Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
Old 04/14/07, 10:08 PM   #1 (permalink)
Neuer Benutzer
cottonc's Avatar
Default Best practices for M8 batteries?
Any sound advice to have them last long?
Cotton
__________________
Cotton Coulson
Keenpress
Oestbanegade 19 St tv
2100 Copenhagen Denmark
www.keenpress.com
Member of Advisory Board for
Aperture Users Professional Network
http://apertureprofessional.com/
cottonc is offline   Reply With Quote
Old 04/15/07, 12:00 AM   #2 (permalink)
Benutzer
Default Re: Best practices for M8 batteries?
I let my batteries drain down completely before recharging. I learned this from using lithium ion batteries for laptop computers. This is known as "conditioning" tn he battery.
gerasdoc is offline   Reply With Quote
Old 04/15/07, 12:03 AM   #3 (permalink)
Benutzer
I've never done anything special to condition my 2 batteries. they easily allow me to fill a 4Gb card with raw images. when i change the card, i change the battery.
willemvelthoven is offline   Reply With Quote
Old 04/15/07, 12:46 AM   #4 (permalink)
Erfahrener Benutzer
my understanding of Li-ion batteries is that they degrade at a constant level regardless of use, mainly time is the issue. this in terms of laptop batteries, I once bought two apple laptop batteries with the idea that I would use one and conserve the other, but after 18 months both batteries exhibited the same charge-drain characteristics, they were about half as effective.
also my understanding is that they do not exhibit the memory effect of ni-cads that do need charge-discharge cycles.
so far I have done nothing special, run the batteries until no bars are showing, even ran one down until the camera shut off (incidently, no sign on the lcd like "battery low" that I saw) and all has been well on this camera.
robertwright is offline   Reply With Quote
Old 04/15/07, 02:16 AM   #5 (permalink)
Erfahrener Benutzer
All batteries have their lives shortened by deep discharge cycles, but we have gotten used to this because it is needed in the Ni-Cd and Ni-Metal systems. It is not necessary for Li-Ion batteries to be deep-cycled more than a few times at first and maybe once every half year after that (to ensure that the voltages of the battery when fully charged and when discharged match the camera's prejudices). So charge them whenever you aren't using them.
There is some reason to believe that the infrequent sudden death syndrome (SDS) occurs when batteries discharge too rapidly near the end of their cycle, so it you want to be extra safe, change or charge your battery when it reaches zero bars.
scott
__________________
___________________
www.pbase.com/skirkp
www.cs.huji.ac.il/~kirk
scott kirkpatrick is offline   Reply With Quote
Old 04/15/07, 02:22 AM   #6 (permalink)
Erfahrener Benutzer
mboerma's Avatar
Hi,
Maybe these tips from Apple will also help:
http://www.apple.com/batteries/notebooks.html
Maarten
mboerma is offline   Reply With Quote
Old 04/15/07, 02:24 AM   #7 (permalink)
Erfahrener Benutzer
neelin's Avatar
Lithium-ion battery - Wikipedia, the free encyclopedia
more than you wanted to know.
exec. summary, store at 0 degrees C at 1/2 charge or thereabouts.
neelin is offline   Reply With Quote
Old 04/15/07, 05:51 AM   #8 (permalink)
Erfahrener Benutzer
scott
i think it might have had to do with my first M8 sds, in my excitement I took the camera with me for the day after only a partial charge cycle from new, and I believe it suddenly lost power at the end of the day, and after that it was never recoverable, even after charging the battery.
that being said, my current M8, yesterday the camera which had had the battery in for a few days and was running down, was on zero bars for a little while, I was hoping to see the flashing bars indicating 5%, but I did not, it just shut down completely. I put a fresh battery in and it worked normally-no sds. so these are two examples of running out of power unexpectedly, but I believe someting is different with the replacement camera, so it was not a problem this time.
Old 04/15/07, 06:11 AM   #9 (permalink)
Erfahrener Benutzer
arthury's Avatar
Quote:
This may be true for a reasonably comfortable temperature but the life-time of a single charge will drop significantly if the surrounding atmospheric temperature which the camera is in is really low. I experienced the same thing as you in warm weather but when I was at Alaska in early spring when the outdoor temperature was hovering in single digits (deg F), the Leica battery only lasted for 2-3 hours with a single charge.
arthury is offline   Reply With Quote
Old 04/15/07, 07:47 AM   #10 (permalink)
Erfahrener Benutzer
Quote:
Things stop working pretty quickly. I've monitored the discharge of the M8 battery every 5-10 minutes close to shutdown http://www.leica-camera-user.com/dig...tml#post223054
and still never saw the indicator go into the flashing mode, so I think zero bars is a more reliable indicator to look for as the signal to stop using that battery.
scott
__________________
___________________
Old 04/15/07, 08:18 AM   #11 (permalink)
Erfahrener Benutzer
doubice's Avatar
This is the best information on Li-Ion batteries I have read - ever! Thanks for the link!
Jan
doubice is offline   Reply With Quote
Old 04/15/07, 03:11 PM   #12 (permalink)
Erfahrener Benutzer
scott
I hope they are working on this for a new firmware revision, it does not inspire confidence to have the camera shut off without warning. I mean, they went to the trouble to put it in the manual...
Old 04/15/07, 10:16 PM   #13 (permalink)
Erfahrener Benutzer
Quote:
Not good. See http://www.kenrockwell.com/tech/battery-life.htm
".....Modern Li-ion batteries love to be charged often. They don't like being fully discharged. This is completely opposite from older style batteries."
Skippy Sanchez is offline   Reply With Quote
Old 04/16/07, 08:26 AM   #14 (permalink)
Erfahrener Benutzer
mboerma's Avatar
Discharging Li-Ions completely is not recommended. It also takes considerably longer to recharge and it does not do any good to the battery.
Maarten
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Best way to mark additional M8 batteries is ... grober Leica M8 Forum 6 04/04/07 05:48 PM
Leicasonic batteries: fx-01 vs D-LUX 2 biglouis Digital Forum 2 01/18/07 03:43 PM
Kodak Batteries Annibale G. Customer Forum 1 01/18/07 03:04 PM
Best of the Best ddp Customer Forum 20 01/15/07 04:20 PM
M8 Batteries in London chris_tribble Digital Forum 0 01/10/07 03:18 PM
