ShotCapture Posted April 17, 2014 Share #1 Posted April 17, 2014 Advertisement (gone after registration) Got a wedding to shoot with my M240. It froze up 2 X in 2 days. I have a M9 for a backup, and the wedding is to be shot all available light per request of the bride. The M240 can handle it, but the M9??? Should I spring for a new M240 while my M240 is sent off for repair, or trust that the freezups can be controled by battery removals, (and won't occur during a key shot)? Quote Link to post Share on other sites More sharing options...
Advertisement Posted April 17, 2014 Posted April 17, 2014 Hi ShotCapture, Take a look here Get 2nd M 240, or.... I'm sure you'll find what you were looking for!
ShotCapture Posted April 17, 2014 Author Share #2 Posted April 17, 2014 P.S. If I got the 2nd M240, I would use the M9 in trade for it, but it is really frustrating to not be sure if I can trust the 240 I have. Then what if a new 240 has the same problem? What to do... Quote Link to post Share on other sites More sharing options...
leica1215 Posted April 17, 2014 Share #3 Posted April 17, 2014 I encountered couple times, mainly due to high iso like above2000, my experience is when iso gets higher the M gets slower, and SD card compatibility, I personal found that Toshiba SD card not working as good as Sandisk. it is just my personal opinion. for wedding, if you want the luxury of using Leica then be prepare something might happen, it just the possibility. 1 Quote Link to post Share on other sites More sharing options...
Reddotcamera Posted April 17, 2014 Share #4 Posted April 17, 2014 If I were in your shoes, I would trade in the M9 for a second M240. I'd be certain that the new M240 was 100% functional before the wedding. I'd take the dysfunctional M240 to the wedding shoot as a back-up to the new M240. I would send the dysfunctional M240 off for warranty service after the wedding shoot is complete, and then I'd have two M240 bides when it returns from service. That is what I'd do; YMMV. Quote Link to post Share on other sites More sharing options...
jaapv Posted April 17, 2014 Share #5 Posted April 17, 2014 If you find a friendly dealer he might trade the M9 in towards a second M240, but still let you keep it temporarily as a backup loaner whilst the original M240 is off under guaranty. 1 Quote Link to post Share on other sites More sharing options...
jto555 Posted April 17, 2014 Share #6 Posted April 17, 2014 I to have had a few lockup issues. Pulling the battery out is the only way to get the camera working again. If this is the same issue you are having, try formatting your cards with: https://www.sdcard.org/downloads/formatter_4/ I have found that the SD Formatter helps a lot. Quote Link to post Share on other sites More sharing options...
plasticman Posted April 17, 2014 Share #7 Posted April 17, 2014 Advertisement (gone after registration) If you find a friendly dealer he might trade the M9 in towards a second M240, but still let you keep it temporarily as a backup loaner whilst the original M240 is off under guaranty. I want to buy from this dealer!! Quote Link to post Share on other sites More sharing options...
bybrett Posted April 17, 2014 Share #8 Posted April 17, 2014 Of course the M9 can handle it! (available light) 2 Quote Link to post Share on other sites More sharing options...
jaapv Posted April 17, 2014 Share #9 Posted April 17, 2014 I want to buy from this dealer!! You should 1 Quote Link to post Share on other sites More sharing options...
Paul J Posted April 17, 2014 Share #10 Posted April 17, 2014 Given I have zero problems with my M9 I would say use the M9 and the 240 as a backup. 1 Quote Link to post Share on other sites More sharing options...
