Strange effect from 35mm Lux FLE
viboons
My daughter's sunglass shape was distorted. Can anyone give me a clue how this happen and how to avoid?
Thank you for you all.
The 3 photos were adjusted in LR5.7
#1 -100 Highlight
#2 -100 Contrast
#3 -100 both Highlight & Contrast
This is the photo when I try to hard not to blow the brighter area and correct in the LR.
The second photo, the cropped, show horizontal stripes.
And are you shooting .DNG raw pictures, or .jpg originals?
The two pictures you have shown so far are of scenes with extreme contrast ranges. You simply cannot expect to get detail in black hair, shaded under a hat, under a roof - and also get detail in sunlit white surfaces.
Except (maybe) with a) color negative film, or B) using high dynamic range (HDR) techniques (shoot multiple bracketed exposures with a tripod, and use Lightroom to combine them for the maximum amount of detail range.
What does that second portrait look like - straight from the camera with no special processing in LR?
(By the way - none of this has to do with 35 FLE lens itself. While it is a modern contrasty lens compared to some historical lenses, most lenses would produce similar problems in similar light.)
Edited by adan
The ISO is 160 f2.0 1/125 sec. and +4.0 exposure in LR5.7
I know I made wrong exposure and trying to recover in LR is not working. However; what I wonder is that I took another shot with in 5-10 seconds and with the same setting but had no horizontal line.
Thanks to confirm me that nothing wrong with my 35mm Lux FLE.
Edited by viboons
Extreme local adjustments required (to window area and adjacent to glasses), but even then I suspect highlights are blown beyond recovery. The solution is better exposure to start (or a closed window shade).
Jeff
The airplane shot looks well exposed to me. I'm surprised that the camera would have just ignored information due to the backlight. It's not just edges of the sunglasses/face that have been affected but approx. 50% of the sunglasses have simply not registered.
I have the same lens but use it with film. I have shot it straight at strong light sources many times, and metered properly, but I have never seen this phenomenon.
Edited by philipus
You have probably rotated the first shot, and not the second shot.
Rotating pictures may produce stripe artifacts (interference between sensor noise pattern and rotation algorithm).
