Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
090909 Promo
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
LinkBack (68) Thread Tools Display Modes
Old 29.11.2006, 14:56   8 links from elsewhere to this Post. Click to view. #61 (permalink)
Erfahrener Benutzer
Default Re: Proof of concept regarding self coding of lenses
Quote:
Originally Posted by chetccox
Decimal equivalent from binary codes-
added 90mm f4 from previous post
21 f2.8 0XX000 = 24
24 f2.8 0XX00X = 25
28 f2.0 0XX0X0 = 26
28 f2.8 0XXX00 = 28
35 f1.4 0XXX0X = 29
35 f2.0 0XXXX0 = 30
50 f1.0 0XXXXX = 31
50 f1.4 X00000 = 32
50 f2.0 X0000X = 33
50 f2.8 X000X0 = 34
75 f2.0 X00X00 = 36
90 f2.0 X00XX0 = 38
90 f4.0 X00XXX = 39
Interesting? I would guess the 75 lux to be X000XX =35
Not sure about the 90 f2.0 - the 90 f2.8 has a code of X00XX0 (38). You can also code the macro adapter, which I assume will be the same as the 90/4. I'm thinking parhaps the 90/2 is 37, the 75mm Summilux is 35 and the old 28mm f2.8 is 27. Using this scheme, original TE is 42.
__________________
Mark
marknorton is offline   Reply With Quote
Old 29.11.2006, 15:10   #62 (permalink)
Erfahrener Benutzer
Original Pre-ASPH 35/2 has a code of 6...
__________________
Mark
Old 29.11.2006, 15:11   #63 (permalink)
Erfahrener Benutzer
Quote:
Here's where a Sharpie could take an M lens in a proper 28mm mount and mark it with the 27 pattern, to see what the camera tells us. Similarly, as I recall the 75 shows with the 50 frame, so see if you can mark a 50 to look like the 75/1.4 by giving it code number 35. Since 28 and 90 are paired (right?), wiping the 27 off the existing 28 and recoding it as a 37 will answer the final question in Mark's list.
scott
__________________
___________________
www.pbase.com/skirkp
www.cs.huji.ac.il/~kirk
scott kirkpatrick is offline   Reply With Quote
Old 29.11.2006, 15:19   #64 (permalink)
Erfahrener Benutzer
The macro adapter has no code. Interesting...
Bruce
brucek is offline   Reply With Quote
Old 29.11.2006, 15:26   #65 (permalink)
Erfahrener Benutzer
The entry for the 90 f2.0 was a typo. It should have been for the 2.8.
The others should fit in exactly as you mentioned.
chetccox is offline   Reply With Quote
Old 29.11.2006, 16:28   #66 (permalink)
Erfahrener Benutzer
Corrected table
21 f2.8 0XX000 = 24
24 f2.8 0XX00X = 25
28 f2.0 0XX0X0 = 26
28 f2.8 0XX0XX = 27 ? OLD 28
28 f2.8 0XXX00 = 28
35 f1.4 0XXX0X = 29
35 f2.0 0XXXX0 = 30
50 f1.0 0XXXXX = 31
50 f1.4 X00000 = 32
50 f2.0 X0000X = 33
50 f2.8 X000X0 = 34
75 f1.4 X000XX = 35
75 f2.0 X00X00 = 36
90 f2.0 X00X0X = 37
90 f2.8 X00XX0 = 38
90 f4.0 X00XXX = 39
left to right, code on top, black is X, white is 0
Old 29.11.2006, 16:31   #67 (permalink)
Neuer Benutzer
Quote:
Originally Posted by carstenw
Maybe you can use a purple one, Guy
I presume that the reading you did is counter-clockwise? Let's standardize on clockwise, it seems logical somehow. However, I would suggest that instead of 0 and X, where X means sharpie, we use binary. These are numbers. Standard in the computer industry is that 0 is black (like 'off'), 1 is white (like 'on'), and the easiest way to read the pattern is to place it at 12 O'Clock. Here are all the codes so far, read in this way (compared to previous chart 0 is 1 and X is 0).
