Leica User Forum 5% Discount for Forum Members
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
Old 05/03/07, 07:18 AM   #1 (permalink)
Erfahrener Benutzer
Default magenta @ 50mm
i recently bought a pre-asph 50mm lux and getting the same magenta results as we all have at 15-35mm range. is that normal? i thought magenta was only an issue for wides?
thanks
m
misha is offline   Reply With Quote
Old 05/03/07, 07:34 AM   #2 (permalink)
Erfahrener Benutzer
adan's Avatar
Default Re: magenta @ 50mm
Magenta IR contamination will happen on the M8 with any unfiltered lens. Focal length is not a factor.
The issue with wide-angles (<35mm) is that the corners turn green or cyan WITH IR-blocking filters (while the magenta is mostly eliminated), and therefore wides need coding to declare the focal length, and the corrective firmware (v. 1.1+) , in which case the camera can correct for the "cyan drift" after exposure.
The deal with your 50 is that, IF you get an IR filter for it, it will not show the green-corner effect, and thus will not require the 6-bit coding spots and any firmware corrections (unless you just want the focal length recorded in the metadata).
adan is offline   Reply With Quote
Old 05/03/07, 07:48 AM   #3 (permalink)
Erfahrener Benutzer
got it (i think) .
thanks a lot for a quick and elaborate explanation.
misha
Old 05/03/07, 08:56 AM   #4 (permalink)
Erfahrener Benutzer
Andy explained that well. The 50s will show a little bit of cyan drift but it's minor.
Cheers,
Sean
__________________
Sean Reid
http://www.reidreviews.com
sean_reid is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
50mm Summicron-M replacement Peter Branch Customer Forum 21 05/03/07 04:44 PM
90mm elmarit & 50mm Cron (rigid) with M8 JWW Leica M8 Forum 1 04/14/07 06:19 PM
IR Magenta and 1.092 without filter jonoslack Digital Forum 22 03/19/07 07:11 PM
Magenta madness Hans Roggen Digital Forum 9 01/20/07 10:50 AM
Need advices on M 50mm lenses bono0272 Customer Forum 59 09/07/06 08:24 AM
