richfx Posted December 11, 2014 Share #1 Posted December 11, 2014 Advertisement (gone after registration) I found both these vintage lenses for my MM in extremely clean condition and had both CLA'd (the Canon by Youxin Ye and the Nikkor by Don Goldberg). The Nikkor is substantially softer wide open. In fact, there's not much of a comparison between both lenses at f/1.4. My understanding from research was that Nikkors of this vintage were stellar lenses (my Nikkor 35mm 1.8 LTM is an amazing lens on the MM and tack sharp wide open). Is this just the way the Nikkor renders or might my copy have something wrong with it? Quote Link to post Share on other sites More sharing options...
Advertisement Posted December 11, 2014 Posted December 11, 2014 Hi richfx, Take a look here Nikkor and Canon 50mm 1.4 LTMs. I'm sure you'll find what you were looking for!
Stealth3kpl Posted December 11, 2014 Share #2 Posted December 11, 2014 I believe the Nikkor Millenium 50/1.4 is the one to get. I think Pico mentioned a while back that he prefers the Nikon 50s to those of Leica. Pete Quote Link to post Share on other sites More sharing options...
Lenshacker Posted December 11, 2014 Share #3 Posted December 11, 2014 I've owned Two Canon 50/1.4's, have twelve Nikkor 5cm F1.4's between Leica mount and S-Mount. I would suspect that something is wrong with your Nikkor. Do a focus check on something like graph paper. The Nikkor is a Sonnar formula lens, has more field-curvature. Normally the Nikkor is optimized for wide-open/close-up work, center sharp. The focus is controlled by a simple shim. My Nikkor was sharper than the Canon in the center, the Canon had better flatness-of-field. Quote Link to post Share on other sites More sharing options...
Lenshacker Posted December 11, 2014 Share #4 Posted December 11, 2014 I believe the Nikkor Millenium 50/1.4 is the one to get.I think Pico mentioned a while back that he prefers the Nikon 50s to those of Leica. Pete The Millenium Nikkor must be used with a Nikon to M-Mount adapter, was never made in native Leica mount. I have one, it is very good. It is not a Sonnar formula lens, as most of the 1950s Nikkors. Quote Link to post Share on other sites More sharing options...
richfx Posted December 12, 2014 Author Share #5 Posted December 12, 2014 Thanks for the focus test suggestion. It isn't front or back focusing; it's just extremely soft wide open. Quote Link to post Share on other sites More sharing options...
Lenshacker Posted December 12, 2014 Share #6 Posted December 12, 2014 Post some shots. The Nikkor has a lot of focus shift, which shows up as a low-contrast image when used wide-open. I end up using the Zeiss 5cm F1.5 Sonnars more than the Nikkor. Quote Link to post Share on other sites More sharing options...
uhoh7 Posted December 12, 2014 Share #7 Posted December 12, 2014 (edited) Advertisement (gone after registration) I have both, though my nikkor, 1954 5cm /1.5 uses amedeo adapter. It's not soft wide open. Here on A7r: Vic by unoh7, on Flickr These lenses are so different, there is no either or. The nikkor is a portrait sonnar, the canon is a more all around lens with totally different rendering. Canon LTM WO on M9: L1001685 by unoh7, on Flickr at f/4: L1001696 by unoh7, on Flickr The LTM Nikkors are notorious for being beat up and out of calibration. They were mostly used by pros. For best results I think you are better off with a pristine SC mount adapted to M: DSC01569-2 by unoh7, on Flickr The jena sonnar is again totally different. No relation real world to the nikkor, though it's the inspiration. Optimized for infinity, while nikkor shoots best at 2 meters. Edited December 12, 2014 by uhoh7 1 Quote Link to post Share on other sites More sharing options...
uhoh7 Posted December 12, 2014 Share #8 Posted December 12, 2014 (edited) 1937 Jena WO on M9 Shy Friend by unoh7, on Flickr f/8: jena blue by unoh7, on Flickr no post on last, that's the real contrast on M9. This was the best all around 5cm lens in the world for over 20 years, not for nothing. jena on M9 via amedo adapter: DSC06958 by unoh7, on Flickr Again LTM copies not likely to be great. Native Contax mount preferred. Edited December 12, 2014 by uhoh7 Quote Link to post Share on other sites More sharing options...
