Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
090909 Promo
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
Old 25.01.2010, 20:12   #1 (permalink)
Neuer Benutzer
Default M8 shutter stops
M8/35-1,4 ASPHO
My new used M8 I'm using it 2 weeks is a perfect camera. My question is:
Three times during taking pictures the shutter did not continue to work. I have seen that when I turn it off, the numbers of resting pictures and battery stayes on.
This stops after 10 seconds.
When I turn the camera on again, no more problems, it happened 3 times.
Is there anyone who has an advice or knows why it happened and what to do?
Thanks for answers,
Gerjan
Gerjan is offline   Reply With Quote
Old 25.01.2010, 20:14   #2 (permalink)
Erfahrener Benutzer
Default Re: M8 shutter stops
Was there a red LED blinking on the back of the camera? It sounds as if you filled the camera's buffer and it was simply saving off the images. During that time the shutter will not fire until the buffer has cleared out enough to store an image.
brucek is offline   Reply With Quote
Old 25.01.2010, 20:19   #3 (permalink)
Erfahrener Benutzer
Nicoleica's Avatar
Hi Gerjan,
When this occurred, had you been making several photographs in quick succession? If so, then the camera's buffer may have filled, and you just have to wait a few seconds for the camera to finish writing to the SD card and the red light to stop flashing before you can continue.
Edit. oops. sorry Brucek. I took too long typing again.
__________________
Nicole
Never stand between an old bat and her Leica!
Last edited by Nicoleica; 25.01.2010 at 20:21. Reason: I must type faster.. I must type faster...I must type faster..
Nicoleica is offline   Reply With Quote
Old 28.01.2010, 23:25   #4 (permalink)
Erfahrener Benutzer
Gerjan, you're probably running up against the end of the M8 buffer, as the others said. If the "write" diode is blinking when the camera stops shooting, that's what's happening.
However, I've recently run up against a similar occurrence which I didn't have before having the M8 shutter "upgraded":
Now, sometimes, using the camera in "S" mode with "normal" advance, after I've pressed the release two or three times in succession, pressing it again doesn't work. I have to press two or three times before it will again take a picture.
This may or may not be related to the "Jesus stripes" I reported elsewhere. My camera is currently on sojourn to New Jersey for a correction of both these behaviors.
__________________
Best,
Howard Cornelsen
ho_co is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