16-18-21/4.0 Asph: 010101 = 21
21/2.8 Asph: 100111 = 39
24/2.8 Asph: 100110 = 38
28/2.0 Asph: 100101 = 37
28/2.8 Asph: 100011 = 35
28-35-50/4.0 Asph:
35/1.4 Asph: 100010 = 34
35/2.0 Asph: 100001 = 33
50/1.0: 100000 = 32
50/1.4 Asph: 011111 = 31
50/2.0: 011110 = 30
50/2.8: 011101 = 29
75/1.4:
75/2.0 Apo-Asph: 011011 = 27
90/2.0 Apo-Asph:
90/2.8: 011001 = 25
90/4.0:
135/3.4 Apo-Asph:
Still wanted: 28-35-50 T-E, 75 Lux, 90 Cron, 90 Macro, 135 Telyt.
my 35/2.8 pre asph 100100=36
my 75/1.4 011100=28
vincent1 is offline   Reply With Quote
Old 29.11.2006, 16:34   #68 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by hrosell
Street precaution – less attraction...
I've done plenty of shots in the street (architectural and parks) in rather questionable areas with two M6 and a R6.2 masked. You feel somehow safer this way...
Regards,
Horacio
Figures, I guess. Doesn't strike one so much out here in Singapore where street crime seems lower! Actually most people don't seem to know what a Leica is and how much it costs. Earlied this week though I was surprised when at a large dinner part someone I know sent me a text message enquiring about the cost of the camera!!
vikasmg is offline   Reply With Quote
Old 29.11.2006, 16:37   #69 (permalink)
Erfahrener Benutzer
Is Leica going to code the 135/3.4 Apo-Asph?
__________________
Peter
Peter41951 is offline   Reply With Quote
Old 29.11.2006, 17:07   #70 (permalink)
Erfahrener Benutzer
Sean, with Mike's elegant coding solution, that kind of removes the need for user lens selection, doesn't it?
If we can get this to work reliably then yes it could be very useful. My Sharpie will be busy today when time allows. I don't yet see how this could work with the screw mount lenses because the adapters (at least the ones I have here) don't cover the 6-bit sensor. Maybe with a different adapter?
Cheers,
Sean
__________________
Sean Reid
http://www.reidreviews.com
sean_reid is offline   Reply With Quote
Old 29.11.2006, 17:09   #71 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by mike prevette
None of my screw mount to M adapters were a possibility for this as they have a cut away shape where the lens sensor is. i.e. there is no material on the mount to draw on.
_mike
I ran into that same problem last night. Darn...
Sean
__________________
Sean Reid
Old 29.11.2006, 17:13   #72 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by andybarton
Given that the vignetting and other characteristics of Zeiss lenses are likely to be completely different to those of Leica ones, the only advantage that I can see of this operation is to add the focal length to the EXIF data.
I can't see Leica objecting to that.
Hi Andy,
One of things that comes out in that 28s article is that the cyan cast is not so different and the vignetting of some lenses is also similar to that of their Leica competitors.
Cheers,
Sean
__________________
Sean Reid
Old 29.11.2006, 19:44   #73 (permalink)
Neuer Benutzer
To save a lot of time sending lenses back to Leica couldn't Leica provide a kit to carry out the coding by the owners of lenses? The kit would comprise of a template to lock into position on the lens flange and suitable markers to create the code. I do not think that this would be expensive and it would be another way for Leica to support their loyal customers.
My first posting in this forum. Best wishes to all.
Barmul.
Barmul is offline   Reply With Quote
Old 29.11.2006, 19:58   #74 (permalink)
Benutzer
this whole coding system is bunk anyway. Any correction system that doesn't take into account shooting aperture can cause more harm than good. Imagine shooting with a lens that the firmware corrects for 1 stop of vignetting, at f8 when the lens renders no noticable vignetting. The camera wil still automaticly correct for it, and to your RAW data none the less. Thats unacceptable.
