| Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8. |
#1 (permalink) | |
Neuer Benutzer
Quote:
louis |
| Advertisement (gone after free registration) |
#2 (permalink) | |
Erfahrener Benutzer
Quote:
#3 (permalink) | |
Erfahrener Benutzer
Quote:
If anyone hears back from the German gnomes please share here.
__________________
- Ken Tanaka - |
#4 (permalink) |
Erfahrener Benutzer
Same problem here. Not after a FW update but rather after the first week of usage. Some people might find it No problem but I sometimes need to have a camera ready to shoot at an instant. Like this it seems to take forever.
kind regards, Etienne
__________________
http://www.wfa-photo.eu |
#5 (permalink) |
Benutzer
My M8 (December vintage) started out not requiring a push of the shutter button to turn it on but one day it simply froze and had to be reset by removing the battery and replacing and ever since then it has required a firm press of the shutter after being turned on to bring it to life.
I feel that it's a bit of a ticking time bomb as others have reported that this was there first step towards a total camera failure. I am vacation in SE Asia currently in Saigon and it's working very well despite some inane WB results eg two shots taken on a tripod within a couple of seconds of each other have markedly different WB. It will make batch correcting of WB in post impossible - what a pain! |
#6 (permalink) |
Erfahrener Benutzer
Dear M8 Fans...
I had the same problem with my M8, and i thought, that it was also after the last firmwareupdate - but my shop here in Berlin told me, that the on/off switch has a defect. So we send the camera to solms and after 14 days they sent it back and everything was as usual. So you do not have to push the trigger after turning the camera on - that is not normal and as Leica tols me it has nothing to do with the firmware. Within that repairment they adjusted also the Bajonett, because it was so hard to change lenses, much harder than with my m6 - now it works equal to the m6. To check if you have a defect on/off switch, do the following: Turn the camera on in absolutely slow motion, with a little bit of pressure to the switch, try it several times... If the camera turns on now, with this solw-mo procedure, you have a defect switch. You have to try it, it does not work all the time, you have to figure ot the right speed for this procedere. By the way, the strange thing with the switch is, that only the on/off procedere behaves like i explained, the other switch positions worked normal with my m8... Good luck, yours Ekki |
#7 (permalink) | |
Erfahrener Benutzer
Quote:
You are correct. A little pressue and slow turn on means no shutter press. Oh well. I guess I will live with it until after my vacation, then send it in ![]() |
#8 (permalink) |
Erfahrener Benutzer
Thanks, for trying that - i could also not beleeve that behaviour of the m8...
Maybe it is also the reasen for some sudden death problems, because if the switch does strange things it might be also a reason for the sudden death problems, i red abot here. Greetings Ekki |
#9 (permalink) | |
Erfahrener Benutzer
Quote:
I really don't know why some think this is some type of feature of there particular model/version when it is CLEARLY a problem with the camera and needs to be fixed. |
#10 (permalink) | |
Erfahrener Benutzer
Quote:
#11 (permalink) |
Erfahrener Benutzer
I have a perfectly working camera, but if I play this game with the turn-on switch I can eventually get my camera to the on position, but the menu buttons do not work until I press the shutter release down. Normally this does not happen, but I would bet most people with normal working cameras can simulate this problem. I believe this definitely shows that this is a camera defect, and it is in the switch itself and how it sequences the turn on functions.
#14 (permalink) | |
Erfahrener Benutzer
Quote:
I think I'll just live with the problem unless the switch fails entirely.It's disappointing that the M8 was released with so many craftsmanship issues. So much for the Leica reputation in the age of Asian electronics.
__________________
- Ken Tanaka - |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| M8 on Ebay | kodachrome64 | Digital Forum | 3 | 01/27/07 06:08 PM |
| Let's get a statement from Leica on the DR and the M8 | wparsonsgisnet | Digital Forum | 1 | 11/15/06 08:14 PM |
| Has anyone tried a 50mm dual range summicron on the M8? | davidmires | Digital Forum | 0 | 11/05/06 09:59 PM |
| Exposed LCD on M8? - How to protect it? | LarryK | Digital Forum | 16 | 07/17/06 04:04 PM |
| M8 Viewfinder | Rolo | Digital Forum | 86 | 07/12/06 06:17 AM |
