Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
Old 04/24/07, 03:14 AM   #1 (permalink)
Benutzer
Default The Shrinking M8 Files
I have several questions having to do with the D8 DNG files.
1. What does the Adobe DNG converter do?
2. Why do my 10.2 Meg D8 DNG files shrink to 6 Megs after processing by the Adobe DNG converter.
3. What are the differences between the different DNG files, I thought Adobe's objective was to provide a standard portable format for all digital negatives but if there are different formats then that objective has not been achieved.
4. If the Leica M8 DNG files are being processed by the Adobe Converter and are losing 40% of their bytes then are we losing critical image information when we convert using this converter?
5. Should we be archiving the original M8 DNG files insted of the files that are produced by Adobe DNG converter?
As you can tell, I am new to the Leica M8 world!!
roccoriley is offline   Reply With Quote
Old 04/24/07, 03:28 AM   #2 (permalink)
RSL
Erfahrener Benutzer
RSL's Avatar
Default Re: The Shrinking M8 Files
1. The DNG converter simply compresses the file. If you're using it with any other format, such as .NEF, it converts the other format to DNG and compresses it. You don't have to use compression, but it's lossless, so why not?
2. Because they're being compressed with lossless compression.
3. There isn't any noticeable difference. Some earlier DNG files were slightly different, but DNG is backward compatible. Leica may be adding some stuff to the M8 DNG files, since DNG allows that, but, in essence, DNG is DNG, just as parts is parts.
4. You're not losing any information, critical or otherwise. The M8 does a whirlygig non-linear compression of some of the high data to 8 bits, but the resulting file is difficult, if not impossible, to tell from full "16 bit" files.
5. That's up to you. I can't think of a good reason to hang on to the originals, but maybe someone can come up with one.
__________________
Russell
www.FineArtSnaps.com
www.rslstudio.com
RSL is offline   Reply With Quote
Old 04/24/07, 03:31 AM   #3 (permalink)
Erfahrener Benutzer
adan's Avatar
The purpose of the DNG converter is to convert non-DNG-format RAW files (Nikon NEF, Canon RAW, Sony SR2, etc.) to the DNG format. Since the files straight from the M8 are ALREADY DNGs, why would you want to use the convertor with them? Seems redundant.
I haven't used DNG Converter since I switched from the Sony R1 to the M8 - I just open the files from the M8 directly in Adobe Camera Raw or Capture one or whatever.
adan is offline   Reply With Quote
Old 04/24/07, 03:45 AM   #4 (permalink)
Erfahrener Benutzer
Hi Andy,
The main reason might be to compress them easily and quickly.
Cheers,
Sean
__________________
Sean Reid
http://www.reidreviews.com
sean_reid is offline   Reply With Quote
Old 04/24/07, 05:45 AM   #5 (permalink)
Erfahrener Benutzer
R--
Remember, there are two design standards for DNG.
Leica was the first and so far only company to use the second version, which includes a lookup table.
A big part of what the DNG converter is doing is removing the lookup table and storing the actual value for each pixel rather than a pointer to the point in the LUT where the value is stored.
To me it would be more logical for Leica to have stored the actual value in each location rather than a pointer to where the value is stored, but if they had done that with their compression scheme, apparently it would no longer have matched the DNG specification and would have been considered a RAW file that needed its own RAW conversion algorithm.
Or maybe they knew they'd be getting enough flak for producing a 10 meg DNG and decided that was better than trying to explain a 6 meg version.
You're saving all the data that were there to begin with, just compacting them to fit into a smaller space.
--HC
ho_co is offline   Reply With Quote
Old 04/24/07, 06:01 AM   #6 (permalink)
Benutzer
Thank you all very much for the information.
Old 04/24/07, 06:06 AM   #7 (permalink)
sirvine
Posts: n/a
Incidentally, Lightroom users can perform this conversion automatically on import, if preferred.
Old 04/24/07, 07:43 AM   #8 (permalink)
Erfahrener Benutzer
to see full size previews in photo mechanic and other editing apps.
btw They don't shrink in size if you don't select compression. (they are actually larger with the large preview option)
bsmith is offline   Reply With Quote
Old 04/24/07, 08:07 AM   #9 (permalink)
Neuer Benutzer
If DNG is DNG, then why do some programs open the M8 files and others don't.
I use ACDsee, and, although my version is the latest, and it is set to recognise DNG files, it will not open those from the M8. I cotacted ACDsee about this and was told that their ACD pro does not recognise files from the M8. They said that future updates would.
This means that all DNG files are not the same, and that the M8 files are not as universal as we are led to believe.
yadillah is offline   Reply With Quote
Old 04/24/07, 08:41 AM   #10 (permalink)
Erfahrener Benutzer
Quote:
Yes
Old 04/24/07, 09:59 AM   #11 (permalink)
Erfahrener Benutzer
Default AW: Re: The Shrinking M8 Files
Hello!
Some programs are DNG reader, some programs are only reader of special DNGs.
The developer of this application has not implemented the standard (ISO), he has only implement those, he knows about some DNGs...
M8 DNGs follow 100% the standard, but some (and also expensive) applications have only a SUBSET of the standard implemented!
isaac is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Official Leica Statements sean_reid Digital Forum 359 03/05/07 01:12 PM
M and R lens Character guy_mancuso Digital Forum 57 01/12/07 07:28 PM
M8 debunking the theory of the M line guy_mancuso Digital Forum 64 12/12/06 09:10 PM
Camera gamuts and the M8 markedavison Digital Forum 0 11/15/06 09:04 PM
Hands-on trial with beta-M8 adan Digital Forum 20 09/25/06 08:29 PM