Gerard Posted April 17, 2014 Share #11 Posted April 17, 2014 From my experience shooting weddings, available light simply doesn't cut it. I always used to push the fact I had fast lenses and preferred to work with available light, but I now sell the benefits of carefully applied flash when the light gets low. 3 Quote Link to post Share on other sites More sharing options...
rirakuma Posted April 17, 2014 Share #12 Posted April 17, 2014 I had lockup issues at the start and as suggested by some forumites the problem will go away after a few recharges. I would suggest to keep the M9 alongside the M as it draws differently and they compliment each other quite well. Not sure how dark your venue will be but if you need a low light camera you should consider hiring a DSLR as a backup for this particular shoot. Quote Link to post Share on other sites More sharing options...
wda Posted April 17, 2014 Share #13 Posted April 17, 2014 I am really surprised that you question the M9's ability to shoot effectively in available light. Brett for sure used his M9 for weddings and I also believe his M8 before that. Just do a trial run beforehand in the venue or similar. 1 Quote Link to post Share on other sites More sharing options...
algrove Posted April 17, 2014 Share #14 Posted April 17, 2014 shotcapture Admirable venture. Have you done this before with a Leica? Sending your camera in for lockups is a waste of time I found since there is no current fix for it. I was hoping by buying an M after the latest .12 FW update (not required on earlier versions) would help, but it does not. Cold weather, warm and hot weather, it still locks up. Not using the EVF sometimes extends the # of shots between lockups, but that is no assurance either. I use 2 M240's so I have 2 different FL immediately available. Quote Link to post Share on other sites More sharing options...
ShotCapture Posted April 17, 2014 Author Share #15 Posted April 17, 2014 There does not seem to be a pattern of when M 240s in general lock up. Different forum members seem to have different theories on when their camera locked up, but I don't see any consistency in how it happens. This is discouraging for I worry that a new body will do the same. ls there any foolproof cure? It does not seem that there is. Yes I've shot a wedding with an M9. it was quite well lit and an easy shoot. This wedding will be under darker circumstances, but with even lighting that the M 240 could handle well. The bride really does not want flash at all.and will be asking guests not to use flash also. Quote Link to post Share on other sites More sharing options...
jaapv Posted April 17, 2014 Share #16 Posted April 17, 2014 There is no rhyme or reason to this lockup story. I had them only in very high ambient temperature, with the EVF active and autoshutoff enabled. Otherwise never. Other users report differently. I supect, but cannot prove that the "other" .lockups (from my perspective) must be SD card related, but have not yet been able to discern a pattern For the record, I use Lexar Professional 16 GB 600x cards. Quote Link to post Share on other sites More sharing options...
ShotCapture Posted April 17, 2014 Author Share #17 Posted April 17, 2014 Some of the suggestions have been "recharge the batteries multiple times". I 've done that. "Don't use the EVF". I do not want to give it up because I find it very valuable for low light shots with my 0.95 and I use it a lot for that and for my 21mm. "An SD formatter "helps a lot". I have not tried it yet, but "helps a lot" does not give me confidence. "Don't use high ISO", but then I give up my M240 advantage. Quote Link to post Share on other sites More sharing options...
ShotCapture Posted April 17, 2014 Author Share #18 Posted April 17, 2014 There is no rhyme or reason to this lockup story. I had them only in very high ambient temperature, with the EVF active and autoshutoff enabled. Otherwise never. Other users report differently. I supect, but cannot prove that the "other" .lockups (from my perspective) must be SD card related, but have not yet been able to discern a pattern For the record, I use Lexar Professional 16 GB 600x cards. Is there anyone using Lexar Pro 16 GB 600x cards that HAS had a lockup? Quote Link to post Share on other sites More sharing options...
ShotCapture Posted April 17, 2014 Author Share #19 Posted April 17, 2014 JAAPV if it was only card related, you should not have had your lockup. Quote Link to post Share on other sites More sharing options...
2wk Posted April 17, 2014 Share #20 Posted April 17, 2014 As much as I love Leica...if it was me, and I was being paid to capture very important moments... I dunno, I think I would rent a D4 and a couple fast primes or something like an EM-1. Even a 5Dmk3 is going to guarantee you capture that kiss, or whatever important moment. The Leica is going to give you some classy points. But those points would quickly vanish when you miss the bouquet toss and the bride is glaring at you while you are pulling out your battery. Its a tough call, but you already know about these lock-ups and that isn't very pro. 2 Quote Link to post Share on other sites More sharing options...
