Guest NEIL-D-WILLIAMS Posted October 28, 2014 Share #1 Posted October 28, 2014 Advertisement (gone after registration) Anyone have or know of a Lee Filter holder for a 21mm Lux I made one before with a 21mm lux hood but it really didn't work that great........looking for other ideas and a 21mm f3.4 is not an option:D Quote Link to post Share on other sites More sharing options...
Advertisement Posted October 28, 2014 Posted October 28, 2014 Hi Guest NEIL-D-WILLIAMS, Take a look here Lee GND filter for 21mm Lux. I'm sure you'll find what you were looking for!
01af Posted October 28, 2014 Share #2 Posted October 28, 2014 There's an E82 filter holder available for the Summilux-M 21 mm Asph (art. no. 14481) which screws on the lens in place of the hood. Then you might work your way from there ... Quote Link to post Share on other sites More sharing options...
mirekti Posted October 28, 2014 Share #3 Posted October 28, 2014 looking for other ideas and a 21mm f3.4 is not an option:D ...than CV Ultron 21mm might be your choice. ;-) Quote Link to post Share on other sites More sharing options...
tobey bilek Posted October 28, 2014 Share #4 Posted October 28, 2014 LR or PS model. Use HDR, or graduated filter where you control the density and steepness of the graduation. Fits any lens. Can be customized to accommodate objects that stick up into the darkened area. Need not carry it with you. I can not think of a single instance where a factory blend fit a real photo unless it is a sunset over an ocean. Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted October 28, 2014 Share #5 Posted October 28, 2014 There's an E82 filter holder available for the Summilux-M 21 mm Asph (art. no. 14481) which screws on the lens in place of the hood. Then you might work your way from there ... I just saw that on eBay...............do you think that by the time you stack another adapter on top of that plus the holder the filter will end up to far away from the lens causing vegetating Quote Link to post Share on other sites More sharing options...
jdlaing Posted October 28, 2014 Share #6 Posted October 28, 2014 I just saw that on eBay...............do you think that by the time you stack another adapter on top of that plus the holder the filter will end up to far away from the lens causing vegetating I'm Googling vegetating now. Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted October 28, 2014 Share #7 Posted October 28, 2014 Advertisement (gone after registration) I'm Googling vegetating now.its the black bits in the corners of the picture Quote Link to post Share on other sites More sharing options...
DMJ Posted October 28, 2014 Share #8 Posted October 28, 2014 Scrape them off & it'll still be ok. Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted October 28, 2014 Share #9 Posted October 28, 2014 Okay so I ordered the E82 filter holder the seven5 holder and 3 adapter rings plus a Lee 0.6 GND filter along with the stepdown ring.........so I should be good to go Quote Link to post Share on other sites More sharing options...
DigitalHeMan Posted October 28, 2014 Share #10 Posted October 28, 2014 Okay so I ordered the E82 filter holder the seven5 holder and 3 adapter rings plus a Lee 0.6 GND filter along with the stepdown ring.........so I should be good to go Will be interested to hear your views on the seven5. I tried to modify my 100mm filter holder for use on the Leica and it failed miserably..... Now thinking about the Lee system as well Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted October 28, 2014 Share #11 Posted October 28, 2014 Will be interested to hear your views on the seven5. I tried to modify my 100mm filter holder for use on the Leica and it failed miserably..... Now thinking about the Lee system as wellSimonMy first go around I bought a spare lens hood (~200 bucks) and had it modified on the rig by the rig welder and it worked but to be honest was crap............vingetting was bad and the welder was blind as it wasn't square so that little project cost me more than all of the above that I just ordered from B&H. Anyway once I get it all I will post up some pictures of the set up Quote Link to post Share on other sites More sharing options...
jdlaing Posted October 29, 2014 Share #12 Posted October 29, 2014 SimonMy first go around I bought a spare lens hood (~200 bucks) and had it modified on the rig by the rig welder and it worked but to be honest was crap............vingetting was bad and the welder was blind as it wasn't square so that little project cost me more than all of the above that I just ordered from B&H. Anyway once I get it all I will post up some pictures of the set up Wouldn't it be simpler to just get the 82mm filter holder and a 82mm GND? Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted October 29, 2014 Share #13 Posted October 29, 2014 Wouldn't it be simpler to just get the 82mm filter holder and a 82mm GND? There's not such a thing Quote Link to post Share on other sites More sharing options...
jdlaing Posted October 29, 2014 Share #14 Posted October 29, 2014 There's not such a thing Tiffin B&W Formatt Hitech All available at BH Photovideo. Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted October 29, 2014 Share #15 Posted October 29, 2014 There round and not gnd Quote Link to post Share on other sites More sharing options...
jdlaing Posted October 29, 2014 Share #16 Posted October 29, 2014 There round and not gnd Work with me here. Tiffen 82mm Color Graduated ND .6 (4x) Filter 82CGND6 Tiffen 82mm Graduated 0.6 ND Filter 82CGND6 B&H Photo Video HOYA | The Difference is Clear Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted October 29, 2014 Share #17 Posted October 29, 2014 There round and not gnd TiffinB&W Formatt Hitech All available at BH Photovideo. If the attached is what you are talking about they are crap as you cannot adjust the height so you always have the horizon 50/50........sorry no good laaa Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted October 29, 2014 Share #18 Posted October 29, 2014 For landscape photography you need to be able to adjust the height of the filter so that it is level with either the horizon or where light meets dark and with the rule of thirds that is not good..........if you only have the option to go 50/50 Quote Link to post Share on other sites More sharing options...
darylgo Posted October 29, 2014 Share #19 Posted October 29, 2014 For landscape photography you need to be able to adjust the height of the filter so that it is level with either the horizon or where light meets dark and with the rule of thirds that is not good..........if you only have the option to go 50/50 Theoretically you are correct however these filters are quite useful. They reduce density toward the edge when looking at the filter however in use the final image shows a very subtle transition that adds just enough neutrality to save many images. Soft transition, of course. The vignetting issue I believe will be there with the 21mm adapter and Lee filter holder, perhaps using the wide-angle adapter and no more than one slot it will be okay. My solution is to hold the square (rectangular) type filters in hand and forget the holder. The plastic filters, including the Lee filters are okay quality, the glass gnd filters used in cinema can deliver better image quality, I find that testing is needed on each filter due to inconsistency. Quote Link to post Share on other sites More sharing options...
Berlinman Posted October 29, 2014 Share #20 Posted October 29, 2014 I use my LEE Filter only simple handheld without bulky stuff. Quote Link to post Share on other sites More sharing options...