_mike
My understanding is that this correction is for the difference between light rolloff caused by the digital sensor vs how the image is produced by film. So after the correction is applied, in theory you should be left with the same image you would have were you shooting film. At full aperture you'd have darker corners than you would at f:11, just as you would have with film. So if this is unacceptable, it would also have to be considered unacceptable when shooting KII on an M2.
Jean LeBlanc is offline   Reply With Quote
Old 29.11.2006, 19:59   #75 (permalink)
Erfahrener Benutzer
johnastovall's Avatar
This all looks like fun much on the level of making a pin hole camera with an Oatmeal box but if Leica wanted to do the right thing they would put this all in a firmware menu.
Why don't we rather than going out buying sharpies, take up collection and buy a Nikon D200 and send it to Solms. Maybe they could be inspired by the example.
__________________
"The market wants a Leica to be a Leica: the inheritor of tradition, the subject of lore, and indisputably a mark of status to own."
Mike Johnston
johnastovall is offline   Reply With Quote
Old 29.11.2006, 20:03   #76 (permalink)
Erfahrener Benutzer
blakley's Avatar
In the meantime, here's a quick-and-dirty template. Print it out; the gray surround should be exactly 2 inches by 2 inches.Cut out all the white parts. The cutout at lower left aligns with the little recessed slot in the lensmount; the holes then represent the code bit positions. It's easiest to get on if you cut the recessed-slot piece all the way through to the edge of the paper so you can just open the template up and slip it on. I've made it a nice shade of magenta :-) If you want a template you can use over and over again, I'd suggest a trip down to Office Depot to get some overhead transparencies to print the template on. That way your sharpie won't damage the template.
blakley is offline   Reply With Quote
Old 29.11.2006, 20:05   #77 (permalink)
Erfahrener Benutzer
Jean,
After rethinking the issue, I agree with you that it isn't eliminating all vignetting, it's only eliminating the vignetting it introduces. So my point is sort of mute. I still think we should be the ones in control of how much correction is applied to our raw data (beyond the typical data formating of course).
_mike
mike prevette is offline   Reply With Quote
Old 29.11.2006, 20:17   #78 (permalink)
Erfahrener Benutzer
robsteve's Avatar
Quote:
Cheers,
Sean
Sean:
I just looked at an original Leica adapter and it too had the cutout in the coding area.
I suppose you could screw the adapter on to the lens and then try the coding on the screw mount flange of the lens itself. You could even just put a piece of white tape on the lens and mark the coding on that. It is only a bit over a mm between the M flange and the exposed screw flange underneath. The coding may still work from that distance and if it does, it is less likely to wear off.
robsteve is offline   Reply With Quote
Old 29.11.2006, 20:25   #79 (permalink)
Erfahrener Benutzer
Exactly my thought as well, Mike.
Also, no matter Leica does it with current 6-bit coding on the mount or, through adding firmware functions letting users input the lens data manually - such as Nikon is already doing with the F6, D2 and D200, ... I can hardly believe that Leica will include the optical characteristics mapping of other lenses from Zeiss, CV or whoever else - so as Andy says, all you get is the EXIF data ... who is in desperate need of that - certainly not me.
sdai is offline   Reply With Quote
Old 29.11.2006, 20:40   #80 (permalink)
jlm
Erfahrener Benutzer
an interesting lens to hack would be the CV15, if a workaround for the missing metal can be found.
