ericborgstrom Posted August 27, 2014 Share #1 Posted August 27, 2014 Advertisement (gone after registration) Two lenses with 40 years between them, one made in Canada the other in Germany. Photos shot with Leica M240 on a tripod at f/11. The second with a wider view of course is the 18mm. –Eric Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 7 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/232962-mandler-19mm-r-ver-i-and-karbe-18-mm-m/?do=findComment&comment=2658095'>More sharing options...
Advertisement Posted August 27, 2014 Posted August 27, 2014 Hi ericborgstrom, Take a look here Mandler 19mm-R ver. I and Karbe 18 mm-M. I'm sure you'll find what you were looking for!
k-hawinkler Posted August 27, 2014 Share #2 Posted August 27, 2014 Thanks Eric. What is the point you are making? Both images look fine to me on my iPad. Quote Link to post Share on other sites More sharing options...
ericborgstrom Posted August 27, 2014 Author Share #3 Posted August 27, 2014 That is also my conclusion. You need to print realy large to see much of a difference at f/11. But the older lens has unsharp corners at f/2.8. The Karbe lens is much better at full aperture. –Eric 1 Quote Link to post Share on other sites More sharing options...
mmradman Posted August 27, 2014 Share #4 Posted August 27, 2014 That is also my conclusion. You need to print realy large to see much of a difference at f/11. But the older lens has unsharp corners at f/2.8. The Karbe lens is much better at full aperture. –Eric Newer M lens is also almost f4, that in itself provides more sharpness than f2.8 for given focal length. 1 Quote Link to post Share on other sites More sharing options...
pgk Posted August 27, 2014 Share #5 Posted August 27, 2014 My 19mm suffered from severe flare if pointed anywhere towards the light. I have the 21mm SEM which is amazingly flare resistant as is the 18mm I'd guess. Quote Link to post Share on other sites More sharing options...
Peter Branch Posted August 28, 2014 Share #6 Posted August 28, 2014 My 19mm suffered from severe flare if pointed anywhere towards the light. I have the 21mm SEM which is amazingly flare resistant as is the 18mm I'd guess. It also has an "interesting" distortion profile. Not visible in the pictures shown but for architecture the 18mm wins hands down - especially if the ACR profile for the 18mm is applied - distortion is then in the process lens class. Quote Link to post Share on other sites More sharing options...
billo101 Posted August 28, 2014 Share #7 Posted August 28, 2014 Advertisement (gone after registration) Mandler ! Quote Link to post Share on other sites More sharing options...
Erik Gunst Lund Posted August 28, 2014 Share #8 Posted August 28, 2014 .... The second with a wider view of course is the 18mm. –Eric Is the 18mm wider than the 19mm? The upper right corner in the first one seems,,, very bad af f/11 IMHO Quote Link to post Share on other sites More sharing options...
Peter Branch Posted August 28, 2014 Share #9 Posted August 28, 2014 Is the 18mm wider than the 19mm? The upper right corner in the first one seems,,, very bad af f/11 IMHO One of the issues that Leica had to address was the fact that legally, at least in the UK, it was not a 19mm lens. They took, most unusually, to quoting the diagonal field of view, 97.5 degrees. This implies a focal length greater than 19.5 mm and hence it should have been described as a 20mm lens. I believe it was actually 19.7 mm. The 18mm is actually 18.3 mm. 1 Quote Link to post Share on other sites More sharing options...
jankap Posted August 28, 2014 Share #10 Posted August 28, 2014 Is the 18mm wider than the 19mm? The upper right corner in the first one seems,,, very bad af f/11 IMHO You mean the vignetting? Was this R-lens corrected in the camera too? Jan Quote Link to post Share on other sites More sharing options...
ericborgstrom Posted August 28, 2014 Author Share #11 Posted August 28, 2014 Is the 18mm wider than the 19mm? The upper right corner in the first one seems,,, very bad af f/11 IMHO The upper right corner is nearly 1 km away. The rocks 1m. Even at f/11 I did not get it all in focus. –Eric 1 Quote Link to post Share on other sites More sharing options...
ericborgstrom Posted August 28, 2014 Author Share #12 Posted August 28, 2014 You mean the vignetting? Was this R-lens corrected in the camera too?Jan I used the manual lens selection for the R lens (I think it only transfer EXIF data), automatic for the coded M. In lightroom profiles for both lenses were used. –Eric Quote Link to post Share on other sites More sharing options...
