| Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8. |
LinkBack (2) | Thread Tools | Display Modes |
#41 (permalink) |
Benutzer
Rob I can see NOT recommending using the 283 because of the issue regarding early high voltage circuitry that I had alluded to earlier. The issue was resolved many years ago, but since anyone making a recommendation has no way of knowing which vintage of 283 you may have, it may NOT be recommended. All the later ones are quite safe though.
That said, I just tried out a FL-36 on an MP camera since this camera has no dedicated pins. I felt doing this would be safe. Well while I have no idea whether the flash I tried or the camera I tried may have problems but the flash did NOT trigger consistantly. It triggered, I would say maybe 70 percent of the time, so SOMETHING is up. Again, I don't know if maybe there may just be a problem with the flash or camera I used, but I just thought I would share this. Last edited by californiajay; 31.03.2007 at 20:02. |
#42 (permalink) |
Erfahrener Benutzer
well if you think about it
what you are doing may indeed be damaging there is no locating pin i take it and all the other pins are against the flash bracket which could be the same as the neg current side as opposed to a digital dedicated hotshoe, that has a central plastic part, insulating the neg side use card to blank out the pins other than the central primary pin
__________________
Riley Id give my right arm to be ambidextrous |
#44 (permalink) | |
Neuer Benutzer
Quote:
I have an Olympus FL36 which I am keen to use on a Leica M9 (which I am hoping to acquire soon...). Did you ever get a response from Leica about the advisability (or otherwise) of using the FL36 on your M8? (californiajay's concerns have got me a bit twitchy, though I note the very helpful suggestions from Riley about covering the relevant pins.) Thanks in advance for any more light you can throw on this situation. |
#45 (permalink) |
Erfahrener Benutzer
Thanks for the heads up ck1.
I have both the FL-36 and the FL-50 and can confirm they both work really well on an M9 as well (sorry to jump in on the M8 forum). The FL-50 is a bit large unless you have a flash bracket and/or grip, but the FL-36 balances very well. I find on the M9 that you need to go for a slightly wider focal length than simply half the designated length (to account for full frame and the 4/3 2x 'crop') and perhaps use the built in wide diffuser for wide lenses to stop a slight vignette. Otherwise I can't see any downside, its just a case of learning the tweaks and foibles of the FL-36 on the Leica body. Steve
__________________
http://www.flickr.com/photos/steve_barnett/ |
#46 (permalink) |
Neuer Benutzer
I also use the FL 50 with my M8, and it works flawlessly. You will need to get out of the 4/3 mode and back into the FF mode to get a better match. This is easy to do, if you can remember the steps to take, i.e. which buttons to push and for how long!
Roger |
#47 (permalink) |
Erfahrener Benutzer
I use an FL-36 on R8 and R3 with (so far?) no problems, but my ancient hammerhead flash used for years on the R3, has a triggering voltage of just over 200!
I had been using that on an E-300 and an E-1 with never a thought of possible camera frying, but emailed Olympus, Australia who said if I must use it, to use a Wein Safesync HSHSB to cut down the voltage to a safe 6 volts maximum. I never worry about the extra FL-36 contacts using the Wein, but used to put a bit of plastic to cover them on the R8, just in case. (The R8's hotshoe is said to be safe to 24 volts). John. |
#48 (permalink) |
Neuer Benutzer
I use the same combination. But I find it extremely difficult to mount the FL-36 flash on my M8. Only through a bit of violence, I can mount it. In fear of destroying my camera I do not use this combination. Are there others who have similar experiences?
#49 (permalink) |
Benutzer
Hi all (I was formerly CK1)
...I got 2 emails back from Leica: "I can not guarantee the Olympus flash gun will not harm the M8 camera, but it will certainly not give any dedicated function" and "I have not used this Flash Unit...I can only recommend the SF24D Flash unit sold by Leica...I am unable to comment as to compatibility issues with Olympus flash units...Sorry I could not be more help...Thanks.." |
#50 (permalink) | |
Erfahrener Benutzer
Quote:
probably not an FL36 problem
__________________
#51 (permalink) | |
Neuer Benutzer
Quote:
I, of course, understand the commercial reasons behind this attitude but, looking at it from another angle, if Olympus (and other camera manufacturers) were interested in maximising their sales generally (ie not just of their cameras), you might think they'd want to promote their products being used as much as possible with other brand cameras (simplistic attitude on my part, I know). Of course, also, if Leica made a flash with the additional desirable capabilities of other brand flashes (such as the FL-36), we could all spend more of our time actually using our cameras rather than on trying to sort out such problems here. Cheers Michael (still waiting for my M9 to turn up!) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/leica-m8-forum/20429-m8-olympus-fl-36-flash-works.html
| Posted By | For | Type | Date | |
| Untitled document | This thread | Refback | 01.07.2009 13:41 | |
| Small auto flash for Leica M8? - FM Forums | This thread | Refback | 24.05.2007 08:19 | |