i looked at the new 16-21 tri-elmar at photokina: reading counter-clockwise at the lens base: w w w w B w. this would be a good shot fot the CV15
jlm is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/leica-m8-forum/10494-proof-concept-regarding-self-coding-lenses.html
Posted By For Type Date
Untitled document This thread Refback 05.03.2010 18:46
Untitled document This thread Refback 05.03.2010 10:37
Untitled document This thread Refback 05.03.2010 10:02
Untitled document This thread Refback 05.03.2010 09:43
Untitled document This thread Refback 05.03.2010 09:42
m8 primeras imagenes • Ver Tema - Codificación lentes casera This thread Refback 28.02.2010 23:21
m8 primeras imagenes • Ver Tema - Codificación lentes casera This thread Refback 25.02.2010 20:32
Effeunoequattro - La Leica M8 [Forum - Digitale] This thread Refback 24.02.2010 19:27
Untitled document This thread Refback 13.02.2010 08:08
Effeunoequattro - La Leica M8 [Forum - Digitale] This thread Refback 04.01.2010 23:06
m8 primeras imagenes • Ver Tema - Codificación 6 bits casera para objetivos M This thread Refback 02.01.2010 14:24
Effeunoequattro - La Leica M8 [Forum - Digitale] This thread Refback 29.12.2009 15:45
Effeunoequattro - La Leica M8 [Forum - Digitale] This thread Refback 28.12.2009 21:45
Effeunoequattro - La Leica M8 [Forum - Digitale] This thread Refback 28.12.2009 15:31
m8 primeras imagenes • Ver Tema - Codificación 6 bits casera para objetivos M This thread Refback 22.12.2009 12:49
´·»²ÄÌÞÛ¸ÞƒÀŠO•”ØÝ¸ This thread Refback 15.10.2009 14:48
‰¿Ši.com - w‚±‚̃Jƒƒ‰‚Á‚āu”ƒ‚¢v‚Å‚·‚©Hx ƒ‰ƒCƒJ LEICA M8 ‚̃Nƒ`ƒRƒ~Œfަ” This thread Refback 10.10.2009 13:20
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 02.10.2009 22:05
´·»²ÄÌÞÛ¸ÞƒÀŠO•”ØÝ¸ This thread Refback 25.09.2009 10:17
‰¿Ši.com - ƒ‰ƒCƒJ LEICA M8 ‚̃Nƒ`ƒRƒ~Œfަ” This thread Refback 03.08.2009 03:23
´·»²ÄÌÞÛ¸ÞƒÀŠO•”ØÝ¸ This thread Refback 21.07.2009 15:53
´·»²ÄÌÞÛ¸ÞƒÀŠO•”ØÝ¸ This thread Refback 19.07.2009 05:13
´·»²ÄÌÞÛ¸ÞƒÀŠO•”ØÝ¸ This thread Refback 15.07.2009 16:14
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 04.07.2009 01:50
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 30.06.2009 19:21
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 30.06.2009 08:10
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 30.06.2009 08:07
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 29.06.2009 16:35
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 29.06.2009 14:18
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 29.06.2009 14:01
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 29.06.2009 12:13
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 29.06.2009 11:34
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 29.06.2009 11:26
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 29.06.2009 11:16
Êëóá Äàëüíîìåð :: Ïðîñìîòð òåìû - Leica M8 - â íîãó ñî âðåìåíåì! This thread Refback 29.06.2009 11:15
Coding lenses for Leica M8.2 with a sharpie? | Lightstalkers This thread Refback 25.06.2009 19:50
[Leica] Self-coding lenses, was Yellowstone This thread Refback 18.06.2009 09:30
´·»²ÄÌÞÛ¸ÞƒÀŠO•”ØÝ¸ This thread Refback 07.06.2009 08:45
´·»²ÄÌÞÛ¸ÞƒÀŠO•”ØÝ¸ This thread Refback 06.06.2009 12:08
