| Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8. |
LinkBack (25) | Thread Tools | Display Modes |
#381 (permalink) | |
Erfahrener Benutzer
Quote:
Of course, not every camera is getting a free pass from all of that, because not all case should be treated equal. Some do misuse their cameras more than others, and this is what Leica said for Godfrey's case. 5 incidents are a real small sample that can verify the fact that there is a small very small chance for it to break. |
#382 (permalink) |
Erfahrener Benutzer
Perhaps it's helpful to think of it in these terms:
Imagine a vast aircraft hanger or warehouse where laid out on tables are 200 rows of boxed M8s, and each row is 100 M8s deep. You are told that 5 of the 20,000 M8s will have a problem where the body shell will break but that Leica will fix for free and you can buy any of the M8s. Would the presence of those 5 stop you from choosing and buying one of the 20,000 M8s? Pete.
__________________
Eur. Ing. Pete F@rnsworth Live and let live. |
#383 (permalink) |
Erfahrener Benutzer
Maybe, some believe that because they pay a lot for their camera (M8) they can also expect to demand a lot, even if they miss treat the cameras. Every product and M8 is no exception follows some very specific specs. I wonder if something like that ever happened to a Canon how would Canon have reacted? What did you believe? Alan?
#384 (permalink) | |
Erfahrener Benutzer
Quote:
If the tripod mount of a pro model Canon or Nikon ripped out it would probably have to be the result of a camera and tripod falling a considerable distance. Hence it would be abuse. I've had a Canon 1Ds and tripod topple over onto a hard floor with no damage. I would expect that I could grasp a Canon or Nikon (pro models) while it is on a heavy tripod and lift the tripod up and swing it around with no damage too. Back to tripod mounting. I think knowing that there is even a 1 in 6000 chance that tripod mounting could fail on any camera would really disturb me. I work on a tripod a lot and often use panorama heads with the camera in a vertical position. And I have used gyro stabilizers for aerial work. Carrying a tripod over my shoulder with a camera attached is something I've done with every camera I have owned. Most of these cameras weighed a lot more than an M8. Specifically, what bothers me about the M8 base plate mounting isn't just the possibility of the failure, it is my inability to understand how Leica could have designed it that way in the first place. And why haven't they redesigned it or beefed it up since. This seems so simple. So it is more about how my respect for Leica is diminished than anything else. I used to own a Leica Ortholux microscope. (60s vintage) You should look at one of those if you want to see the level of craftsmanship I used to expect from Leica. |
#385 (permalink) | ||||
Erfahrener Benutzer
Understood, but the situation isn't usefully comparable in too many details. We could argue about the similarities and differences, but that seems pointless.
Quote:
Quote:
Quote:
I spoke to one manufacturer of camera mounting plates that unequivocally told me carrying any camera on a tripod was foolish. I bet they've seen some interesting failures. I still do it---I've got a Phillips 4x5 that could stand tripod-attached abuse that would put any Leica, Canon or Nikon to shame! Quote:
I don't quite understand why this dead horse is getting such a beating, but to each his own. Until later, Clyde |
#388 (permalink) | |
Erfahrener Benutzer
Quote:
You can still carry your camera around with your tripod, but you should realize that you do this on your own. And that any camera can eventually break lose, simply because forces that developing this way are more times more powerful than by just using it as intended. It might break it might not break, but this is your fault. Really I don't see where the problem is, we are talking about a camera body of what? $5k? The manufacturer admitted that if that alloy breaks he will replace free of charge, so he secured you even more. What else do you need? To hang the designer by the neck in a public place? |
#389 (permalink) |
Erfahrener Benutzer
I think AlanG has completely lost it when he says a 1 in 6000 chance of the tripod mounting failing "would really disturb him". How do you ever get out of bed in the morning?
Let's say, he's 50. He also has a 1 in 200 chance of dying in the next year, an event 30 times more likely than his M8 falling to earth and, I would submit, a rather greater cause for him to be concerned.
__________________
Mark |
#391 (permalink) | |
Erfahrener Benutzer
Quote:
The 1 in 6000 odds disturb me because they should be zero percent chance of failure in what I consider normal use. Plus as I previously wrote, I think Leica's designers should be better than this. The tripod mount on my Canon SD800 pocket size p&s looks much better than the M8's. I simply don't like having the tripod mount being part of a removable base. Additionally, I don't buy that 6,000 to 1 figure because I believe more cameras have or will fail. Now if you wish to recalculate the odds of failure assuming every camera will be steadily used the way I use my cameras, then the odds might change dramatically to 1 in 100 or 1 in 10. But I couldn't do most of my types of work with an M8 if I wanted to. So it would get pretty light usage in my hands. As for strength, here is a photo of me lifting a Linhof tripod that weighs about 10 lbs. I am leveraging this in the air solely by holding the body of a basic 50s era Pentax. The forces were pretty great as I could barely hold it while waiting for the self timer to trigger. I did this a few times and saw no signs of strain or damage. As you can see, the socket is strongly attached to the frame of the camera. Now if we repeat this test with 30,000 M8s, I wonder how many will break? I also closely examined the mounting plate on my Rollei 6006 and it is exceptionally strong and well designed. That is the kind of construction that I expect from a camera that will be employed by professionals. Last edited by AlanG; 07.09.2008 at 20:13. |
#392 (permalink) |
Benutzer
I'm sorry to post a reply almost a year later but I only saw this now. I must post this to make the information complete. I had not used a 6006 but I did have a 6008i. The mounting plate had a design flaw. The electronics of the 6008i shorted the circuits so that you could not fire a flash when the camera is mounted on a tripod. It's such a well known problem that Rollei actually sold a separate tripod mount to get around this problem.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| M8 Shutter Failure | psquared | Leica M8 Forum | 2 | 24.04.2007 00:36 |
| Low profile Arca-swiss plate? | deltoid1 | Digital Forum | 6 | 21.02.2007 19:26 |
| Quick Release plate for M8? | gurtch | Digital Forum | 15 | 12.12.2006 22:14 |
| M8 Base Plate Dimension | A.Brunner | Digital Forum | 4 | 13.10.2006 13:36 |
| Base Plate for M6TTL and M7 | ckli | Customer Forum | 3 | 17.09.2006 16:02 |