Lenshacker Posted December 12, 2014 Share #9 Posted December 12, 2014 (edited) My early Leica Mount 5cm F1.4, "Tokyo" wide-open, on the M Monochrom Nikkor 5cm F1.4, early Nikkor 5cm F1.4, early, Leica Mount Nikkor 5cm F1.4, early Edited December 12, 2014 by Lenshacker 1 Quote Link to post Share on other sites More sharing options...
Lenshacker Posted December 12, 2014 Share #10 Posted December 12, 2014 (edited) 1937 Jena WO on M9 .... Again LTM copies not likely to be great. Native Contax mount preferred. I cheat. 1934 5cm F1.5 CZJ Sonnar, now Leica Mount. Wide-open on the M9, Marine Museum, Quantico 1936 5cm F1.5 Sonnar, now Leica Mount, Wide-open on the M Monochrom. L1003963 by fiftyonepointsix, on Flickr Both are uncoated. The out of focus areas of the Zeiss lenses are smoother than the Nikkor. The Nikkor tames down at F2. My two "best" F1.5 Sonnars, a 1943 5cm F1.5 Sonnar "T" and a 1950 Jupiter-3 that was made in April 1945. Both required a lot of work to bring the elements back into alignment. jupiter3_1950 by fiftyonepointsix, on Flickr Edited December 12, 2014 by Lenshacker Quote Link to post Share on other sites More sharing options...
uhoh7 Posted December 13, 2014 Share #11 Posted December 13, 2014 I cheat. 1934 5cm F1.5 CZJ Sonnar, now Leica Mount. Wide-open on the M9, Marine Museum, Quantico 1936 5cm F1.5 Sonnar, now Leica Mount, Wide-open on the M Monochrom. L1003963 by fiftyonepointsix, on Flickr Both are uncoated. The out of focus areas of the Zeiss lenses are smoother than the Nikkor. The Nikkor tames down at F2. My two "best" F1.5 Sonnars, a 1943 5cm F1.5 Sonnar "T" and a 1950 Jupiter-3 that was made in April 1945. Both required a lot of work to bring the elements back into alignment. jupiter3_1950 by fiftyonepointsix, on Flickr LOL yes I love your hybrids, but the results are hard earned. Whipping out a simple amedeo adapter feels more like cheating LOL 1 Quote Link to post Share on other sites More sharing options...
richfx Posted December 13, 2014 Author Share #12 Posted December 13, 2014 Post some shots. The Nikkor has a lot of focus shift, which shows up as a low-contrast image when used wide-open. I end up using the Zeiss 5cm F1.5 Sonnars more than the Nikkor. Here are wide open shots with my Nikkor 50mm 1.4 LTM and Canon 50mm 1.4 LTM, respectively. Crops follow each photo. Focus is on the aperture ring numbers. The Nikkor is fuzzy (some may say it glows), for lack of a better word, and the Canon is quite bit sharper, at least to me (in addition to being noticeably contrastier). Is this the way both lenses are supposed to render? Rich Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/238335-nikkor-and-canon-50mm-14-ltms/?do=findComment&comment=2727860'>More sharing options...
Lenshacker Posted December 14, 2014 Share #13 Posted December 14, 2014 (edited) The shots with the Nikkor- show a lot of flare. Shining a light through the back of the lens, is there any haze on the inner surfaces or fine scratches on the surfaces? My Nikkors do much better than this; I have seen Nikkors do this due to cleaning marks, and other lenses do this because of haze. I chose this shot as an example, note back-lit leaves against the tree, the edges are well defined. This lens is the earlier design, around 1953 (or so) the optics changes slightly. Nikkor 5cm F1.4, early Edited December 14, 2014 by Lenshacker Quote Link to post Share on other sites More sharing options...
