the piece of broken metal, and I want to sent it to Leica so they can see exactly how it failed.
Old 23.05.2007, 01:45   #14 (permalink)
Erfahrener Benutzer
Enoteca's Avatar
Default AW: Re: Base plate failure,
Oh, Bill . . .
Magnesium
__________________
Schönen Gruß aus Freiburg, Magenta-Forest
Manfred
Enoteca is offline   Reply With Quote
Old 23.05.2007, 02:14   #15 (permalink)
Erfahrener Benutzer
Default Re: AW: Re: Base plate failure,
Quote:
Originally Posted by Enoteca View Post
Magnesium
I just looked at my M7 and M4s, and they do not have this split I see in Ed’s photo - also, they appear to be a different metal. Do you know what they used in the previous Ms, and why they changed the design (and perhaps the choice of metal) in the M8?
Old 23.05.2007, 02:33   #16 (permalink)
Erfahrener Benutzer
Outch,
small cast lip cantelievered off of a thin casting at a right angle is just the thing to cause a stress concentration.
The wear strip/reinforcement should help a little as long as those screws are snug, but this design seems hazerdous for a metal as non-ductile as (I assume) pressure cast magnesium.
-bob
rwfreund is offline   Reply With Quote
Old 23.05.2007, 02:42   #17 (permalink)
Erfahrener Benutzer
With all the film M's the locking lug on the body was screwed into the main center section of the camera. Completely different then the M8.
I have a feeling yours will not be the only M8 that has this problem.
Oh and all I have to look at is a M3 but that model has a full cast shell, one piece, where as the M8 is 2 halfs screwed together.
Old 23.05.2007, 05:00   #18 (permalink)
Erfahrener Benutzer
Joe Mondello's Avatar
Default Second Base plate failure
Wow, this is the second base plate failure I've read about.
Can't find the link now but the failure was at the other end of the plate where the tab is, The base plate failed at that spot where the metal is thinnest.
I guess we'd all best mind how we handle the "auf<>zu" from now on!
nice macros BTW!
Joe Mondello is offline   Reply With Quote
Old 23.05.2007, 05:19   #19 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by rwfreund View Post
Outch,
Indeed, and it's the adjustment of the baseplate latch which will determine how much pressure is applied to the casting when the baseplate is on; you want it to be tight enough to hold the baseplate securely but not so tight as to put undue stress on the casting.
Put the camera on a tripod though and forces on the tripod mount (for example, inadvertently letting the camera carry the weight of the tripod) will put extra stress on the bracket.
Which gets me thinking about holding the camera by just the the grip with a heavy lens attached... casting fractures and camera and lens fall to earth...
__________________
Mark
Old 23.05.2007, 05:24   #20 (permalink)
Erfahrener Benutzer
Default Re: Second Base plate failure
Thank you for posting that warning, Bill. This is a particularly disturbing failure since that base plate has the same functional design mission as a tit on a bull.
__________________
- Ken Tanaka -
ken_tanaka is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/leica-m8-forum/25121-base-plate-failure.html
Posted By For Type Date
Leica M8 - kokemuksia? This thread Refback 19.02.2010 20:34
D(isappointing)5000 - rec.photo.digital.slr-systems | Google Groups This thread Refback 29.09.2009 09:35
Leica M8 - kokemuksia? This thread Refback 22.09.2009 20:13
[Leica] Report of M8 Base Failure This thread Refback 30.08.2009 07:06
rec.photo.digital.slr-systems | Google Groups This thread Refback 21.08.2009 04:49
Leica M8 - kokemuksia? This thread Refback 18.02.2009 14:35
Leica M8 - kokemuksia? This thread Refback 18.02.2009 11:03
Leica M8 - kokemuksia? This thread Refback 17.02.2009 22:07
Leica M8 - kokemuksia? This thread Refback 17.02.2009 21:56
[Leica] Report of M8 Base Failure This thread Refback 15.08.2008 23:51
Kokeile M8-kameraa! This thread Refback 15.08.2008 09:49
Kokeile M8-kameraa! This thread Refback 15.08.2008 09:44
Kokeile M8-kameraa! This thread Refback 15.08.2008 09:30
Kokeile M8-kameraa! This thread Refback 14.08.2008 21:54
More fun with the Leica M8 - rec.photo.digital | Google Groups This thread Refback 14.08.2008 21:08
rec.photo.digital | Google Groups This thread Refback 14.08.2008 14:51
More fun with the Leica M8 - rec.photo.digital | Google Groups This thread Refback 14.08.2008 11:51
M8 Warning, camera shell failure - Photo.net Leica and Rangefinders Forum This thread Refback 12.08.2008 10:48
M8 Warning, camera shell failure - Photo.net Leica and Rangefinders Forum This thread Refback 12.08.2008 10:42
[Leica] Report of M8 Base Failure This thread Refback 25.05.2007 12:24
[Leica] Report of M8 Base Failure This thread Refback 24.05.2007 20:03
[Leica] Report of M8 Base Failure This thread Refback 24.05.2007 10:10
[Leica] Report of M8 Base Failure This thread Refback 24.05.2007 07:01
[Leica] Report of M8 Base Failure This thread Refback 24.05.2007 02:41
[Leica] Report of M8 Base Failure This thread Refback 24.05.2007 02:37
Similar Threads
Thread Thread Starter Forum Replies Last Post
M8 Shutter Failure psquared Leica M8 Forum 2 24.04.2007 00:36
Low profile Arca-swiss plate? deltoid1 Digital Forum 6 21.02.2007 19:26
Quick Release plate for M8? gurtch Digital Forum 15 12.12.2006 22:14
M8 Base Plate Dimension A.Brunner Digital Forum 4 13.10.2006 13:36
Base Plate for M6TTL and M7 ckli Customer Forum 3 17.09.2006 16:02
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.1