´·»²ÄÌÞÛ¸ÞƒÀŠO•”ØÝ¸ This thread Refback 06.06.2009 03:29
´·»²ÄÌÞÛ¸ÞƒÀŠO•”ØÝ¸ This thread Refback 29.05.2009 14:10
´·»²ÄÌÞÛ¸ÞƒÀŠO•”ØÝ¸ This thread Refback 29.05.2009 13:55
´·»²ÄÌÞÛ¸ÞƒÀŠO•”ØÝ¸ This thread Refback 06.05.2009 05:27
‰¿Ši.com - ƒ‰ƒCƒJ LEICA M8 ‚̃Nƒ`ƒRƒ~Œfަ” This thread Refback 24.01.2009 16:32
BoPhoto.com: M8 coder - simple manual handcoding of M lenses This thread Refback 23.01.2009 23:14
‰¿Ši.com - ƒ‰ƒCƒJ LEICA M8 ƒNƒ`ƒRƒ~ This thread Refback 15.10.2008 06:21
‰¿Ši.com - ƒ‰ƒCƒJ LEICA M8 ƒNƒ`ƒRƒ~ This thread Refback 02.06.2008 13:44
?????????Proof of concept regarding self coding of lenses - Leica User Forum This thread Refback 18.12.2007 13:31
[Leica] Self-coding lenses, was Yellowstone This thread Refback 12.11.2007 20:22
RD-1 & M8 for Something I love...323 : 自分����棚�上��... This thread Refback 14.10.2007 11:55
‰¿Ši.com - ƒ‰ƒCƒJ LEICA M8 ƒNƒ`ƒRƒ~ This thread Refback 22.09.2007 17:05
L E I C A P A S S I O N F O R U M :: Leggi argomento - help, dima per modifica 6 bit This thread Refback 18.09.2007 13:44
L E I C A P A S S I O N F O R U M :: Leggi argomento - help, dima per modifica 6 bit This thread Refback 15.09.2007 18:15
L E I C A P A S S I O N F O R U M :: Leggi argomento - help, dima per modifica 6 bit This thread Refback 14.09.2007 19:28
L E I C A P A S S I O N F O R U M :: Leggi argomento - help, dima per modifica 6 bit This thread Refback 14.09.2007 19:24
L E I C A P A S S I O N F O R U M :: Leggi argomento - help, dima per modifica 6 bit This thread Refback 14.09.2007 14:37
L E I C A P A S S I O N F O R U M :: Leggi argomento - help, dima per modifica 6 bit This thread Refback 14.09.2007 13:00
L E I C A P A S S I O N F O R U M :: Leggi argomento - help, dima per modifica 6 bit This thread Refback 14.09.2007 12:53
L E I C A P A S S I O N F O R U M :: Leggi argomento - help, dima per modifica 6 bit This thread Refback 14.09.2007 12:45
‰¿Ši.com - ƒ‰ƒCƒJ LEICA M8 ƒNƒ`ƒRƒ~ This thread Refback 13.08.2007 06:28
‰¿Ši.com - ƒ‰ƒCƒJ LEICA M8 ƒNƒ`ƒRƒ~ This thread Refback 23.07.2007 08:11
Re: Question questions questions (new M8) - ok, yes, I'm excited: Leica Talk Forum: Digital Photography Review This thread Refback 20.06.2007 07:34
Question questions questions (new M8) - ok, yes, I'm excited: Leica Talk Forum: Digital Photography Review This thread Refback 20.06.2007 07:05
LEICA M8‚ɂ‚¢‚ẴNƒ`ƒRƒ~y‰¿Ši.comz This thread Refback 21.05.2007 04:40
ƒ‰ƒCƒJ‚·‚ׂĂɂ‚¢‚ẴNƒ`ƒRƒ~?y‰¿Ši.com?z This thread Refback 20.05.2007 08:51
LEICA M8‚ɂ‚¢‚ẴNƒ`ƒRƒ~?y‰¿Ši.com?z This thread Refback 19.05.2007 16:42
LEICA M8‚ɂ‚¢‚ẴNƒ`ƒRƒ~?y‰¿Ši.com?z This thread Refback 19.05.2007 16:03
LEICA M8‚ɂ‚¢‚ẴNƒ`ƒRƒ~?y‰¿Ši.com?z This thread Refback 19.05.2007 15:51
Similar Threads
Thread Thread Starter Forum Replies Last Post
Does Size Matter? templar Customer Forum 15 05.02.2009 19:33
Will I need my D2 Lens hood in Paris in December 2006 ? dugby Digital Forum 27 27.07.2006 02:16
Speculating re how M8 lens coding might work edlaurpic Digital Forum 45 19.07.2006 00:10
M8 lens coding the official word guy_mancuso Digital Forum 16 14.07.2006 04:41
M8 Viewfinder Rolo Digital Forum 86 12.07.2006 05:17
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
