louispreynolds Posted July 26, 2014 Share #1 Posted July 26, 2014 Advertisement (gone after registration) I have an M2 with Rigid 50mm Summicron and a Jupiter-12 35mm f/2.8 lens. Recently i have been starting to think that I prefer the 35mm frame to the 50mm frame when shooting, I think th 50 seems too tight. However I don't know whether this is down to the fact that I can see what is outside the 50 frame or because it is actually too tight. the 35mm on an m2 obviously fills the viewfinder, thus i can't see anything outside of it. So, I am trying to at least level-out the lenses so that I have a good 50 and a good 35 - I'm looking at leica for this, but i can't stretch to the prices of even 35mm summaron 3.5s. Are there any leica mount 35mm lenses out there that are around £300? If so, this means i could keep the sum micron!! or should i sell it ad replace with a cheap one?? ahhhh i go round in circles - anyone got any suggestions on what i should do/what you did in the situation? thnks for your patience, Louis Quote Link to post Share on other sites More sharing options...
Advertisement Posted July 26, 2014 Posted July 26, 2014 Hi louispreynolds, Take a look here Lens Suggestion. I'm sure you'll find what you were looking for!
250swb Posted July 26, 2014 Share #2 Posted July 26, 2014 The Cosina Voigtlander (CV) 35mm f/2.5 Color Skopar is a very good lens and comes in around £300 or less on eBay. It is available in LTM or M mount and although the two have a different body style the optical elements are the same. If you can ever envisage buying a Barnack Leica with screw mount the LTM version is the one to go for and use an LTM to M adapter on it for the M2. There are no concerns about sharpness and rendering with this lens, it easily fits into a Leica system in terms of optical quality. Steve 4 Quote Link to post Share on other sites More sharing options...
CalArts 99 Posted July 26, 2014 Share #3 Posted July 26, 2014 I agree 100% with the Color Skopar suggestion. It's a really excellent lens. It's also very small (yet with good ergonomics; there no fumbling around when using it.) Attached to the M2 it can become a truly coat pocket sized package. You might have a hard time discerning whether an image was taken with the CV Color Skopar or a 35mm Summicron in the end. I think it's really that good of a lens. 3 Quote Link to post Share on other sites More sharing options...
louispreynolds Posted July 27, 2014 Author Share #4 Posted July 27, 2014 The Cosina Voigtlander (CV) 35mm f/2.5 Color Skopar is a very good lens and comes in around £300 or less on eBay. It is available in LTM or M mount and although the two have a different body style the optical elements are the same. If you can ever envisage buying a Barnack Leica with screw mount the LTM version is the one to go for and use an LTM to M adapter on it for the M2. There are no concerns about sharpness and rendering with this lens, it easily fits into a Leica system in terms of optical quality. Steve Well in that case it sounds like I have a winner! I looked on ebay and it even has a focusing tab like the summicron!!! Thanks very much for your suggestion. Both of you 1 Quote Link to post Share on other sites More sharing options...