Lenshacker Posted December 14, 2014 Share #14 Posted December 14, 2014 (edited) Later Black 5cm F1.4 Nikkor-S, wide-open on the M8. This version was current with the Nikon SP, the diameter of the optics and fixture was increased "about" the same time that Nikon moved to the 24x36 format. Nikkor 5cm F1.4 on the Leica M8 Also chosen for the lighting. Edited December 14, 2014 by Lenshacker Quote Link to post Share on other sites More sharing options...
uhoh7 Posted December 14, 2014 Share #15 Posted December 14, 2014 wow superb, and really shows off the M8 as well here my 1954 5cm f/1.4, the plain Jane: L1022622 by unoh7, M9 It can be quite glowy and I find it very particular as to the circumstances in which it decides to shine But the lens can deliver like no other. Here an early shot with my Nex-5. DSC01631-1 by unoh7, on Flickr Quote Link to post Share on other sites More sharing options...
uhoh7 Posted December 14, 2014 Share #16 Posted December 14, 2014 The Canon is just a very nice all around lens: L1001716 by unoh7, on Flickr the M9 seems to like it quite a bit. L1001683 by unoh7, on Flickr For daily use I would prefer the canon. Quote Link to post Share on other sites More sharing options...
richfx Posted December 14, 2014 Author Share #17 Posted December 14, 2014 The shots with the Nikkor- show a lot of flare. Shining a light through the back of the lens, is there any haze on the inner surfaces or fine scratches on the surfaces? My Nikkors do much better than this; I have seen Nikkors do this due to cleaning marks, and other lenses do this because of haze. I chose this shot as an example, note back-lit leaves against the tree, the edges are well defined. This lens is the earlier design, around 1953 (or so) the optics changes slightly. Nikkor 5cm F1.4, early No haze or scratches on the rear or other elements. It's completely clean. The mystery continues. 1 Quote Link to post Share on other sites More sharing options...
Lenshacker Posted December 14, 2014 Share #18 Posted December 14, 2014 Try a picture of something flat with structure- brick wall or fence slats. Look to see if any of the corners are more out of focus than others. If the front element or inner triplet is misaligned, you might get increased flare. I've seen some strange aberrations from lenses before, there is usually a reason why some are worse than others. I've seen some that were misassembled at time of manufacture, NEVER worked right until reconstructed. Quote Link to post Share on other sites More sharing options...
rscheffler Posted December 15, 2014 Share #19 Posted December 15, 2014 (edited) My understanding is Youxin Ye does not have a collimator to ensure lenses are optimally reassembled. It would make me a bit skeptical about sending lenses for CLA. But then Brian, you're doing a lot of stuff to lenses, do you think this a collimator is a necessity? BTW, I have both the Nikkor 5cm/1.4 LTM and the Canon (I guess the second version). They're certainly different and enjoy each one very much. I recently did some infinity test shots with a bunch of lenses on the a7S and M240, including the Canon. I wouldn't classify it as tack sharp wide open. It has SA glow and needs f/2 to get the center nice and snappy, while stopping down continues to improve the image towards the edges. I also tested the CV50/1.5 LTM and while it's sharper/higher contrast centrally - probably at least a stop ahead of the Canon, towards the edges it's not that much different/better. As Charlie said, the Canon is a really good all-round lens and tough to beat for the price if looking for a cheap, fast RF compatible 50. BTW, my test is here, with high-rez downloads. Edited December 15, 2014 by rscheffler Quote Link to post Share on other sites More sharing options...
Lenshacker Posted December 15, 2014 Share #20 Posted December 15, 2014 (edited) I use my M Monochrom to set shims, and at best can reseat glass when the corners show a smear. J-3's and Zeiss Sonnars- the construction lends itself to these methods working. I actually own a 1950s Nikon Collimator, but it is a museum piece. I also have the 50/1.5 Nokton in LTM: the front doublet came loose in it, the inner retaining ring was not tightened all the way down. The group finally fell out of position, and focus was off and image smeared. Turns out that if you use standard flat tips to tighten the ring, the tips hit a ridge and someone thought it was tight. I ended up using my modified needle nosed pliers for the final turn, all is good now. The name "lenshacker"- I chose for a good reason! If the lens fails the corner tests, I would send it to DAG. Edited December 15, 2014 by Lenshacker Quote Link to post Share on other sites More sharing options...
